Old 08-27-2007, 10:52 PM   #126
abadsvt
abadsvt's Avatar
Re: progress pics
Looks Sick!!!! These trucks looks so good low like that! I will be watching this build thread for sure!!!
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-17-2007, 05:47 PM   #127
jlaird
jlaird's Avatar
Re: progress pics
a little progress, actually it looks like I went backwards, because I took the cab off, but had to to chop the trailing arm crossmember. So that is what I finished (except for the exhaust cutouts). She cant go any lower, shes on the ground! Heres some pics. Next up is to make a crossmember that goes between the trailing arm x-member and the axle.
jlaird is offline   Reply With Quote
Old 09-17-2007, 06:27 PM   #128
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: progress pics
Looking awesome, can't wait to see the body on that frame
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-25-2007, 07:35 PM   #129
jlaird
jlaird's Avatar
Re: progress pics
Got the driveshaft loop x-member finished as well as the exhaust cutouts almost done. Some pics:
Old 09-26-2007, 01:44 AM   #130
BigShoe24
True Addiction
BigShoe24's Avatar
Re: progress pics
Very nice work, keep it up. How did u determine the drive shaft loop height? Without transmission in.
BigShoe24 is offline   Reply With Quote
Old 09-26-2007, 08:24 AM   #131
jlaird
jlaird's Avatar
Re: progress pics
I've got a two piece drive shaft which means it's at a fixed height at the carrier bearing.
Old 09-26-2007, 08:29 AM   #132
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: progress pics
Nice looking truck!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-26-2007, 11:55 AM   #133
Frizzle Fry
Frizzle Fry's Avatar
Re: progress pics
That's good, becuase I was gonna tell you that I had to raise the upper "hoop" on the TA X-Member for my one-piece driveshaft + 8" notch. With that notch you definately would too, but a two pice DS takes care of that! Nice work
What's the dia. on your exhaust cut-outs?
Frizzle Fry is offline   Reply With Quote
Old 09-26-2007, 12:12 PM   #134
jlaird
jlaird's Avatar
Re: progress pics
They have a 4" inner diameter, so will be good for something like a 3" exhaust pipe.
Old 10-02-2007, 03:11 AM   #135
impala_631
:( BYEBYE :(
impala_631's Avatar
Re: progress pics
i know its a little bite late but heres a crappy pic of my steering linkage made from 2 astro van linkages
impala_631 is offline   Reply With Quote
Old 10-02-2007, 11:26 AM   #136
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: progress pics
great work man. glad to see some progress.
on the topic of the split drive shaft. Are you concerned at all that the travel of the axle will pull on the carrier bearing? obviously normal up and down is fine, but with the extra travel that you'd get with air bags, i'm curious if the axle will put more preasure on the CB.
in my application (bagged with a split shaft) it didn't seem to put any additional pressure on the CB, but i only have a C-notch, not a step. Also, my bags are mounted on the T-arms, so my travel is not much.
IvelDesigns is offline   Reply With Quote
Old 10-02-2007, 11:52 AM   #137
jlaird
jlaird's Avatar
Re: progress pics
I'm really not worried about that at all. I set up the driveshaft and CB to work properly with the frame rails only being 5 inches off the ground. This truck is not going to see a lot of vertical travel(especially at cruising speeds) that will be putting any sort of stress on the CB. I'm not suspension expert, just seems like common sense to me.
Old 11-07-2007, 12:22 AM   #138
SBCustoms
Complete Street Customization
SBCustoms's Avatar
Re: progress pics
wheres the progress??????????????????
1968 GMC SWB (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=269230)
1998 Chevrolet Silverado Z71
Southern Born Customs
Knoxville, TN
865-934-9126
SBCustoms is offline   Reply With Quote
Old 11-08-2007, 09:00 PM   #139
jlaird
jlaird's Avatar
Re: progress pics
frame and all the suspension parts are going to the powder coater tomorrow. It will be nice to see something in my garage that is one color! Cant wait....
I will post pictures when I get it back. They said two weeks.
Old 11-08-2007, 09:06 PM   #140
XXL
Seņor Member
XXL's Avatar
Re: progress pics
Uh oh... that's a notorious statement. Do you know how many times I've heard "two [more] weeks" from body shops and "body shops?"
Hopefully your powder guys can handle it.
XXL is offline   Reply With Quote
Old 11-09-2007, 06:27 PM   #141
jkade
jkade's Avatar
Re: progress pics
Couple questions, how long is your 4 link? How big of a notch did you install? Keep up the good work.
jkade is offline   Reply With Quote
Old 11-09-2007, 10:05 PM   #142
jlaird
jlaird's Avatar
Re: progress pics
If memory serves me correctly (can't go out and measure because everything is at the powdercoaters), the 4link bars are 32 inches long and the notch ended up being about 9-10 inches.
Old 11-24-2007, 01:52 PM   #143
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Re: progress pics
Nice! I havent been up here in a while I must say! Real Clean work!
Sweet 85 C10 is offline   Reply With Quote
Old 11-24-2007, 10:53 PM   #144
onetonk5
Cereal Killer
onetonk5's Avatar
Re: progress pics
why leave the trailing arm crossmember in if your not using the trailing arms?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 11-25-2007, 08:58 AM   #145
jlaird
jlaird's Avatar
Re: progress pics
Two reasons: Strength and holds my two-piece driveshaft bracket.
So I decided to have a local engine builder build me an engine over buying a crate. I think I'm getting a pretty darn good deal. He's building me a mild 350 with vortec heads for a little more than the cost of GM's 290 horse crate. I should have that by end of December.
XXL was right on the money with the damn powder coaters. They said it should be around two weeks. Two weeks was yesterday. Their yet to call me with my final quote. I hate dealing with people like this... I guess I just have to be patient.
Old 11-25-2007, 10:17 AM   #146
XXL
Seņor Member
XXL's Avatar
Re: progress pics
Just re-reading this thread and I stumbled on this... you're probably getting MORE travel than jlaird. With his bags coming straight off the rearend, he's getting pretty much 1:1 lift. With yours on the trailing arms (assuming at the stock spring location), you're getting a little leaverage since you're "up the lever" a bit from the rearend.
If you're not getting any carrier bearing issues, he should be just fine.
Old 11-25-2007, 10:20 AM   #147
XXL
Seņor Member
XXL's Avatar
Re: progress pics
Makes you want to show up with a trailer and load your stuff up... but they've generally got us by the... uh... throat. So we have to put up with stuff like that. One day somebody with a keen sense of customer satisfaction is going to open a shop to do this stuff, and he's going to grab much of the market. Until then Bastages!
Old 12-01-2007, 02:37 PM   #148
OLDIRON69
Re: progress pics
Very nice build! I love lowered trucks, mine is a worker so laying frame is out of the Q. One day when I retire the truck from working........ AGAIN, GREAT JOB!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 01-12-2008, 07:17 PM   #149
SBCustoms
SBCustoms's Avatar
Re: progress pics
how bout the powder coating? still havent got it back? any word?
Knoxville, TN
865-934-9126
Old 01-13-2008, 05:30 AM   #150
jlaird
jlaird's Avatar
Re: progress pics
Got it back on wednesday. What a PITA. These guys took their sweet a$$ time with it. They had it for 2 months. And listen to this, they called me Monday at about 10am to say they were going to start it and to confirm I didn't change my mind on anything which was nice. I actually ended up having them do just the frame and blast everything else for me to paint myself.(I wanted to save some $$) They called me back at around 2pm to tell me it was done. They made me wait 2 MONTHS for about 4 hours of work. They have some workflow/timing issues to say the least.
The frame came out good though. I will post pics soon.
