Old 01-17-2008, 07:09 PM   #1
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Coy Wheels Don't Fit Chevy Trucks...
Without some extra work.
You really have to check clearances, when you are first installing wheels or any other after market parts. Here are some pics of problem areas.
First the wheels on the front would not go on all the way. They looked OK, but I could feel them going on the hub hard. When I checked there was a gap between the wheel and brake rotor. Smaller grease cups didn't cure it.
The inside of the wheel was too tight to go over the hubs in two areas...sanding drums on die grinder opened the wheels up enough to go on until the end of the rotor by the grease cup hit the wheel cap...I could either use spacers on the cap (that looked goofy) or grind the ends of the rotor hubs...grind away.
When they would finally go on easy and the caps cleared...I realized the valve stems hit the rotors. I guess that will call for breaking down the tires and installing some kind of angled stems???
Those open spoke areas sure show all of the rust & dirt behind the wheels, so I guess I am going to have to do some clean up & paint.
Next comes the fit on the rear wheels...
PICKMUP is offline   Reply With Quote
Old 01-17-2008, 07:12 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Coy Wheels Don't Fit Chevy Trucks...
It takes a lot of tools to put a Coy wheel on the first time...
Old 01-17-2008, 07:32 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Wow...and I've always liked Coy C5's (?) and have thought of getting a pair.
What size wheels are those?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-17-2008, 09:43 PM   #4
Premium72
Premium72's Avatar
damn that sucks!!.. good luck.
Premium72 is offline   Reply With Quote
Old 01-17-2008, 10:36 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
we need wheel/tire specs on these C5's. Gringoloco has a set on his Blazer, but I don't recall him having this much trouble...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-18-2008, 01:00 AM   #6
Hart_Rod
Hart_Rod's Avatar
PICKMUP,
Have you called them and discussed the issues? I would like to install a set, but prefer not to have to deal with issues like that. Maybe it's something they can easily fix. I had a friend that installed a set on an 86 SWB and he had know issues. Is that year of rotors that much different?
Hart_Rod is offline   Reply With Quote
Old 01-18-2008, 01:35 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
I only had to deal with one of those issues with my 20/22 combo; the hub cap beveling. The valve stems they sent me were the "flush" style that would probably work for you too. As long as the removable stem doesn't hit the rotor when you need to air it up.
Frizzle Fry is offline   Reply With Quote
Old 01-18-2008, 01:55 AM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Actually, these types of problems are very common when installing non-OEM parts. These wheels (17x8 w/4" BS) were probably designed to fit cars---more common. I got them used and they were said to be on an Impala? The clearances on the hubs to inside of wheels were close, but a little too tight to go on.
The rotors sticking out and hitting the caps may be from replacement rotors not being exact. After 40 years, who knows.
I put American 200S "Coke Bottles" on the front of my 2wd Blazer and the caps hit the grease cups. I ended up putting a bead of silicone between the wheel & hub on the inside to keep dirt out and run them without dust caps. That sounds scary, but it is all sealed up in there, so it works fine.
My point is, check everything you install carefully. 50% of it won't fit without help and 25% of it will just be wrong.
I wish I had $1 for every time I send pics & info to manufacturers on problems and get back the classic answer, "Well, no one else has ever complained...and we sell a lot of them".
Old 01-18-2008, 03:26 AM   #9
Alvin
Never Done?
Alvin's Avatar
I bought some 17x8 Edelbrock 454 wheels and hit similar problems. They had tri-bar spinners that actually screwed onto the push-in center cap. The center cap wouldn't fit over the hub, just like the coy's. I also had a problem of the lug recesses on the face of the wheel. The only thing I can figure is the 5x5 cars must have smaller lugs, because there was no way I could fit a lug nut in the recess.
I wound up going with 17x8 American Racing Torq-thrust Originals. They bolted right up without any problems.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-18-2008, 04:44 AM   #10
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
That's what I had to do with my front wheels too.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 01-18-2008, 11:32 AM   #11
see ten
WTB this ad
see ten's Avatar
I had to run knock offs instead of the standard caps to clear the hubs on my Billet Cruzers. 71see10 had to grind his rotors like you did to get his Centerlines to fit.
see ten is offline   Reply With Quote
Old 01-18-2008, 01:09 PM   #12
67_C-30
I have a radical idea!
67_C-30's Avatar
They do. The cars have 7/16" studs and the trucks have 1/2" after '71.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-25-2008, 04:44 PM   #13
Chevy Fleetside
Chevy Fleetside's Avatar
They look pretty to me... I might even get some for my 65...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-25-2008, 06:35 PM   #14
fatboys69
fatboys69's Avatar
had the same problem on my 69, this is waht I did. I can send out the cad file so you can get some made.
http://67-72chevytrucks.com/vboard/s...d.php?t=288030
fatboys69 is offline   Reply With Quote
Old 05-30-2008, 04:39 AM   #15
billydonn
Council of the Elders
billydonn's Avatar
Here's how TT2s fit on 72up rotors
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-30-2008, 02:23 PM   #16
fatboys69
fatboys69's Avatar
I had the TT2's before the Coys and had no issues with the TT2's on my 69.
Just a difference with the wheel mfg's I guess
Old 05-30-2008, 05:29 PM   #17
GKsport67
GKsport67's Avatar
I wouldn't want to purchase "NEW WHEELS" n have to alter them to fit!
The procedure should be ...1.slep'em on 2.ride FLY!
GKsport67 is offline   Reply With Quote
Old 05-30-2008, 05:39 PM   #18
ortegamotor
ortegamotor's Avatar
that is why Coys are cheaper then the rest.you have to fit a generic size rim to a specific size vehicle and it takes some grinding . i have a set of centerline smoothies ,like a lot of you out there and on the front rotor they have the same issue with our trucks. only because they are set up for a newer 5 lug rotor.i think coys needs to take a look at the design of that wheel and possible make some adjustments.
ortegamotor is offline   Reply With Quote
Old 05-30-2008, 05:55 PM   #19
GKsport67
GKsport67's Avatar
They becoming real popular! i just saw an OLD TRADER magazine with a 40's truck with some chrome COY's n it was nice but...
Old 05-31-2008, 06:53 AM   #20
AllenKarber
Thanks again for that file Dewayne!! I had terrellautosports from here cut me a set of spacers,and they should be here really soon!. Thanks Tim!!! You rock!
That should solve the fitment issue, but now I have to go to work on the substandard (in my eyes) polishing job. I won'y have to bother with using soft towels as the wheels came equipped with fine scratches right from Coy's.
The valve stems hitting the caliper will not be an issue either. On my Coy's,you unscrew a cap and screw in an adaptor to air up the tire. When you're done, you screw the cap back in. Pretty cool!
AllenKarber is offline   Reply With Quote
Old 05-31-2008, 06:50 PM   #21
Nobby
Nobby's Avatar
I had to grind down my rotors for my coys to fit on the front of my Blazer.
Nobby is offline   Reply With Quote
Old 06-02-2008, 07:50 AM   #22
GKsport67
GKsport67's Avatar
I must say they look just as good as the TTII's
Old 06-02-2008, 08:14 AM   #23
Deuce
Deuce's Avatar
I had the same problem.
Requested a copy of the file for the spacers.
Damn COYS!!!! I'd spend the money on a better set of wheels next time.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 07-25-2008, 01:53 AM   #24
r1lorenzini
Just got my new bonspeeds 22's and my 72 2wd blazer wont let me get the cap on anyways so it seems we are all dealing with the same crap!
r1lorenzini is offline   Reply With Quote
Old 07-25-2008, 09:31 PM   #25
Fastfun
Fastfun's Avatar
When I installed my Boyd'sI had to do a little grinding on the front set also
Fastfun is offline   Reply With Quote
