03-27-2008, 09:43 PM | #1 |
SAS S-10 axles and stuff
Not sure if this is the right place or not, mods feel free to move it if needed.
I have some axles that I was gonna use for an SAS on my Blazer, but thing is slowly getting worse. Dana 44 front out of an early Bronco, '74 IIRC. Was drum brakes open knuckle, so donor parts are easy to get, which I will get. 5,6 or 8 lug. Ground all the coil stuff off, spring pads ready to be welded on. 3.54 gears. 9" from the same truck, no center or brake drums. Needs everything brake related..... $250 for the above pair. Dana 60 rear 63" wide, out of a 60s Ford. 8 lug full floater, 4.10s open. Was gonna use this in the rear of the S-10, with 8 lugs up front, would match the rear width pretty close. This prolby needs brake work, been sitting outside for awhile. $100. NV4500 tranny, 2wd no bell/shifter. $350. 15x8" 8 lug wagon wheels, 4.25" b/s. $100. XJ Dana 44 rears (2) these came in Cherokees and pickup with the tow package. There are alot of Jeeps up here, and only found these two, getting hard to find. Haven't checked the gears, but guessing 3.54. These are the same width as an S-10, so would be a good upgrade. Parts are cheap and easy to find, and of couse much stronger..$350 each. I really want to get rid of this stuff. If I don't get rid of it, gonna want to keep it and use it, don't really have the time, money or patience or place to do it. This stuff is b/o, would prefer pickup, but I can meet somewhere for a buck or two for gas, or I go near Harrisburg PA every nite, so could meet there too. I can ship as long as buyer sets it up.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
