03-28-2008, 06:12 AM | #1 |
Cluster Light Problems
I have all my other interior lights working now except for my cluster lights...I noticed in the fuse box there is a spot that reads cluster feed---is that what I'm missing or any ideas???
03-28-2008, 07:11 AM | #2 |
its all about the +6 inches
Re: Cluster Light Problems
cluster feed would be to wire in aftermarket guages, so they would dim with the rheostat.
03-28-2008, 08:59 AM | #3 |
Check this one - http://67-72chevytrucks.com/vboard/s...d.php?t=284861
and this one - http://67-72chevytrucks.com/vboard/s...d.php?t=284477
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-28-2008, 02:40 PM | #4 |
I have tried extra grounds...everything...which copper leads on the harness connector should have juice for the lights --on the plug that plugs into the cluster--I even cleaned the heck out of all the copper leads...I'm lost...
03-28-2008, 02:42 PM | #5 |
I checked and I do have tail lights which is on the same fuse as the cluster light--so I have been told---so what now??
03-28-2008, 03:03 PM | #6 |
Have you checked circuit continuity on your printed circuit board with a meter? You may have a bad board.
1997 GMC Sierra Ext 1965 Mustang |
03-28-2008, 03:11 PM | #7 |
No..I haven't done that yet...but I have tried two seperate boards...the only light that comes on is the turn signal--but that is very weak--I would think it was a ground but I have tried extra grounds through wires, alligator clips, and even tried touching the darn thisn to the dash to ground it...I have all new fuses, new dimmer switch, new headlight switch, new dome light, new everything. I even found the factory ground and its working...
03-28-2008, 04:51 PM | #8 |
Active Member
Since you have eliminated the possibility of a ground problem and parts failure, you need to check for voltage. I'd start with "U" shaped connector and check to make sure you have the 12 vdc needed and work yourself up to the instrument panel connector.
If your lights are weak it's possible you may have a high resistance on one of your feed wires. Let us know what you find... |
03-28-2008, 06:14 PM | #9 |
the U shaped plug has nothing to do with the inst panel, that's just brake lights and turn signals.
03-28-2008, 07:37 PM | #10 |
also make sure that plug that goes into the circuit board is clean and making good contact......
03-28-2008, 08:45 PM | #11 |
Gettin By on Gettin By
May want to look at the head light switch. Might be goining bad.
03-28-2008, 09:14 PM | #12 |
Headlight switch is brand new...cleaned the contacts snd still nothing
03-28-2008, 09:43 PM | #13 |
The Older Generation
Panel lights aren't turned off at the headlight switch are they? (rotate headlight switch knob) LockDoc
03-28-2008, 10:29 PM | #14 |
Between Trucks...
They are actually.
Beat it to fit, Paint it to match... |
03-29-2008, 05:53 AM | #15 |
I give up...Tried everything again tonight...
