Old 09-09-2008, 08:13 PM   #26
lyrikz
PITbut
lyrikz's Avatar
Re: Airbaggers. Where are you putting your tanks?
Even better.
450c
450C specs
lyrikz is offline   Reply With Quote
Old 09-09-2008, 08:22 PM   #27
lowriden58
lowriden58's Avatar
i dont recommend the 450, they do have a newer version the 460c with new head design but check out Viairs site.. and compare them with REAL specs
http://www.viaircorp.com/400s.html
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 09-09-2008, 08:24 PM   #28
lyrikz
PITbut
lyrikz's Avatar
Of course they are sold out of the 460's. They always seem to be sold out of the cool stuff...
Old 09-09-2008, 08:26 PM   #29
Rollie396
someday it will be done!
Rollie396's Avatar
I realize this isn't a great option now that your exhaust is done,but mebbe it'll spark another idea.I had one of those big tanks originally,but being as I want everything out of sight,it wasn't going to work too well.I built my own tanks out of 6" pipe and mounted them like the pic shows.I was going to use two Viairs,but have since decided to try out an EDC.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 09-09-2008, 08:32 PM   #30
lyrikz
PITbut
lyrikz's Avatar
oh SONOFAB!TCH THATS awesome... ahah Nice setup man...
Cool setup..
What is an EDC if you dont mind me asking?
Old 09-09-2008, 08:35 PM   #31
lowriden58
lowriden58's Avatar
i think if you plan on running 2 comps at some point i would bite the bullet and buy the dual 480 silver pack its like 360ish and cheaper than 2 of the 450/460s ive owned the 450s before and they SUCK for normal use let alone daily use. the 480s are faster and more reliable which im about to buy a dual pack very soon for my newest project
Old 09-09-2008, 08:36 PM   #32
lowriden58
lowriden58's Avatar
EDC is Engine Driven Compressor
Old 09-09-2008, 08:36 PM   #33
Rollie396
Rollie396's Avatar
Thank you,I hope it works out like I'm thinking it will.
edc=engine driven compressor.I went junkyard hunting for an old york air conditioning pump and am plumbing it in to keep the air flowing.
'80 LWB 2wd beater
my pics
Old 09-09-2008, 09:26 PM   #34
Painter D
Painter D's Avatar
I don't know what this is going to do but here goes. .........It worked!
Ignore the wiring.
Painter D is offline   Reply With Quote
Old 09-10-2008, 05:45 AM   #35
umwtnt
umwtnt's Avatar
Good Morning Lyrikz,
I did some measuring under, around and anywhere I seen some space and it doesn't look good for you. As some of the others recommended you may be better off with 3 gallon tanks or just installed them in the bed. An idea a friend of mind made to me was to built a box to install tanks in and make them to look like tool boxes. Painted separate from the bed and maybe even a tool manufacter sticker on it to fool onlookers. Good luck and thank you for the offer to check my muffler fit. I will probably take off the cab here in a few weeks and will check it then. I do know it will be tight.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 09-10-2008, 11:08 AM   #36
Grandpa's CST
Grandpa's CST's Avatar
Cool Re: Airbaggers. Where are you putting your tanks?
I have done a few different air ride setups, cars and trucks. I have always ran and trusted 450 Viair's I run 2 on a 5 gallon tank. I use 1/2" valves up and 3/8" valves down (with the weight helping come down the speed is about the same) the system will allow it to go up and down approx twice and then it recovers reasonable fast usually 1-2 min. I don't have any solution for hidding the tank, I'm not there yet on my project. Goodluck!
Grandpa's CST is offline   Reply With Quote
Old 09-10-2008, 03:44 PM   #37
lyrikz
PITbut
lyrikz's Avatar
Dont think so huh? I made a fake tank that was 34 inches and 7 inches in diameter and it MIGHT fit... Who knows... I will find out in a few days. Thanks for the measurments.
I ordered dual pack 400's and a 5 gallon tank. I MIGHT upgrade to another 5 gallon tank later... For what i want it for, if i can go up and down without waiting once, im fine with that...
Old 09-10-2008, 08:48 PM   #38
Trey`
Active Member
Trey`'s Avatar
I had two 400's on two 7 gallon tanks under my '00 GMC for years with no problems and never burned up a compressor, just a relay once. It now has a Oasis on it but is torn apart for a rebuild. i got a good deal on it or it would still have the 400's. Just bought the 480 dual pack for my '07 but it is not bagged yet. I think you will be fine. Wish I could help you out on the air tank problem. Not the easiest thing but I have seen trucks that used there frame rails for tanks.
'70 Chevy stepside, ECE discs & 4/6,
'00 GMC ext. cab stepside, never ending project
'07 GMC Crew Cab, 24's & 5/7
"We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing"
Trey` is offline   Reply With Quote
Old 09-11-2008, 11:47 AM   #39
lyrikz
PITbut
lyrikz's Avatar
I think this will fit. Im sure i can make it fit. I dont want it pokin out under the rocker is all im worried about.. Its 7 inches in diameter, we will see how it goes... will keep you updated.
Old 09-11-2008, 12:01 PM   #40
jmuck
jmuck's Avatar
Infront of my rear wheels on my 68 swb fleetside.
jmuck is offline   Reply With Quote
Old 09-11-2008, 12:02 PM   #41
lyrikz
PITbut
lyrikz's Avatar
I have a stepside, quit teasin me. ahaha I dont have that extra room.
If the tank doesnt fit where i want it, i will just put it in the bed.... Not that big of a deal..... kinda.
Old 09-11-2008, 12:04 PM   #42
jmuck
jmuck's Avatar
paint it to match and put some pinstripes on it then it won't be an airtank it will be a piece of art!
Old 09-11-2008, 08:52 PM   #43
yotaforce
I WOULD run two tanks, outside rear frame rails, in front or behind the wheels.
yotaforce is offline   Reply With Quote
Old 09-11-2008, 11:08 PM   #44
lyrikz
PITbut
lyrikz's Avatar
Now your just messing with me. I have a stepside........Nothing fits there.
Old 09-11-2008, 11:45 PM   #45
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
ok, first the feedback you can use... whoever said one comp per 3 gal tank hit it on the head. it's gonna take way to long to fill a 5 gal tank with one compressor. i run my whole setup off a single 3 gal tank with 1 compressor. when the tank is full (160psi) i can fill my bags to ride height all the way around. Then it takes about 2-3 to refill the tank.
that seems to work well for the "just gonna drop it at the shows". I will also tell ya that for the first two - six months, you'll play with them at every stop light you can. at least i did. especially if the wife or kids were with
ok, the other thing for ya is a pick of my compressor, tank, gas tank and exhaust setup. i'm not sure if you can do this though since you're a step bed.
i'm not sure mounting it under your cab is gonna work. you may run the risk of laying your truck down on the tank, or it hitting bumps in the road.
you have to keep in mind that your truck MUST still move @ 10mph or so if you're completely aired out. if not, you're gonna be screwed if anything ever blows going down the interstate.
IvelDesigns is offline   Reply With Quote
Old 09-12-2008, 12:25 AM   #46
Riveted1
Tasty Cakes!
Riveted1's Avatar
No more of a chance than if you have it mounted on the rear portion of the frame.... It's all gonna be the same height.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 09-12-2008, 01:27 AM   #47
IvelDesigns
not really because the frame bends up before the axle. that's why the bed had perches up front, and bolts directly to the frame in the back.
Old 09-12-2008, 02:45 AM   #48
OARNGESI
OARNGESI's Avatar
Not sure if itll work but have you thought about under the hood maybe the firewall were the heater core goes
OARNGESI is offline   Reply With Quote
Old 09-12-2008, 09:07 AM   #49
Riveted1
Tasty Cakes!
Riveted1's Avatar
Ah true Ivel! Wasn't thinking about that. Makes me wonder how I did on my test in class yesterday.... All of my posts were half-assed b/c of lack of sleep!
Old 09-12-2008, 11:52 AM   #50
jorgensensc
jorgensensc's Avatar
Stepsides are A pain in the arse. If you aren't running a heater/ac box, you may be able to put the tank in the engine compartment. I never could find a good spot to mount it. My mufflers are even turned verticle, and there is still not enough roomto mount it on the inside of the frame rail. The only other thing I could think of was kind of a strange deal. I thought about putting a shelf across the trailing arms and mounting the tank and compressor to that. You would have to mount it with rubber mounts so that it could flex and move with the trailing arms. The only other thing I could think of was mounting the tank to the bottom of the bed just above the driveshaft near the front of the bed, by the driveshaft bearing. These are just a few different thoughts I had. Good Luck!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
