Old 10-15-2008, 11:06 PM   #1
Momboy007
Bolt pattern on 69 GMC 3/4 ton 8 Lug
Hello All,
Does anyone know the bolt pattern for a 69 GMC 3/4 ton truck? It has the 8 bolts, but I do not know if it 6.5" or what???
Thanks all,
Rick
Momboy007 is offline   Reply With Quote
Old 10-15-2008, 11:18 PM   #2
El Jay
Gone to greener pastures
Re: Bolt pattern on 69 GMC 3/4 ton 8 Lug
My '72 looks like 8 x 6 1/2".
I can't promise that exactly; I was working by myself with a tape major and a flashlight.
But, I'll say I'm damn close.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-15-2008, 11:57 PM   #3
Keep on Trucking
Keep on Trucking's Avatar
Yes, 8 on 6.5"
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach.
Can have new owner for the right price.
"Life is tough, its tougher if you are stupid" (John Wayne)
My buddys truck for sale here.
http://67-72chevytrucks.com/vboard/c...p?product=2676
Keep on Trucking is offline   Reply With Quote
Old 10-16-2008, 03:54 AM   #4
OhioDan
OhioDan's Avatar
I have a Dana 60, and mine are 6.5" also.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-16-2008, 06:03 AM   #5
Back when Detroit figured standardizing was a smart thing all 8-lug pickups used the same lug pattern.
Old 10-16-2008, 10:08 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
My '69 C-20 is 6.5"
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-16-2008, 11:58 AM   #7
prg machine
prg machine's Avatar
so besides the bolt circle what about the hub hole diametter differences?? Ford to Chevy vica versa??????
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-16-2008, 12:08 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
One of my rims is off a F@rd and fits O.K.
Beat it to fit,
Old 10-16-2008, 04:22 PM   #9
prg machine
i've heard that chevy won\t fit ford cause smaller hole for axle hub?????
383 .040 over
Old 10-16-2008, 11:14 PM   #10
wolfgang_90
after I think 1999 ford switched to metric.. (damn they've gone metric on us again) The metric one is like 8 on 80mm or something. Before the cut over, the ford rims bolt on to GM's and visa-versa. They are a little wider than the GM ones if I recall too.
wolfgang_90 is offline   Reply With Quote
Old 03-10-2009, 05:17 PM   #11
69time
69time's Avatar
my 69 C2500 has the 6.5. I measured it just last night.
69time is offline   Reply With Quote
Old 03-10-2009, 08:26 PM   #12
onlyifihadachevy
the newer fords wont fit theyre off by a little and chevy and dodge r the same i thinks its 8 x 6.5 and most people agree so i would go with that
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-10-2009, 09:37 PM   #13
ed2552
ed2552's Avatar
New chevy and dodges are the same because they use the same axles. And yes, there's a member here w/ the aluminum PYO's off of a newer chevy, and I've seen another w/ the chrome steelies in the long-step thread.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-10-2009, 09:38 PM   #14
chucks70
I've got Chryslers on my 3/4 ton 4X4
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 02-23-2018, 10:36 PM   #15
'65fleetSide
'65fleetSide's Avatar
Unhappy Re: Bolt pattern on 69 GMC 3/4 ton 8 Lug
Would this be the same on a 65 Chevy C30 1ton 8 lug??
'65fleetSide is offline   Reply With Quote
