Old 10-15-2008, 01:50 PM   #151
tk-mpl
tk-mpl's Avatar
Re: Ackattack's Pro touring restoration thread
Did you get the intake off of an ebay store, do you mind posting name of seller. I had another one picked out, but it did not come with a blue filter and hoses.
Looking good..
tk-mpl is offline   Reply With Quote
Old 10-15-2008, 01:59 PM   #152
Ackattack
Ackattack's Avatar
Looking good..
yep, good ol' ebay. I got this one cause the tube is aluminum, not chrome.....I can always repolish it if needed.....chrome would probably chip.
http://stores.ebay.com/insys-usa
Ackattack is offline   Reply With Quote
Old 10-15-2008, 09:08 PM   #153
Rokcrln
Rokcrln's Avatar
Looking good! What does the rest of the cold air kit look like? Does it pull the air through the rad. support or down through the inner fender? I have a 5.3L for my Blazer and if I don't Turbo it I will be doing a C.A.I. as well.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-18-2008, 12:50 AM   #154
Ackattack
Ackattack's Avatar
Kevin
LFD Inc.
Here's the other piece of the CAI.....it doesn't really fit. I may or may not use it. Basically the only place to get air is from around the headlight and other holes in the core support, so not a big supply of cold air.
Old 10-18-2008, 01:07 AM   #155
Ackattack
Ackattack's Avatar
Tonight I was finally able to get the fuel system up and working correctly. Man, aluminum line sure does flare a lot easier than stainless steel (go figure). So after I replaced my hard line and fittings, I tested it out, and no leaks!
So then I put the bed on, so now it looks like a truck!
I also got the holes drilled in the firewall for the HVAC:
I'm planning on running the lines kinds between the outer fender and the inner fender to kinda hide them. I thought of running them into the kick panel vent like someone else did (great idea) but decided not too (lots of effort and possibly more problems down the road, but definatly a cleaner look)
The other night I worked on installing the front sway bar. I worked on mounting it directly to the frame, but after getting it installed, I didn't like the way it worked. It would slide back and hit the bags when fully deflated and when fully inflated it pulled one of the bushings out of the retainer/clamp thing. So I ordered the short stands from ECE.
Speaking of ordering stuff, I ordered a bunch of little stuff that I need. I'm hoping I got all of the stuff that I'll need before paint. I also got some other things that were on my list.
I also got the A/C condenser mounted, and then the tranny cooler. Of course when I went to start making the lines for the tranny cooler (using -6 SS braided hoses) I realized I didn't have enough fittings. So it will go on my list for the next time I make a Summit order (I just got a bunch of the plumbing stuff for the fuel lines....but of course not the right fittings). I may see if the local napa sells them.
So my list of things to do before paint is getting pretty short. The two big things I have yet to do is finish installing the one piece windows (test fitting them at least) and leave the small triangle installed, so it gets painted body color, and figure out the gas filler. Now that I have the bed on, that will be the next priority.
Oh yes, I have a high hump tranny cover coming I'll have to install. Got it from a board member!
Old 10-18-2008, 10:49 AM   #156
68 short step
lookin good
68 short step is offline   Reply With Quote
Old 10-18-2008, 12:18 PM   #157
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looking good keep up the killer work.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-18-2008, 12:27 PM   #158
Rokcrln
Rokcrln's Avatar
Sounds good! Do you really need the entire high hump trany cover or could you smooth it down a bit? I have a high hump for my 2WD Blazer but plan on tweaking it a bit plus with the DM it moves the motor forward and up 2".
Kevin
LFD Inc.
Old 10-19-2008, 02:45 PM   #159
texanidiot25
Eat My Rust
texanidiot25's Avatar
The truck looks absolutly awesome man! Love that stance and the wheel/tire combo is perfect
texanidiot25 is offline   Reply With Quote
Old 10-19-2008, 02:52 PM   #160
abadsvt
abadsvt's Avatar
Looks SWEET!!! I like the wheels too!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-19-2008, 10:40 PM   #161
Rokcrln
Rokcrln's Avatar
I am sure it is back in here some place but what are the wheel and tire spec's.
Kevin
LFD Inc.
Old 10-19-2008, 11:40 PM   #162
Ackattack
Ackattack's Avatar
Kevin
LFD Inc.
Rear:
315/35/20 on 20x10 with 5.75" BS
Front:
255/40/20 on 20x8.5 with 4.25 BS
Obviously the front tires tuck, but the inner fender is hitting on them when fully aired out. I'm not going to be able to drive with it fully dumped, nor had I planned to. I haven't tried turning the tires yet
Old 10-19-2008, 11:51 PM   #163
Ackattack
Ackattack's Avatar
Today's progress:
I finished up the initial install on the Brother's one piece windows. Kinda a PITA. I thought the instructions left a lot to be desired. I'll have to finish the install once everything is painted. I did find that I have some rust to repair under one of the door hinges too.
The other day I mounted up the fender, door, and cowl and everything didn't fit real well. So I moved the cab a little (it's not bolted down yet...) and set the door where it lines up nicely, then I installed the fender and cowl. I had to do a little "adjustment" to get the lower corner of the front fender to fit good.
I didn't really like the way the gap around the door was with the drip rail missing, so I took a little advice from Frizzle Fry and filled in some of the gap with some 3/16 rod. Seemed to really help fill the gap.
I also got my other fender and grill down from my storage area. And went ahead and threw on the grill just for kicks.
I now see what piece I'm going to have to get at the salvage yard to get rid of the blinkers (they'll be in the headlights)
Finally, I spent some time cleaning up the garage. The 900 square foot 3 car garage had so much stuff spread out in it that I couldn't get any other cars in there.....now I can get 3 in there. Here is a pick of the parts I have to go back on the truck....using it for storage:
Old 10-19-2008, 11:54 PM   #164
Ackattack
Ackattack's Avatar
Kevin
LFD Inc.
I could get away with making something else that wouldn't be quite so high, but the high hump will be easier, plus I won't have issues with the carpet not fitting.
Old 10-20-2008, 12:17 AM   #165
Frizzle Fry
Frizzle Fry's Avatar
Lookin good man. Good call on the carpet.
Frizzle Fry is offline   Reply With Quote
Old 10-20-2008, 11:45 PM   #166
Ackattack
Ackattack's Avatar
So tonight I got the driver's side filler piece in. Nothing too exciting.
Then I started on cleaning up around the back window frame. I knew there was one spot I was going to have to fix. Well when I took the wire wheel to it I found that there are a lot more places that i'm going to have to fix. Hopefully it won't be too hard. I'll bend up a longer strip of sheetmetal, then as I cut out the rust, I'll just be able to cut out the right size of filler piece. Hopefully i can bust that out tomorrow night.
Old 10-21-2008, 11:34 AM   #167
djracer
djracer's Avatar
Sweet looking project. I just went through the entire thread. You may want to look where the lower felts go for the one piece window and do a little filling in there before paint. Mike Nutt said he wishes he would have. Thanks for documenting the project.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-21-2008, 12:17 PM   #168
Ackattack
Ackattack's Avatar
I kinda wondered about that area, but figured the felts covered it up. I guess I'll do a little searching on here to see what others have done or wish they had done. Thanks!
Old 10-21-2008, 08:39 PM   #169
Painter D
Painter D's Avatar
Very cool truck. I like everything you are doing to it.
I'd also like to say thanks for posting a "how to" on widening your rear wheel tubs. I did mine almost identical to how you did yours. Being able to come back and look at this thread helped out.
Again , nice work ,and nice truck.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 10-22-2008, 11:52 PM   #170
crabalais
Nice work, where did you get the tublar engine frame mounts?
crabalais is offline   Reply With Quote
Old 10-27-2008, 12:47 AM   #171
Ackattack
Ackattack's Avatar
I can't remember....I'll do some checking
I managed to get the rust around the rear window cut out and replaced with new metal, welded, and cleaned up. Turned out pretty good. I didn't get any pictures though.
Earlier last week I got my van tilt column's neutral safety switch relocated. I went to check how it fit's and installs and I realized that I'm missing the support that goes on the firewall. I must have sold it with the non tilt steering columns that I sold. Oops!
So tomorrow I'll run by the salvage yard and hopefully get one of those brackets (this place has ~5 67-72s, so hopefully I'll be able to find one bracket. While I'm there, I'm also going to try to get a 67-68 upper grill insert to put in my lower grill, since my turn signals are in the head lights.
I'm also going to make some phone calls and talk to some shops about painting my truck. I have one shop in mind. I had this shop repair my corvette's front bumper (wife backed into it). So they did a good job on that, and was willing to take on a restoration paint job (several of the other body shops I went to don't even do restoration paint work.)
I also went by another shop that also came recommended a week or two ago. Talking to them, they said there average paint job is $14k!!! I don't think I want to pay that much for paint, since I'm going to drive this thing!
So we'll see what I find out this week. Before I choose a shop, I'm going to get some references from people who they've done restoration paint jobs for....see how it turned out, if it was on time and on budget.
Old 10-27-2008, 08:26 AM   #172
djracer
djracer's Avatar
Smart move on getting references. I personally would want to see the cars not just talk to someone.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-27-2008, 01:24 PM   #173
Hart_Rod
Hart_Rod's Avatar
$14K?!?! This might be a good time to buy a paint gun and teach yourself how to paint. Looks like you've got the skills, all you need is a little practice.......
Hart_Rod is offline   Reply With Quote
Old 10-27-2008, 02:52 PM   #174
SCOTI
SCOTI's Avatar
It all depends on what a guy is wanting in the end. $14K for top-tier work that includes, stripping, prep/panel alignment, bodywork, painting (single color) & reassembly is not out of line. That's a bunch of work.
Also, the over-all affect on quality will be evident if a guy chooses to do paint/prep work in a non paint-friendly environment (dirt, dust, moisture, silicone contaminants, etc....).
Ackattack is doing a heck of a job though!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2008, 04:39 PM   #175
Hart_Rod
Hart_Rod's Avatar
Don't get me wrong, I know a top tier paint job is expensive (I've got a painter buddy that reminds me all the time, ). But if he plans on driving it a ton, spending that kind of money on a paint job would be wasted in my opinion. If you planning on showing it a lot, and want to be competitive, ya' better dig deep into those pockets.........
