Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-13-2008, 07:14 PM   #251
1sik52
Re: Building a Blazer - vtblazer's Way
Originally Posted by vtblazer View Post
Not if your gonna flame me about em...
J/K, they've got some pretty big number weight rating but I forget exactly what it is.
They hold it fine and work great 'cause their adjustable height-wise but I wouldn't care to shove the tub sideways real hard.
Yea, Id be very careful. I have a set of those and they will collapse in a heartbeat if pushed sideways!
1sik52 is offline   Reply With Quote
Old 11-13-2008, 07:18 PM   #252
vtblazer
vtblazer's Avatar
These have lock outs, you can't collapse the legs until the lock out is dis-engaged.
vtblazer is offline   Reply With Quote
Old 11-17-2008, 11:47 PM   #253
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
OK, it's been 4 days, time for an update on either the garage or the Blazer.
low'n slow is offline   Reply With Quote
Old 11-18-2008, 06:52 AM   #254
vtblazer
vtblazer's Avatar
Nothing all that exciting but things are still moving forward.
Garage:
Got my lighting up, installed four 8ft H.O.'s, three together on one switch and the fourth on a three-way between the passthrough doors for coming/going.
Moved the overhead door button inside for easier, more convenient access and started the insulation process. (putting up insulation sux)
Blazer:
The POR is here but need to finish the insulation so I can get the garage up to temp before painting it.
The fifth H2 wheel has been located.
I did finally "use" the garage as a garage though, pulled out and used a lot of good power tools.
Even fired up the plasma cutter.
Started working on retrofitting an old truck plow blade to fit a buddy's tractor.
Old 11-18-2008, 07:08 AM   #255
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Progress is progress!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 11-19-2008, 11:30 PM   #256
low'n slow
low'n slow's Avatar
Progress, how ever slow is still progress. Looks good, both the garage and the Blazer.
Did you put heat in the garage?
Old 11-20-2008, 06:20 AM   #257
vtblazer
vtblazer's Avatar
True, it's all good stuff.
This years heat source will just be a little 30K propane heater w/fan I already have, it's small but does a decent job of throwing heat out and with the insulation done (someday) it'll be fine for this year.
Worked on the kitchen for 12hrs yesterday.
All insulated and rocked so the family is warm, now I can move onto the garage without catching h*ll for it...
Hoping to finish up the plow bucket we're currently working on which means more plasma and welding, maybe more insulating there too.
14 degrees here this morning.
Old 11-20-2008, 07:03 AM   #258
Chevyman63
Chevyman63's Avatar
I feel your pain...yesterday it didn't get above the freezing point here.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-24-2008, 06:35 AM   #259
vtblazer
vtblazer's Avatar
Had some left over 2x6's from the garage build, had an old 1.5" thick 4'x6' laminated desk top taking up space, had a sheet of 3/16th iron...hmmm.
Turned em into a nice little compact shop bench, it's only 2'x4' but that's what I wanted and had room for.
Used the 'cut to size' desk top as a template for the plasma cutter, worked slick.
Got the kitchen sheet rock completed over the weekend, hope to prime and hang cabinets Monday.
The little woman's been really decent about the garage build but I'm thinking that having the kitchen up and running for turkey day might be a good idea.
Old 11-24-2008, 07:11 AM   #260
Chevyman63
Chevyman63's Avatar
Cool...one of the all important accessories.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-24-2008, 07:23 AM   #261
vtblazer
vtblazer's Avatar
...this is one of those too.
Old 11-24-2008, 07:27 AM   #262
Chevyman63
Chevyman63's Avatar
No doubt about it!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-24-2008, 11:48 PM   #263
low'n slow
low'n slow's Avatar
How are going to finish off the beam in the kitchen? We lived in an old house in Texas that we remodeled over a 3 year span. Momma really likes it when the kitchen gets done.
Old 11-25-2008, 06:04 AM   #264
vtblazer
vtblazer's Avatar
Leaving it 'natural' as in pretty much the way it sits.
Should be quite the conversation piece, ya think?
Old 11-25-2008, 08:53 AM   #265
Big J
Its lookin' like a Blazer!
Big J's Avatar
Conversation piece... I'd toss a trolley and chain hoist on it. Tell people ya use it to drop small blocks in the dishwasher for degreasin'.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-25-2008, 09:03 AM   #266
Chevyman63
Chevyman63's Avatar
Now that's a good idea!!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-25-2008, 09:22 AM   #267
vtblazer
vtblazer's Avatar
...wonder if she'd let me.
Old 11-25-2008, 02:19 PM   #268
Big J
Big J's Avatar
I doubt it but she probably would like it if you welded up some kind of cool pot & utensil rack to mount to it. Maybe in the shape of a bowtie
BAZINGA!
My Build
Old 11-26-2008, 08:32 AM   #269
vtblazer
vtblazer's Avatar
Done in time for turkey day.
It's a huge mess still but all the cabinets are done/installed.
Now it's her turn...
The kitchen will not see me again until my garage is insulated!
Once insulated, on comes the heat and on goes the POR...dammit.
Old 11-26-2008, 08:41 AM   #270
Chevyman63
Chevyman63's Avatar
Bring on the POR!!!
Wow...check out the cat's eyes in the first of those 2 pics.
BTW, the cabinets look good.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-28-2008, 01:27 PM   #271
vtblazer
vtblazer's Avatar
Day of testing...
- how it will hold heat now that's it's mostly insulated
- how is this POR stuff gonna work in a semi cool garage
- how much meatl clean up does the POR take
- how much smell gets into the house when I'm using it
Good news all around.
- was able to work in the garge just wearing a t-shirt
- to my surprise, I thought the POR was really decent to work with
- a good scuffing with the Scotch-Brite pad took care of it
- went inside when I had painted for around 45 minutes to ask the wife if the smell came into the house and her answer was 'what smell'
Old 11-28-2008, 01:43 PM   #272
glimmertwin01
glimmertwin01's Avatar
nice job.. props on both projects We will have to call you Tim the tool man taylor... grunt grunt...
Ive used POR for yrs good schtuff! just make sure to wear tyvek coveralls and good latex gloves wommen dont like men with dirty paws.... I wish my frame was that clean but then the 50 mils of grease on the bottom of the truck/ frame is probably why it is still solid...
I was blessed with an insulated well lit man cave when i bought this place.. (one of the main selling ponts) i fire up the 100,000 BTU salamander for 15 min and its toasty for hours
NICE now if i could only get ALL of my neighbors to appreciate old chevy IRON!
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 11-28-2008, 01:51 PM   #273
jaros44sr
jaros44sr's Avatar
Nice, now all three of you guys have shiny black frames. Cool on the teeshirt and no fumes in the house. I have problems w/fumes and can't fix it
That stuff looks like it really went on nice, does it stick to your skin
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-28-2008, 03:35 PM   #274
vtblazer
vtblazer's Avatar
Not shiny, should dry to a satin kinda finish, almost wish I'd gone with glossy though cause it looks really nice right now.
Stick to skin? Yeah, says right on the lable that if it dries, the only way it's gonna come off is with time.
60% done, I'll let what's done dry a couple days and reinstall the body mounts and front axle, then finish up the rear section and repaint around the mounts.
Old 11-28-2008, 03:42 PM   #275
jaros44sr
jaros44sr's Avatar
Stick to skin? Yeah, says right on the label that if it dries, the only way it's gonna come off is with time.
That's about as taken apart as possible, all down hill from here...looks good tho. How does it fill in any pitted area
SAFETY FIRST
AS usual, off topic
Jim
