Old 03-16-2009, 10:47 AM   #1
heyjoe
Tire size for H2 rims on stock height c20
Anyone run H2 rims on their 2 wheel drive truck? What tire size are you using?
I have a '67 c20 Fleetside that is stock height. I have a set of the H2's and I have read that the rims will work, but I need a useful recommendation on tire size.
I have done searches on this forum and Google 'til I'm blue-in-the-face but have not found anything definitive. I have trial fitted the H2 rims on the truck and have measured and plotted and figured, but cannot come up with an answer on tire size that would make me comfortable to pull the trigger on buying tires. If I have to use spacers.. so be it.
At present, I am feeling very stymied in my efforts.
Again, anybody run H2s on their stock height, 2 wheel drive C20 Fleetside?
If so, what tires are you using?
heyjoe is offline   Reply With Quote
Old 03-16-2009, 11:43 AM   #2
jb4short
Damn Yankee
jb4short's Avatar
Re: Tire size for H2 rims on stock height c20
I have a '67 c20 that is stock height. I have a set of the H2's and I have read that the rims will work, but I need a useful recommendation on tire size.
Again, anybody run H2s on their stock height, 2 wheel drive C20?
Which H2 rim? 17" or 20"
jb4short is offline   Reply With Quote
Old 03-16-2009, 02:30 PM   #3
texanidiot25
Eat My Rust
texanidiot25's Avatar
Stock hummer wheels won't fit with out spacers in back, and probably up front, with the hub hole on the rims machined out.
texanidiot25 is offline   Reply With Quote
Old 03-16-2009, 10:37 PM   #4
heyjoe
Tri-Pro
We're talking about 17"
The rims measure 17x8-1/2 with approx. 5-9/16backspace, the total rim width is 10" measuring from outside of flange to outside of flange.
I have 1-1/2" clearance between edge of rim to edge of of bed/tub.
This is a Fleetside, by the way.
Texanidiot
I can see the possibility of needing spacers for tire clearance if the tire section width turns out to be much more then 10".
The hub holes are actually oversize for the hub - they won't need to be machined out
Old 03-16-2009, 10:39 PM   #5
texanidiot25
Eat My Rust
Strange,the H2 must have a larger hub hole then the other GM wheels. Any other GM truck wheel won't fit with out work. Hummer must use some different dimensions..
Old 03-17-2009, 06:17 AM   #6
Blazer1970
Blazer1970's Avatar
No, the 8 lug wheels all have the same size hole. The problem you are thinking of is with new 6 lug wheels.
265/70R17 is about a 31 inch tire and should fit I would think.
Blazer1970 is offline   Reply With Quote
Old 03-17-2009, 08:02 PM   #7
heyjoe
Yeah I'm currently running 8.00x17.5 bias plys 30.8" tall - don't want anything shorter. A 31" tire would be good. Gonna need spacers to run that 265 section width.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
Old 03-17-2009, 08:10 PM   #8
Blazer1970
Blazer1970's Avatar
I don't think you would need any spacers.
Old 03-17-2009, 08:46 PM   #9
heyjoe
After looking at some tire specs for that size, looks like I may have 1/2" inboard clearance on the rear if I'm lucky.
I'm open to all suggestions.
Old 03-17-2009, 11:16 PM   #10
pmpski_1
pmpski_1's Avatar
Take a good guess and see if you can get a local tire shop to mount some different sizes of used throw away tires. Take them home, put them on the truck, measure for clearance.
pmpski_1 is offline   Reply With Quote
c20, h2 wheels, rims, tire size
