#51 |
Re: LFD's XXL DropMember I6 Install
Kevin, are the tires turned to full lock in those pictures? Is that with it sitting on the ground or raised a inch or two?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#52 | |
![]() Last edited by 68 short step; 04-19-2009 at 09:48 PM. |
#53 |
Nope, no DM... Yet. I have a feeling my Blazer will get the C4 or maybe a C5, C6 or even a C7 by the time I get around to building that one.
#54 |
Nope it is layed out with the tires almost lock to lock. The pics are deceiving as far as the rack and arms looking level. This truck would sit lower if my shop floor was not so high
![]() I do own a DM C4 and it should be here this week for my Tahoe ![]() Kevin LFD Inc. Last edited by Rokcrln; 04-19-2009 at 10:20 PM. |
#55 |
wow!
so how much narrower is the track width with the DropMember?
#56 |
#57 |
very nice!
#58 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#59 |
Floor is all finished just waiting for the seam sealer to dry so I can touch up the paint. The PS line kit I ordered did not work so my Local Napa guy is taking care of that for me.
I will start the bed work on Tuesday. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() |
#60 | |
A guy with a truck
-The the inner fenders are trimmed -The firewall is tubbed -He is running a small diameter tire (compared to 20s) Your average DM install won't do that- at least mine doesn't ![]() Are you finishing the sheetmetal work that was started? I have been anticipating the completion of that for a while. Very slick, unique ideas he had for the stepper...
#61 |
#62 |
Under Construction
looking good Kevin.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#63 | |
Señor Member
![]() Thanks. I'm trying to juggle the truck back into the dd rotation for a few weeks so I can finish some mods on my real dd. As a result, I've only asked Kevin to do a couple of things in the bed. Once I get some more time to get the truck back to him, I'll be coaxing him to do some more fun things to the truck.
#64 |
VA72C10
![]() Join Date: Mar 2008
[QUOTE=XXL;3270101Once I get some more time to get the truck back to him, I'll be coaxing him to do some more fun things to the truck.[/QUOTE]
I'm sure $$$ it won't $$$ take too $$$ much to $$$ coax $$$ him to $$$ work on $$$ your truck $$$ ![]() ![]() ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#65 | |
Señor Member
![]() BTW, he's worth what he charges... but don't tell him that. I'm trying to dicker down.
#66 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Well ken I for one am glad you decided to go with kevin and knowing that its getting done and done right has got to let ya sleep well at night unlike an un named body guy..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#67 |
I put the seat back in and closed the cab door for the last time! Only part left of the DM install is the PS lines, my guy came bu tonight and did a few mock ups but I was not happy with what he had so we will try again tomorrow night. I am wanting a clean simple look without a bunch of adapters if at all possible. That tunned is about 1/4" clear of the seat and looks really good.
I started on the bed tonight with panels I had my sheet metal shop brake up for me to Kens specs. He wants the top rails of all 4 sides the same and now they are! I will finish weld them up in the next day or so then spray on a coat of epoxy. First thing I did was trim the panels since I had them made 1/4" long so I could trim to fit. Then I cut two flat pieces to weld in the floor to seal off the chamber once the panels go in. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#68 |
Almost ready to send home!
Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#69 |
I like it!!
#70 |
All finished, I will do a shack down inspection Friday night then a test drive Saturday morning. I shot a coat of DP90LF on the bare steel and shot the inner sides as well since they were bare.
#71 |
looks good kevin, now i want a dropmember, oh well, i can always add it later.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#72 |
Life, Be In It.....
![]() Join Date: Oct 2003
It is coming together nicely. Where did you put the "LFD" tag?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#73 |
![]() Join Date: Apr 2004
Nice progress Kevin, are you planning on coming to the get together tomorrow?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#74 |
THE VILLIAGE IDIOT
another great job kevin.. if i ever hit the lottery your the first on my list to work on somthign i will buy then..lol
honestly honey,,i have no idea how that truck got here. ![]() |
#75 |
I see this vehicle every day when I'm working.
-Scott- |
