Old 06-06-2009, 12:52 PM   #1
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
poor acceleration
I am a new member, so sorry if this has been answered already. I just got a 72 C-10 short steper. It has a 350 with comp hooker headers and a Eldebrock 1406 carb, it also has Weber stamped on the right side. Other then that it is stock. The problem I am having, when I step on it, it hesitates and I can hear a pop coming from the front, not really a back fire. Is there a simple adjustment I can make to the carb to fix this. I have changed the inline filter right before the carb, is there an other carb closer to the tank that I can change as well.
Thanks for the help.
Josh.
gonzo6869 is offline   Reply With Quote
Old 06-06-2009, 05:09 PM   #2
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Re: poor acceleration
sounds maybe like the accelerator pump is out of it.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-06-2009, 05:40 PM   #3
gonzo6869
gonzo6869's Avatar
Thanks I will check that out.
Old 06-06-2009, 05:43 PM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
definatly start with tuning the carb and checking you ignition timing.
how are your plugs?
wires?
also the pickup screen in the tank could be all gummed up, maybe the sender..
i would start with the carb tho and changle all the fuel filters.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 06-06-2009, 06:56 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
There is also a fuel filter(unless it has been removed) in the carb behind the fitting where the fuel line goes in.It may be clogged or partially clogged.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-06-2009, 07:42 PM   #6
Hoffman65burb
Hoffman65burb's Avatar
im with Bagndragit, check timing and tune the carb. My 69 shorty did that, i was only a few degrees off.
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 06-08-2009, 12:56 AM   #7
gonzo6869
gonzo6869's Avatar
meant to ask if there is a second filter closer to the tank, not a carb.
Old 06-08-2009, 08:41 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
Originally these trucks came with one fuel filter and that was in the carb, but over the years owners have added a second and maybe third one.
Normally if one is added it is between the pump and carb, but if the tank is expected to be dirty another one may be added between the tank and the pump.
Also start at the tank and check all the rubber hoses for cracking or kinking.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
carb, filter
