09-21-2009, 08:49 PM | #1 |
someday
blazer project
I have had this blazer since 2002. its a 72 cst with factory tilt and a/c. It has been apart for 2 or 3 years and i'm finally gettting motivated and getting stuff done. I am currently filling and sanding the body to prep for paint. these two pics are what it looked like when i first got it.
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
09-21-2009, 08:55 PM | #2 |
someday
Re: blazer project
here is the frame before
09-21-2009, 08:59 PM | #3 |
someday
Re: blazer project
for some reason i dont have any pics of the process in between. I sandblasted, primed, and painted the frame cleaned the engine, trans, and transfer case and painted them. Added a poly tank, stainless brakelines, and some stainless hardware.
09-21-2009, 09:02 PM | #4 |
someday
Re: blazer project
now i am working on the tub. It was covered in this thick clay like dirt and undercoating on the bottom so i scraped it off with a scraper.
09-21-2009, 09:04 PM | #5 |
someday
Re: blazer project
next i sandblasted the whole thing.
09-21-2009, 09:09 PM | #6 |
someday
Re: blazer project
I replaced the inner rockers, front floor supports, lower a pillars, rockers, and front quarter panels. I also had to fabricate lower b pillars and repair that rocker box tie in brace thingy.
09-21-2009, 10:07 PM | #7 |
Re: blazer project
keep em coming
09-21-2009, 10:26 PM | #8 |
Re: blazer project
09-22-2009, 06:11 PM | #9 |
someday
Re: blazer project
I know everyone loves pics but i havent taken alot of them. I forgot this one of the bottom of the tub after paint. I will try to get more of the body work progress.
09-22-2009, 09:21 PM | #10 |
Junior Member
Re: blazer project
Nice work. Keep the pics coming!
1967 Camaro (in pieces) 1972 Chevrolet K/5 Blazer 1969 Chevrolet K/5 Blazer 2000 Chevrolet K2500 Crew Cab 454 1999 Chevrolet Blazer 2008 Polaris Ranger XP Orange Crush |
08-29-2010, 06:55 PM | #11 |
someday
Re: blazer project
still working on the blazer. I havent been good at keeping this up to date so i'll post up the few pictures i have taken.
I discover that inside the cowl area was more rotted that i originally thougt so i cut all the spot welds and did some repair. Also this water diversion channel was toast so i fabed up some new pieces and painted the whole thing while it was apart. I dont have any shots of it painted though(i tend to get working and forget pics)
08-29-2010, 06:59 PM | #12 |
someday
Re: blazer project
after the cowl was finished id assembled everthing. I had to do some mods to the new femder on the drivers side it didnt match the curve of the door. also i had to enlarge the holes in the radiator support and the grill because the holes did not line up with the repop fenders.
08-29-2010, 07:01 PM | #13 |
someday
Re: blazer project
I also sprayed al's liner on the inside of the tub. It went on easy and looks good.
08-29-2010, 07:05 PM | #14 |
someday
Re: blazer project
next i have to replace the inner door bottoms. on the first spot weld slip goes the cutter and now its gonna go real slow. I have a pic of the wound uncovered but its pretty ugly. I have to see and orthopedic this week hopefully everthing is good.
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff Last edited by blue_69; 08-29-2010 at 07:06 PM. |
09-23-2010, 09:32 PM | #15 |
someday
Re: blazer project
My self inflicted wound has pretty much healed and have gotten some work done as a result. I replaced the inner door bottoms. The patch pannel for these fit poorly. It took lots of work to get everthing to line up right.
09-23-2010, 09:35 PM | #16 |
Grandpa in the rustmobile...
Re: blazer project
wow man looks good that may look like a little work to some but thats WORK!
keep at it hang in there your really comming along!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-24-2010, 07:19 AM | #17 |
Re: blazer project
It's starting to shape up! Can't wait to see more.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
09-24-2010, 10:02 AM | #18 |
Re: blazer project
Going to be a sweet blazer! Keep it up!
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
09-24-2010, 10:42 AM | #19 |
Re: blazer project
What are you doing to prevent damage to the body panels when you tip the body on it's side to work on the undercarriage? Seems like a good way to get access if it doesn't do the body panels harm.
Good looking truck and good progress! |
09-24-2010, 06:54 PM | #20 |
someday
Re: blazer project
Wanderlusty: I got the idea from a pic i saw one here. Its so simple and works great its just 2 peices of box tubing welded in a "L" shape with some exhaust tubing welded to the top to even out the spacing between the dolly's and the tub. I used a cherry picker to tip it up and put a strap on top to make sure it didnt tip to fast once it got over the center of gravity. I'll try to remember to get better pics for ya but they are on the tub in this pic also you can see the nylon strap on the top.
09-24-2010, 07:00 PM | #21 |
someday
Re: blazer project
oldblue1968chevy, 1956cameo, splehigh, Wanderlusty thanks for the encouragement! I'm terribly slow at bodywork and i dont really like it so its taking me forever so the kind words help alot.
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff Last edited by blue_69; 09-24-2010 at 07:01 PM. |
10-23-2010, 08:41 AM | #22 |
someday
Re: blazer project
still chugging along on the blazer project. I'm trying to get all the big parts painted before the snow flies. Painted the dash and inside of the windshield frame earlier this month. Next i sanded off the rattle can primer i was using to keep it from rusting while i worked and put on etch primer and epoxy sealer. Then my girlfriend and I built this paint booth out of plastic.
10-23-2010, 08:49 AM | #23 |
someday
Re: blazer project
Finally put some color on this thing last weekend. I put it on the frame and pushed it outside yesterday, It's been 4+ years since the tub has been on the frame. I need to wetsand and buff the clear its got some orange peel but overall i'm happy. Now off to work so i can get the doors, fenders, and other bits painted.
10-23-2010, 10:37 AM | #24 |
2WD Jimmy
Re: blazer project
Awesome.
03-10-2011, 01:55 AM | #25 |
Re: blazer project
any updates awesome start
