Old 10-29-2009, 09:16 PM   #101
jaros44sr
jaros44sr's Avatar
Re: Project Blaz-Air
Sorry, lost track of your build, but now I can follow along again...guess I got wrapped up in my own!
Really nice work, combination of LS2, tranny, and those wheels are killer! Should be a great look when done. I'm subscribed
Dam PO's, what are they thinking, patches over rust!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-06-2009, 12:09 AM   #102
b4psi
Nice lookin work. Did you know porterbuilt makes a rear clip for these trucks?
b4psi is offline   Reply With Quote
Old 11-06-2009, 02:32 PM   #103
1sik52
Blazer frame is different than the truck frame
1sik52 is offline   Reply With Quote
Old 11-07-2009, 06:45 AM   #104
OARNGESI
OARNGESI's Avatar
Not sure but dont you have to raise the motor in a converted 4x4 did they make you taller motor mounts for your dropmember
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-07-2009, 04:33 PM   #105
1sik52
No, usually when converting a 4wd frame to a 2wd you move the engine forward. The dropmember puts the engine in the correct position.
Old 11-18-2009, 10:06 PM   #106
1sik52
Got some more work done to the driver side floor pan today and also picked up some new bed sides to cut down and replace the old ones.
Old 11-18-2009, 10:30 PM   #107
mcbassin
Still Learning
mcbassin's Avatar
Your metal work looks great! Nice score on the bed sides! Keep it up.
Old 11-18-2009, 11:18 PM   #108
Nobby
Nobby's Avatar
Man now that brings back memories.Looking good!!
Nobby is offline   Reply With Quote
Old 11-18-2009, 11:46 PM   #109
Rokcrln
Rokcrln's Avatar
You are doing a fantastic job on this build, keep it up.
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 11-19-2009, 03:04 AM   #110
VA72C10
VA72C10
VA72C10's Avatar
with everyone...keep up the good work and progress!
Old 11-19-2009, 09:39 AM   #111
1sik52
Thanks everyone for the comments. Once I get rid of the rust and get to start doing my custom mods then I will feel like I am getting somewhere!
Old 11-19-2009, 09:58 PM   #112
67_ShortFleet
67_ShortFleet's Avatar
Nice work! I having similar fun with a 67 sb. Could post a picture of the boyds? Do you know what style they are also?
67_ShortFleet is offline   Reply With Quote
Old 11-19-2009, 11:08 PM   #113
1sik52
They are sold.
Old 12-09-2009, 08:53 PM   #114
1sik52
Now that the floor is finished I jumped on the firewall today.
Old 12-09-2009, 09:11 PM   #115
mcbassin
Still Learning
mcbassin's Avatar
great progress on the firewall! It looks very similar to what I am doing on our 69.
Old 12-09-2009, 10:12 PM   #116
Nice work Greg!
Old 12-09-2009, 10:24 PM   #117
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 12-09-2009, 10:42 PM   #118
1sik52
Thanks, I got a couple tricks up my sleeve that will make it totally different than any other firewall out there. Will have pics of what I am talking about here in a couple of days.
Old 12-10-2009, 02:30 AM   #119
PHAT TONY
PHAT TONY's Avatar
Looking good, I guess being a previous 4x4 helps with rear tire clearance, no? The frame is narrower above the diff. What color shall it be?
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-10-2009, 09:16 AM   #120
1sik52
I wish it did. But going with 22x12 I have to narrow the rear 3 1/2 - 4 inches on each side.
Old 12-11-2009, 12:40 AM   #121
PHAT TONY
PHAT TONY's Avatar
You need to narrow the frame 4" on each side? Must be alot of backspace in those rims! Worked on mine a little lately, need to update my build thread. Keep goin man!!
1972 K10 4X4-Sold
Old 12-11-2009, 09:07 AM   #122
idonutn0
I have a quick welding question for you.
How are you filling in those huge gaps without burning through the metal? Are you using copper behind it to catch the weld?? Im having issues with burn-through and getting good penetration and could use some advice.
Please keep up the good work, This is a very inspiring project.
Thanks for you time.
idonutn0 is offline   Reply With Quote
Old 12-11-2009, 10:56 AM   #123
1sik52
No, Not the frame. Im narrowing the rearend. There is plenty of room with the frame.
Im not sure what huge gaps you are referring to. The metal is closer than you think. Im not using anything behind the welds. Sounds like maybe you need to turn the heat down on your welder some.
Old 12-11-2009, 11:27 AM   #124
67cheby
67cheby
67cheby's Avatar
looking killer those wheels are sweet, i want some billet wheels bad !!but i guess mine will work for a while i want to get it painted then i will worry about switching wheels!! it amazing how much more expensive the billet ones are
67cheby is offline   Reply With Quote
Old 12-12-2009, 10:03 PM   #125
1sik52
Ran out of gas on my welder so couldnt finish it up but you can get the idea of what I am doing. I am making the drivers side of the firewall match the passenger side by shaving the area where the wiring harness, emerg brake, etc.... used to be. When I get more gas monday I will finish it up and get more pics
