Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-27-2009, 12:47 AM   #151
jojo
printing is my trade
jojo's Avatar
Re: AJ's '72 Cruiser Crawler Build
That motor's lookin real good!
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 09-27-2009, 09:54 PM   #152
AJs72K5
AJs72K5's Avatar
UPDATE 9/27/09: Bottom end complete. Put the new cam in today. Degreed it with the new timing chain, which is cool btw because the timing is spot on with the grind sheet. The cam ended up advanced 3*. Dropped in the new lifters, and closed up the bottom end. Oil pan is bolted down as is the timing cover. We woulda finished the motor, but my friend forgot the adjustable pushrod to measure with...so no pushrods yet. Loaded it up on a trailer and took it back to the shop.
The adjustable timing chain. It's also got a bearing built into the back side so's it won't eat up the block like the last one did
Roller lifters. SEXY!
This was supposed to be the picture of the engine loaded up on the trailer to head back to the shop...but I forgot. So, imagine it looking just like this, but with a motor on a stand and strapped down.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 09-27-2009, 10:12 PM   #153
BLUE THUNDER
BLUE THUNDER's Avatar
I can see it now.
BLUE THUNDER is offline   Reply With Quote
Old 09-27-2009, 10:16 PM   #154
Bentblazer
Bentblazer's Avatar
You must have painted it camo
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 09-28-2009, 09:36 AM   #155
Yukon Jack
Yukon Jack's Avatar
Sweet progress!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-30-2009, 06:56 PM   #156
Jtrux
I'm a poor spectator
Jtrux's Avatar
Nice updates AJ but there's one thing I noticed. I think the computer program you inputed your data into may be a little bit off. It seems to me you're trying to go for a bit of a hotrod and I think you would of benefited from a larger cam. The one you've chosen is just a step above stock, an RV cam if you will. The heads and intake combo you have is great and all but I don't think you'll really be reaping the benefits of them with that cam. You will make good torque (~400tq) but I think the hp will be lacking and not quite what you're looking for (~325HP OR SO). I'm not an expert by any means but I worked at a machine shop several years ago for a while and i've had my hands on quite a few other engine builds so I do have an idea. I really like the Comp Cams Extreme Energy series and I think if you go went with one of those cams you would get some of the performance I think you're after. The only reason i'm making this suggestion is because I don't want you to get this thing together and installed and realize you shoulda gone bigger. Hope you don't feel i'm stepping on your toes, just trying to offer some pointers.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-30-2009, 07:17 PM   #157
AJs72K5
AJs72K5's Avatar
No harm done. Nothing has been inputed wrong into the CamQuest app. The cam I went with, while appearing somewhat mild, is also EFI friendly, which is important. A bigger EFI friendly cam would've required me to go with a Lunati that was a bit too big in my opinion. We'll see how it turns out.
- AJ
Old 09-30-2009, 07:41 PM   #158
72Levi
Active Member
72Levi's Avatar
520hp and 580tq? What compression are you running with the EFI? Are you going to get it dynoed in SA when you are finished?
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum
2004 FORD FX4 SuperCrew
2005 CTS-V 12 sec family car
2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it!
72Levi is offline   Reply With Quote
Old 09-30-2009, 07:50 PM   #159
AJs72K5
AJs72K5's Avatar
If Keith Black's compression calculator is correct, I should end up right around 9.9:1. I'll probably get it dyno'd to dial in the final tuning of the EFI.
- AJ
Old 10-01-2009, 07:59 PM   #160
Jtrux
Jtrux's Avatar
That's awesome, I've always wanted to throw one of my engines on a dyno, you'll have to let us know how it goes.
Old 10-01-2009, 08:51 PM   #161
72Levi
Active Member
72Levi's Avatar
NICE! Let us San Antonio guys know which dyno place is a good one in SA.
Old 11-16-2009, 06:26 PM   #162
AJs72K5
AJs72K5's Avatar
Not a whole lot going on right now. At home recovering from surgery to correct a deviated septum. But I did pick this up... reconditioned tilt column with new levers.
- AJ
Old 11-16-2009, 08:54 PM   #163
Jtrux
Jtrux's Avatar
Nothing like some good ole rhinoplasty to get things straight! lol Let's see some motor updates!
Old 11-23-2009, 08:19 PM   #164
AJs72K5
AJs72K5's Avatar
UPDATE 11/23/09: Septoplasty recovery. I took all of last week off to recover from surgery. By Wednesday, boredom had set in. By Friday, my wife ordered me to the shop to get out of the house...like I was gonna argue.
So...I took it fairly easy and painted the block, upgraded my seriously wimpy bumpstops, pulled the old steering column out, and removed the floor shifter. Hey, anything is progress at this point, right?
Block all masked off...its like turning a 4 year old loose to wrap Xmas presents. Masking pic just for you Kurt
Three coats of Duplicolor High Temp Engine paint red later. Much better than the previous block's purple, I think.
Bumpstops.
more to come...
- AJ
Old 11-23-2009, 08:50 PM   #165
Critter
Future TOTM Winner
Critter's Avatar
Good progress if you ask me. Nothing better than a freshly painted engine. The bump stops looked pretty beefy, I like them. Glad to here you are recovering nicely.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-03-2009, 10:39 PM   #166
AJs72K5
AJs72K5's Avatar
Manged to get off work early today and made a little more progress on the engine.
Measured up a set of pushrods...they're on order now. Then pulled the timing cover back off to put a cam button on. Turns out they're kinda optional on a flat tappet cam. However, required on a roller cam.
After that, the balancer on went on...fighting every inch of the way.
Then started to test fit the new headers. I ordered a set of Hooker Comp 2455s. They're for a 1972 Chevelle and are supposed to fit well. However, I ran into several clearance issues on the DIY4x crossmember. I may need to go back to the factory crossmember. I chucked the old one a while back cuz the PO had mangled it up getting the old engine in. Need to find a factory crossmember...
New cam button
- AJ
Old 12-03-2009, 10:45 PM   #167
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Nice job AJ...lookin good!!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 12-04-2009, 12:09 AM   #168
jaros44sr
jaros44sr's Avatar
Engine looks great, really like the flat black look. How about exhaust manifolds instead of headers. You must just be itching to get that engine back in. Are the small block and big block cross members the same???
Liking the bump stops also, where did you find them?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-04-2009, 12:42 AM   #169
AJs72K5
AJs72K5's Avatar
Yeah, I'm dying to make some significant progress. With the engine I built, exhaust manifolds will constipate it bad. I need something with more flowwwww. Hence the headers with 2" primaries and 3.5" collectors.
It had a small block crossmember in it before. I know there are different engine stands, but the crossmember itself is the same. I'm gonna hit the local PickNPull this weekend to see if I can find one.
I bought the bumpstops from a member on another board. We haven't figured out what kind they are yet.
And to answer your question from before, no, a big block does not use a thrust bearing behind the timing chain. You can put a wear plate and thrust bearing behind it if the timing chain has chewed up the block like my old one did. But you need to mill the surface flat first.
- AJ
Old 12-04-2009, 02:01 AM   #170
jaros44sr
jaros44sr's Avatar
Ok. thanks for the answer, I have to order a .31 shim or wear plate from Cloyes to move my timing chain spocket away from the block. Didn't really want to grind the block...I have a cam button on my cover but I have to set it loose, can't figure out how to machine my block for the torrington bearing with engine in the truck. I was considering a magnetic base drill with an end mill chucked up in it, but that could get ugly in a hurry
If you can't find one in the junkyard and want to pay shipping, there's one in my basement. I even degreased and painted for ya. Sorry ya can't use the DIY. If ya ever figure out where that bump stop came from LMK
Shame we don't all live on the same block
SAFETY FIRST
AS usual, off topic
Jim
Old 12-04-2009, 06:37 AM   #171
vtblazer
vtblazer's Avatar
Have one here, could just make a bigger box and throw it in with the tranny tunnel.
vtblazer is offline   Reply With Quote
Old 12-04-2009, 08:53 AM   #172
Jtrux
Jtrux's Avatar
I'll trade you mine for your DIY
Old 12-04-2009, 09:43 AM   #173
AJs72K5
AJs72K5's Avatar
If I can't find one local, I'll let you guys know. Thanks!
Not ready to give up on the DIY crossmember yet. I want to get a factory one to see how it fits and weigh my options.
- AJ
Old 12-04-2009, 11:04 AM   #174
Burt4x4
Burt4x4's Avatar
passenger side looking forward.
That is a 73+ 3-piece, in the pic you can only see the frame mount and the ORD engine mount. I can't locate a pic of the actual crossmember but you may recal I used ORD's crossmember and it fits but hella tight and about 1/8" away from the pan. Butt! My engine does not move, no shaking just solid.
Anyway just keeping your mind busy
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-04-2009, 01:18 PM   #175
jaros44sr
jaros44sr's Avatar
Ah, another part to the puzzle is answered...good one Burt
SAFETY FIRST
AS usual, off topic
Jim
