60-66 full body wiring
OK,here goes.I hope this helps and I hope I can get them in good ledgible order.
Re: 60-66 full body wiring
Here are a couple more that might help.
Well thats it hope these help.
Why does the horn need a wire? it has a rubber bulb
![]() Sorry I am that kind of mood. Looks good to me and I am sure it will help alot of people. |
If you take apart the horn button there is a contact that is engaged when you press on the horn.What you are actually doing is sending a ground signal to your horn relay coil which has power at it and to one side of contact.When ground signal makes it to the coil at horn relay it engages and closes contact to provide 12v to your horn.Thus giving you the beep beep sound.I hope this makes sense.
#6 | |
I am sorry. I was just making fun of the little horn in the diagram. It looks like a bicycle horn to me. I will go home now. Stay warm |
its all about the +6 inches
looks great! thanks.
FAQ thread here! |
and a few others
I have a bunch more, just can't find them right now....
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Does anyone have more wireing diagrams for 65?
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
tag
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's the engine, cab, and, tail section.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks guys! These look like they'll work. Just sat down and went thru a harnesses for 68 and labelled everything. Now to move onto the 60.
68 Short stepper...(current project, in pieces) 60 Apache 10, short stepper (next project; photo link http://67-72chevytrucks.com/gallery/showgallery.php) 68 LWB fleet, 305 (runs great but rusty...to be parted) 89 GMC K2500 (wood hauler, truck & spare parts picker upper) 02 Dodge Intrepid (daily driver...lol, in all fairness tho it has hauled it's share of parts) |
#14 | |
where did you get the wiring diagram from? What book? How much was it? Any info would be great i would like to buy it. Thank you!
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#15 |
![]() Join Date: Feb 2012
i love it
#16 |
Java Mechanic
Moving this up into the stickies.
Thanks for the input. ![]()
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#17 |
these are awesome and easy to copy and paste onto 11x17 for good use
#18 |
. OK this is what I'm doing i just bought a new stock under the dash fues box with gages .I already have the harness for the gage cluster. What do i.need to do before i take out the old one?And what do i need to do for the new one. Does the.new one plug into the other stock harness?
Posted via Mobile Device Posted via Mobile Device |
#19 |
Awesome! Thanks for sharing!
#20 |
![]() Join Date: Jan 2014
anyway you can email these to me in an attachement. Thanks in advance
barney |
#21 |
I copied them to a flash drive then went to the local FedEx/Kinkos and had them printed on 11 x 17 heavy stock. It cost less than $7.00, is easy on the eyes and will last for years.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#22 |
Thanks 65Gregg!
#23 |
Which harness is easiest in doing a complete re-wire? Painless? or 1966 CHEVROLET C10 PICKUP American Autowire Classic Update Series Wiring Harness Kits 500560
#24 |
Most of the original wiring was missing on my truck. It had been sitting in a field for 30 years or so. If you are going to use the stock dist. with points and don't have or can't find resister wire, this may help. I had trouble figuring out the wiring for the start/run circuit going to the points. The wire is not on the diagram above. As I understand it, the truck came with resistor wire going to the points during run so they would last longer. After much research on my part and the help of my Dad, (he was a mechanic when the truck was new); this is what we came up with.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. Last edited by ljackson; 01-30-2014 at 05:16 PM. |
#25 |
Looking for some help!
I have a 64 C20 with rear light issues. I have turn signals but no brakes, running lights. Also, I have no interior dome light, but gas indicator works. I have replaced just about everything with no luck. Starting at the back, new bulbs, new wiring harness all the way to the front, new brake light switch, new dome light and wiring, new director signal connector in the steering wheel. The onyl place I can see on the wiring diagram where dome light and rear lights meet is in the light switch connector. I am not sure what/where that is or even what it looks like????? Anyone out there got any ideas? I am stumped!! THANKS |
Tags |
wiring |
