01-11-2010, 02:47 PM | #1 |
chopped x member!
got it put in this weekend! top picture is before and the next one is after...it is perfect! sits aired out with just a little rake to it!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
01-11-2010, 03:50 PM | #2 |
Re: chopped x member!
Looks good!
01-11-2010, 04:20 PM | #3 |
thats awesome!
01-11-2010, 04:33 PM | #4 |
it was an easy swap, the steering issues are the only real prob, i may swap to a rack setup anyway.
01-11-2010, 09:22 PM | #5 |
Low & Fast!
Man that thing looks sick! Do you have any pics of what you did to it? and did you cut the floor out in the back for the C?
01-11-2010, 11:57 PM | #6 |
Yea I will post some tomorrow of what I did, I did not cut into the interior at all,it is all under stock floor
01-12-2010, 12:02 AM | #7 |
67-72 parts collector,…
Subscribing,...
It just keeps getting better. |
01-12-2010, 12:09 AM | #8 |
It followed me home?
sits perfect, makes me want a suburban
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-12-2010, 12:18 AM | #9 |
makes me want one too!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
01-12-2010, 11:38 PM | #10 |
Truck Nut
*****in!!!!!
Tony Kee Texas Square Bodies |
01-13-2010, 12:17 AM | #11 |
did you swap the crossmember and just raise the engine up with a hoist? Kick azz burb, i'll be tearing into mine soon.
01-13-2010, 01:03 AM | #12 |
You do not have to remove the engine at all, if you look at the frame mounts for the engine, there are two bolts on the top of the frame leave those hooked up and you can remove the x member, you just remove the bolts from the bottom of the bracket that bolts to the x member and when you slide the member back in the holes should line back up.... I had to drill my back 2 out just a little.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 Last edited by justpball; 01-13-2010 at 01:09 AM. |
01-13-2010, 11:52 AM | #13 |
as promised here are some pics of the work...
01-13-2010, 12:32 PM | #14 |
Redefining LowBudget
Ummmm wait!!! you rock!!! I finally see how these DM's are cut....hmmmmmm...I can do that and I have a spare X memeber...nice work any hints
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-13-2010, 01:47 PM | #15 |
Low & Fast!
Nice jod! This has me thinking now and thats not good..
01-13-2010, 01:50 PM | #16 |
yea having a spare xmember is nice, thats what I did, got it all ready to go in then just pulled mine and put the chopped one in. took about 6hrs...
01-13-2010, 05:47 PM | #17 |
Nice work bro! I need to make that short drive over and say hey! Still working on getting my parts together. How did the steering go back together?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
01-13-2010, 07:03 PM | #18 |
good it was not hard at all, got it all back together. Working on the inter fenders and i think i am close to being done for now...yea right. I am going to take it over to the bay front, and the burger king on 9mile soon.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 Last edited by justpball; 01-15-2010 at 06:48 PM. |
01-13-2010, 07:26 PM | #19 |
so you didnt cut the rear floor, how did you run your bags and lines?
Also are those 20s or 22s? |
01-13-2010, 08:02 PM | #20 |
how about a pic of the steering shaft issue....
01-14-2010, 10:40 AM | #21 |
here is the steering stuff...
and here is what i did.
01-14-2010, 12:32 PM | #22 |
Nice!! my thoughts exactly....I would even consider a small c notch in the a arm..yea I know let the flaming begin!!
01-14-2010, 04:31 PM | #23 |
^yea I thought about that, but had the other stuff laying around so just used it...LOL
stevieb I didnt cut the rear floor at all but, I am going to have to to get it any lower. I will take some pics tonight of my rear setup.
01-14-2010, 04:40 PM | #24 |
Cool thanks, I'm just racking my brain about what to do, so far what I have going on is gonna be...
adjustable behind the axle bag mounts with top cross bar mounts. 4 link with the top bars attached to the frame not a cross member and the bottom bars mounted in the exsisting front perches. the front... after seeing what you have I think I will go that route...LOL thank for the inspiration! |
01-14-2010, 04:52 PM | #25 |
thanks for the pictures.i've got one of Nates Dropmembers and im gonna attempt it with the motor in. gonna do the same thing by leaving the original motor mounts in untill ive got the old crossmember ready to come out then hook up the engine hoist to raise the motor enough to get the DM and then the new motor mounts in. only thing is i'll be doing it on jackstands. Your burb has realy given me the inspiaration to get into my burb again and get it on the road
