01-30-2010, 04:39 PM | #401 |
Re: Project NOT4SLE
Any word on tie rods? AutoZone has a set but they are Duralasts. Did you call Tuckers or that other place...Premier I think.
79' Big Ten 70' 1 ton 4x4 LB "Mean Green" 70' SWB "Major Project" 69' El Camino "t-boned by Camry" |
01-30-2010, 07:33 PM | #402 |
Re: Project NOT4SLE
01-30-2010, 07:37 PM | #403 |
Re: Project NOT4SLE
Carquest stocks all Moog Tie rods. Their "house" brand is all Moog stuff, not cause some moron told you but because it also says on the box.
Anyways I returned my Moog stuff to Checkers, found some in stock at Carquest and got them. Got home and got back to work on the truck... and guess what she is done!!! Well, for now... back on the road. Wont be driven until Monday after an alignment though. Well I could blab and blab but you all want to see pics. Im waiting on Nate from Porterbuilt to get me my other piece I need to raise the rear an inch. Hopefully he comes through soon. I need that inch. The rear seems way more "unlevel" then it is as the upper white/blue line slopes downhill compared to the body lines.... Well here you go All steering cross shafts, and ball joints are Moog |
01-30-2010, 08:31 PM | #404 |
Re: Project NOT4SLE
Looks good. I think it could a touch lower in the front, Just my .02. wheels look really good.
01-30-2010, 08:40 PM | #405 |
Re: Project NOT4SLE
Looks Good
Just wondering about your tie rod connections to the center link, should they not be on the back side of the center link? not the front? or are my eyes playing tricks on me?
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
01-30-2010, 09:12 PM | #406 |
Re: Project NOT4SLE
If you were rolling through South Central LA that stance would be sick. But your not their so FIX IT!!!!!!!!!!!!!!
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
01-30-2010, 10:16 PM | #407 |
67-72 parts collector,…
Re: Project NOT4SLE
Like Normy71 said,... the center link is on backwards. You need to swap it "end for end" so the inner tie rods will connect on the back side of the centerlink.
Member Mondo had this problem and it eventually broke the inner tie rod due to contact with the center link. The ends of the centerlink should point forward, not backwards. Otherwise looks killer. Last edited by lolife99; 01-30-2010 at 10:17 PM. |
01-30-2010, 10:38 PM | #408 |
Re: Project NOT4SLE
looks good.....but I think it needs to drop in the front a little more or bring the back up a little...(.I like the lower in the front a little better)
Keep it up... Jeff |
01-30-2010, 10:41 PM | #409 |
Re: Project NOT4SLE
ya do agree on the center link.
however i think jack the rear up a inch and maybe go a little lower on the front. But man those wheels look good. Your for sure gonna need to get a exshaust setup on that now. |
01-30-2010, 10:49 PM | #410 |
Tot Roddin'
Re: Project NOT4SLE
Lookin' good!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-30-2010, 11:07 PM | #411 |
Re: Project NOT4SLE
Once you get that stance figured out - Watch Out
I wonder if just the 1" raise in the back is going to be enough??? It looks like you have a bit of room in the front to drop her some more. Do you? Keep us posted, maybe once you get your part from Nate it will be where you want her! Looking good.
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
01-30-2010, 11:09 PM | #412 |
Re: Project NOT4SLE
I'm voting on "raising the rear" about 2" and PAINT THOSE DRUMS!
Did you hit that muffler coming off the driveway? Last edited by highperf4x4; 01-30-2010 at 11:11 PM. |
01-31-2010, 01:45 AM | #413 | |||
Re: Project NOT4SLE
I guess Ill have to look at it again Quote:
the muffler was to put something on after doing the rear suspension as the muffler had to be cut off. So it works for now!!! |
01-31-2010, 01:56 AM | #414 |
Never Ending Projects
Re: Project NOT4SLE
Yep, centerlink on backwards. Here is a pic of mine after the rebuild.
I found I had to rotate the centerlink side to side to fit the tie rods on and they are close but about a 1/4" away from the crossmember when centered. As you move left or right, the centerlink moves away from the crossmember. That is also why the inner tie rods have the grease fittings on the end and not the back like the outer ones. Looking good!!!! I'll have to come by next time I'm in Vegas.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-31-2010, 02:14 AM | #415 | |
Re: Project NOT4SLE
Time to remove cotter keys and get it switched... lol |
02-01-2010, 12:07 AM | #416 |
Re: Project NOT4SLE
Vegas - I needed to load some concrete up into the 68' today & I thought of you!
02-01-2010, 12:14 AM | #417 |
Re: Project NOT4SLE
02-01-2010, 12:16 AM | #418 |
Re: Project NOT4SLE
Looks killer , losve the new ride height.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-01-2010, 01:07 AM | #419 |
Re: Project NOT4SLE
02-01-2010, 01:24 AM | #420 |
Re: Project NOT4SLE
Vegas did you get the steering straightened out today?
02-01-2010, 04:31 AM | #421 |
Re: Project NOT4SLE
02-01-2010, 04:41 AM | #422 |
Re: Project NOT4SLE
no, I got out of work and went to breakfast that lasted till noon. sitting around like that all morning after working all night pretty much makes me ready for bed. LOL
Tomorrow I will fix the steering and I am also thinking about remving the front springs and removing about 3/4 of a coil back towards the end of the notch. Im not sure this will remove much height but maybe 3/4" maybe... anyone know? hopefully I get my piece from Porter soon as it is I think I am rubbing to much to drive it. unless anyone has some 4" drop springs they want to trade for 5" drop springs as i have 5" in there now |
02-01-2010, 08:46 AM | #423 | |
Re: Project NOT4SLE
1/2 COIL = 1" of drop. I would start with 1/2 coil first. Bolt it back together without shocks and set it on the ground. Just make sure the top of the spring is in the spring pocket. Let the bottom go wherever it goes. Last edited by lolife99; 02-01-2010 at 08:46 AM. |
02-01-2010, 08:48 AM | #424 | |
Re: Project NOT4SLE
Too much backspace on the wheels? Do you have the 2" drop or 3" drop on your Porterbuilt trailing arms? Last edited by lolife99; 02-01-2010 at 08:49 AM. |
02-01-2010, 11:57 AM | #425 | |
Re: Project NOT4SLE
I currently have 3 extra" of drop along with a 5" drop spring. I need to be around 7" With my tire combo it is perfectly centered in the wheel well however it will still touch both sides of the tub under load. im going to cut just over 1/2 coil off today on the front to get it where I want it I hope and then ill raise the rear to get clearence |
