02-01-2010, 05:47 PM | #701 |
SWB 4x4 Collector
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
Rob, when you get as fair as making upper trim, make sure to take some pics for me. I am wondering how hard it will be to make the upper trim for the 3rd door. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-01-2010, 06:05 PM | #702 |
I'M TRUCK CRAZY!
Very very nice!
02-01-2010, 10:32 PM | #703 | ||||
Thanks!
Thanks! Quote:
Thanks! I've got the compressor and tank mounted, but I still need a couple of more fittings to finish that part up. I'm installing a schrader valve so I can fill the tank if my compressor ever quits. I'm also going to add a fitting to allow me to attach an air hose. I'm going to figure out where the manifold block goes next.. Here's a few pictures of the progress.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-02-2010, 10:20 AM | #704 |
I'M TRUCK CRAZY!
I like the idea of putting in a schrader valve incase the pump stops working. You could carry one of those small air compressors that plug into the cig lighter and fill it up. You would be good to go. I also like the air hose fitting idea too.
Great work Rob! |
02-04-2010, 01:06 AM | #705 | |
I finally have the compressor and air tank permanently mounted and all connections sealed. Next will be the manifold and the "brain". I hoped to have more done today, but I got sidetracked by having to replace a pool pump motor, . Anyway, here are a few pictures of the tank/compressor. I also threw the roof rack on to verify fitment. I'm going to send the stanchions to get them rechromed. They are really nice for originals, but with the burb aired out, you'll be staring right at them and I want them to look nice.
02-04-2010, 04:50 AM | #706 |
Rack looks great on there. Perfect placement too
Is that a moisture trap or descant cartridge? If it's a conventional moisture trap it will only be effective when placed at a location where the air has cooled. Definitely not right off the compressor. In a home/shop system a min of 20' is standard. ...or maybe it's just a filter? |
02-04-2010, 10:10 AM | #707 |
Restoration Virgin!
That's looking real nice Rob....I'm assuming you'll wrap those exposed wires up for protection?!?!....But you know what happens whne we ass-u-me?!?!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-04-2010, 04:09 PM | #708 | ||
Boxes, boxes and more boxes....... R/
02-04-2010, 04:19 PM | #709 |
I'M TRUCK CRAZY!
Looking good!
Can you get to those air valves with the bumper on? |
02-04-2010, 04:22 PM | #710 |
I'M TRUCK CRAZY!
I guess you can get to them.
Looks like it here. I just wonder if you can get under there with it aired out and the bumber on. I guess you could jack it up if you had too. Last edited by LOW DOUGH; 02-04-2010 at 04:23 PM. |
02-04-2010, 04:35 PM | #711 |
I think I should still have room. Here's a picture from the back with it all aired out.
02-04-2010, 04:38 PM | #712 |
"something witty here"
how did you go about lowering the rear? and heres a question that has me stumped, how the heck do you take a suburban tub off the frame?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
02-04-2010, 05:04 PM | #713 |
CPP bolt in notch, Porterbuilt 2" dropped trailing arms, and ART bags. A cherry picker, a chain hoist and lots of help!!!
02-04-2010, 05:16 PM | #714 | |
I was afraid you were goin to say something like that not looking forward to that, maybe I can get by without doing it right now and do a frame off later
02-04-2010, 05:33 PM | #715 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-04-2010 at 05:45 PM. |
02-04-2010, 05:39 PM | #716 |
I couldnt remember if it was in your build or not, I'll definatly go back and read. that seams to be the way with these trucks, just a huge snowball affect
02-04-2010, 05:42 PM | #717 | |
, exactly!!! Kinda like this, check out my BIG BINDERS!!!
02-05-2010, 05:20 PM | #718 |
Prestige Worldwide
Those are some sweet brakes man!
Are you using the Modular Drop spindles from CPP? |
02-06-2010, 01:03 PM | #719 |
I got the whole setup, . I almost have the 12" rear brakes installation completed. So far it's been a pretty simple and straight forward install. I chose to put the calipers forward of the axle but you can do it either way, you just swap the mounting brackets. Here's a few pictures.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-06-2010 at 01:05 PM. |
02-06-2010, 02:47 PM | #720 |
Oh yeah! Beautiful!!! Glad to see you can mount them forward like that. What's your solution for securing the ebrake cables to the PB arms?
02-06-2010, 03:41 PM | #721 |
This....
02-06-2010, 09:12 PM | #722 |
Master Yoda, much skill see I in him....
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
02-06-2010, 10:02 PM | #723 |
Rob what an outstanding job you have going with the Burb...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-07-2010, 08:50 AM | #724 |
Now that is one nice brake set up!!!!! making me jealous. Keep it up and before long you will be scraping paint, draggin tail in that burb. LOL. like that is gonna happen.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-08-2010, 12:49 AM | #725 |
Thanks Al! It's a really sweet kit and I finally feel like I'm making progress on the burb. I pretty much have the rear buttoned up. I have to get a differential gasket tomorrow and tighten a few bolts and then I'll be moving towards the front..... Here's a few pictures of everything mounted inluding the brake lines.
