Old 02-20-2010, 06:05 PM   #101
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Project: Recycle
Dang Scot! You have been moving along at a decent pace. You never mentioned this last time we talked.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-20-2010, 08:33 PM   #102
SCOTI
SCOTI's Avatar
There's more done but I'm showing only the pics of the chassis so far. Once I'm past that, I'll have other stuff too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-23-2010, 09:54 AM   #103
thepartsguy
thepartsguy's Avatar
Subscribed.
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 02-24-2010, 10:47 PM   #104
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn nice work scoti....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-25-2010, 12:24 AM   #105
SCOTI
SCOTI's Avatar
I got a little time in tonight but nothing worth pics.
To recap, I've been considering two choices for my fuel-fill change since my original 'easy-fill' option wouldn't work. Last Friday, I picked up a nice, flat, rectangular, flip open gas door. Option #1 is flush mounting a stainless filler in the floor. Option #2 is the bed (floor) mounted gas door w/the filler just below the floor.
Option #1 is more than likely the route I'll take but I needed to visualize the size, placement, & complexity of each to make the final decision....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2010, 08:51 AM   #106
N2TRUX
Happy to be here
N2TRUX's Avatar
It may be more work, but I like option #2...
Articles-
"Refining Sierra"
Old 02-25-2010, 03:45 PM   #107
SCOTI
SCOTI's Avatar
I think it's the cleaner choice but the material is very thin & would require substantial re-working. That extra work has me questioning its worth....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2010, 10:16 PM   #108
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I prefer option 2 as well. It's all up to you as to which you like best. All we can do is give our .02. If your leanin' towards option 1 then run with it. They are both nice options.
Alan's Classic is offline   Reply With Quote
Old 02-26-2010, 01:24 AM   #109
SCOTI
SCOTI's Avatar
I wish the material was thicker & wouldn't require remaking most of it. I like it as the better option if this was a full blown ride.... Since it's just a 'distraction', I'll take the 'EASY' button this time around.
A little bit of time on the floor yielded a rough idea of how the flush mount set-up will look. I used what was readily available to mimic the 45° slope on the floor runners but widen out near the C/L of the cap. The steel is cut & just taped in place for observation. I fogged it w/some satin blk to get a better idea of how it flows w/the bed runner that runs the length of the floor....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-26-2010, 08:49 AM   #110
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good, we did the '67 similar to that. I liked the option #2 as well, but didnt find a fuel door at the local JY quick enough, and just took the easy way out....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-26-2010, 10:09 AM   #111
SCOTI
SCOTI's Avatar
I looked through the build but didn't notice bed floor pics.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-26-2010, 10:41 AM   #112
aggie91
I'm just glad to be here!
aggie91's Avatar
Boy, I missed something...I had to go back and skim through this whole thing to find out why your doing this for the filler neck. I found where you strugled with the piping from your original location in the corner. I thought that location was great. A buddy of mine did one in the corner on a '71 model that turned out nice, but I never looked at the piping or tank type.
I like how this centered location looks with the small filler. I think that getting anodized in a satin black if you use a spay in liner would make it almost disapear.
Not to bug you too much, but did you have a chance to get those measurements of the axle perches?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-26-2010, 01:07 PM   #113
SCOTI
SCOTI's Avatar
I have the axle installed on the chassis (on my 'table') so gettin accurate dimensions has been a challenge while working solo. My buddy stopped by the shop Wed night after dropping his daughter off but only stayed a few minutes. I asked a guy from my work to lend a hand w/it after work tonight (he owes me a favor).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-27-2010, 10:45 PM   #114
SCOTI
SCOTI's Avatar
Well, it turned out ok. I'm not 100% pleased but I think it will suffice for this build. Keeping the corners aligned & symmetrical was much harder than anticipated. I also got the first fuel fill hole I cut out patched up while I was cutting, welding, & grinding....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-27-2010, 11:33 PM   #115
VA72C10
VA72C10
VA72C10's Avatar
It came out nice!!!
Old 03-01-2010, 10:55 AM   #116
aggie91
aggie91's Avatar
Looks good on the fill hole. Are you going to do a spray in bed liner or paint? I think that the liner would hide whatever you do not like...I don't see anything wrong in the pics.
Thanks for the measurements on the rear end.
Karl
The LST Challenge:
Old 03-01-2010, 01:50 PM   #117
kizer
Its Deja Vu time again
kizer's Avatar
Wow I'm digging your attention to detail on things.
Subscribed of course.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-01-2010, 05:23 PM   #118
Jonboy
Slots go on anything!
I hate I wasn't able to check this one out yesterday. Maybe next time.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-01-2010, 06:17 PM   #119
SCOTI
SCOTI's Avatar
I thought about that, but..... you came to my house; the truck is @ location #2; & the 'build' is going on @ location #3 .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2010, 07:15 PM   #120
lolife99
67-72 parts collector,…
lolife99's Avatar
Scoti,...
I planned on just cutting a round hole and shoving my "homemade" adapter
up thru the bed floor (from the bottom side) and welding in place.
I made the step the same height as the bed floor rib.
Still haven't installed it,... but here's a few pics of the piece I made.
I don't have your welding skills, so I have to make do.
Keith
Convert to disc brakes.
Old 03-01-2010, 08:18 PM   #121
SCOTI
SCOTI's Avatar
Scoti,...
What is your adapter made of?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2010, 08:45 PM   #122
lolife99
lolife99's Avatar
It's just carbon steel.
I was going to have a buddy tack weld it in place from the bottom,...
and then finish weld it from the top.
I wanted something thicker than sheet metal, so I could tap the holes and use stainless machine screws instead of sheet metal screws.
Keith
Old 03-02-2010, 12:58 AM   #123
Alan's Classic
Nice work.
Old 03-02-2010, 01:41 AM   #124
SCOTI
SCOTI's Avatar
Similar plan here. I'll use a steel backing plate w/SS machine screws to secure the filler in place.
I actually considered doing a little from each of my choices from the previous pics (weld in a flat piece of steel across multiple floor runners beveling the edges between to match the factory & simply mount the filler in the center).
I figured if my 1st attempt didn't work out, it's simply a matter of cutting it out @ welding in the flat piece.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-02-2010, 11:13 PM   #125
my67chevytruck
Under Construction
SCOTI, we should have spent more time, as yours looks better, but the filler landed to the far right of one of the humps, and as i stated we took the EASY way out. Keith i like that adapter plate, well thought out.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
