572 update
Well rolled the '72 back in the shop the other day and started to test fit the new engine. things are going well, here are a few pics of the proceedure.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by handsomerob; 02-23-2010 at 08:58 PM. |
![]() Join Date: Jul 2009
Re: 572 update
oh man that looks so good
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Looks like it was made for it... nice!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Feb 2008
Re: 572 update
Oh man, a dream come true. That looks so sweet in that engine compartment. I hope you can get some of the power to the ground.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
![]() Join Date: Jul 2003
Re: 572 update
Yowza!
Re: 572 update
WOW....
looks like you should buy stock in a tire company ![]() |
Re: 572 update
Yup the Distributor clears, dealing with headers right now, been on the phone for hours trying to come up with some solutions.
Re: 572 update
Re: 572 update
Throw twin turbos on there, then you can flip those headers over!! Might need to drop that compression a bit though...
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
60-66 Nut
Re: 572 update
Sanderson makes a set that will work. That's what Stacey David used on Copperhead. I don't remember the part number, but they will know what ones you need.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-24-2010 at 12:37 AM. |
Re: 572 update
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
"THE GREEN GOBLIN"
Re: 572 update
Chevrolet began offering a 572-cubic-inch (9.4 L) "crate motor" in 2003 which produced 720 hp and 685 lb·ft of torque,and more recently a 620 hp / 650 lb·ft version capable of running on 93 octane street gasoline... This is the Beast of all beasts the biggest of the crate motor Big blocks.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 02-24-2010 at 10:03 AM. |
#14 | |
JRods Garage
Re: 572 update
#15 |
"THE GREEN GOBLIN"
Re: 572 update
oops in that case I would like to know too, is it Bigger?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#16 |
Re: 572 update
NICE!!!! I am extremely Jealous!!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#17 |
Champagne Taste on Beer Budget
Re: 572 update
So what transmission you running behind that beast?
Looks awesome! Keep us updated.
Coming Soon: Project 1970 Country Truck |
#18 |
On the path to financial ruin!
![]() Join Date: Jan 2009
Re: 572 update
Uh oohh!! Mama.....here comes that man!!!!!!!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
#19 |
Re: 572 update
The deck height is different, standard BB deck height is 9.2" I believe and the 572 has a deck height of 10.5" so basically it makes the distance from one side of the valve covers to the other wider, makes things a little tighter.
Oh and the Tranny is a 4l85E from GM and I will be using thier recommended controller, along with a Cable-X system to retain the factory speedo, There will be a detroit locker goin in the rear and a ladderbar system to hold it all together. I will post picks as things progress. Last edited by handsomerob; 02-24-2010 at 01:35 PM. |
#20 |
Re: 572 update
Haha, thanks Petey, I was meaning physical size. I saw an overhaulin' where they had to make their own headers to fit it in a '73 Z/28. I was always thinking, "Why didn't they just use BB Camaro headers?" Now I was thinking the same thing with this project. Thanks for the info Rob.
#21 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: 572 update
Even though it has been answered, yes the 572 is a different BBC casting all together, and will not except normal big block brackets, as so I heard on Overhaulin' years ago. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#22 |
Re: 572 update
wow.. i didnt know that. i always thought they were the same size block... very interesting
#23 |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: 572 update
Holy Toledo! How are you going to get that thing to hook up?!?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#24 |
Re: 572 update
did canadian tire do the install???? looks like the shirts
#25 |
Re: 572 update
Canadian Tire probably sponsored him. They figure they'll make it back in rear tires.
