Old 10-11-2009, 11:19 AM   #76
custom63
custom63's Avatar
Re: 250 Inline 6 Performance Build Q's---Hello Brad---
Originally Posted by 68phleet View Post
hey
anybody on here have a holley 390 on a clifford manifold with a brake booster setup????? Rockin a 250. What kind of air cleaner assemblies are you using? Havin a hard time finding a good fit.
What do we have?????
I have a 250 set up on my '63 with a clifford intake and holley 390 with the power brake booster and this is the air cleaner set up I used.
Originally Posted by jsmithbm View Post
Does anyone have power brakes on their 250, i am going to be installing mine here soon now that the weather is getting cooler. Where did you hook the vaccum line too?
Here is a couple pics of my setup
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 10-11-2009, 03:04 PM   #77
68phleet
Thanks custom 63 but I think you have more room than i do
I think maybe one of the triangle freflow ones might work. If anybody has one what is the shortest diameter of it from tip to the other side. I dont think i can fit anything larger than 6" in diameter.
68 c10 lonnnnnngbed 250 6 cyl
68phleet is offline   Reply With Quote
Old 10-27-2009, 02:50 PM   #78
68phleet
almost there...need to get the jetting right. That holley fre-flow filter fit just fine after i persuaded it with a mallet.
Smithy- i cant remember what i had that vacuum line hooked up to but i will have it figured out in the next two weeks
Old 10-27-2009, 02:52 PM   #79
68phleet
hey custom 63,
how did you get your linkage to work with the carb, did you go right through the firewall? I'm trying to figure out the best way to do this.
Old 11-02-2009, 09:31 PM   #80
custom63
custom63's Avatar
hey custom 63,
If you look back at my past post, picture #2 shows the throttle cable coming through the firewall. It’s not a direct shot as you probably already know so that’s why it does the curve it does. Its not as smooth as I would like it either and I have a pretty heavy duty return spring hooked up to it as well. I am planning on tearing her all down for a frame up rebuild and I will probably redesign it then.
Tommy~
-- Albert Einstein
63 build Thread
Old 01-20-2010, 08:17 PM   #81
70c-10
This was going to be installed in my 70 C-10. I sold the truck, so it's going into my Chevy II.
I have some more pics here:
63ChevyII.com
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 03-03-2010, 04:26 PM   #82
68phleet
wow,
That is sikkk!!!!
Old 03-03-2010, 09:34 PM   #83
culp7
HickTown
culp7's Avatar
man, this is a great thread right here!
and can i run stovebolt headers w/ a stock intake/carb setup???? any issues?
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 03-04-2010, 01:50 AM   #84
Brad
Out of the carpool lane.
Brad's Avatar
Yes you can run that. You will need to grind part of the header and intake where they mount at the bolt. I HIGHLY recommend you put studs in place of the bolts since you'll need about 5 hands otherwise, just to keep everything in place and aligned while bolting things together.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-04-2010, 06:11 AM   #85
'68OrangeSunshine
'68OrangeSunshine's Avatar
The kind of studs I use are 3/8-16 UNC into the head and 3/8-24 fine to meet the mating surfaces. The fine thread comes up to torque slower and holds better.
Old 04-11-2010, 10:24 PM   #86
dnorris009
dnorris009's Avatar
Sorry if I missed it in the thread.
Can anyone confirm for certain if these $130.00 Flowtech long tube headers will fit my '70 2wd C-10 with a 250?
http://www.summitracing.com/parts/BI...n/?prefilter=1
It says 4wd only but they look the same as the Cliffords & Hedmans way more expensive ones.
In fact from what I can see they all look like they could have came out of the same factory.
Only the discontinued Hookers look different to me.
(I'd love to find some,if they'd fit)
I don't mind paying more for a better product but if it's the same dang
thing just in a different box,
I'll buy the least expensive every time.
Also if I upgrade to a 292 later....
Will I have to change the pipe routing because of the taller block??
Thanks... Love the StoveBolt photos,keep 'em coming!
Dave
dnorris009 is offline   Reply With Quote
Old 04-11-2010, 10:51 PM   #87
67_C-30
I have a radical idea!
67_C-30's Avatar
Here's some 6 banger performance! I was playing around in my shop truck a while back. It takes mad skills to powershift a 3 on the tree! Seriously though, it is quite peppy to a bone stock 250.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-11-2010, 11:02 PM   #88
tommyd241
tommyd241's Avatar
^^^^^Haha!! That's awesome. You even chirpped the tires in 2nd gear! Love it!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 04-11-2010, 11:09 PM   #89
67_C-30
67_C-30's Avatar
Sometimes it will scratch them just a little going into 3rd, but I let up at the top of second when I saw that car coming. Usually there is no traffic out there, so it surprised to me see someone!
My trucks
Old 04-11-2010, 11:26 PM   #90
tommyd241
tommyd241's Avatar
Nice. Gives me inspiration. I wanna build my 250.
'68 SWB Fleetside
'98 K1500 Silverado
Old 04-13-2010, 12:35 PM   #91
Brad
Brad's Avatar
Dave
I can tell you the Clifford is a completely different header than the Hedman or Hookers or Flowtech.
Old 04-14-2010, 11:28 PM   #92
'68OrangeSunshine
Doesn't Clifford make a couple of different header designs for the "late" L6s?
Old 04-15-2010, 02:06 PM   #93
dnorris009
dnorris009's Avatar
Clifford makes the shorty headers....
http://www.cliffordperformance.net/M...gory_Code=C250
& the long tube....
My understanding of what LeoSantucci wrote in his Stovebolt power manual (could be wrong) is that long tube headers work better than the "Shorties" for a street driven vehicle 2700 pounds or more.
But from what I've read on the net. There may be a clearance issue with the "Long Tubes" & the tranny shift linkages.
If you look at pictures of the $385.00 Clifford long tubes,
the $195.00 Headmans &
the $130.00 Flowtechs.....
They all look like they have the same bends/dimensions.
I'm just trying to find out if they are basically the same or are the more expensive Cliffords worth the extra cash.
I,E.... better clearance/performance.
Old 04-15-2010, 04:51 PM   #94
'68OrangeSunshine
& the long tube....
I've been running the same Clifford long tube headers on the 292 in my '68 C/10 Stepside since 1978 [back when they were still Clifford 'Research']. I have an SM 465 with stock L6 Z-Bar clutch linkage. My truck is at stock ride height -- no mods. I had no major clutch linkage interference issues that a ball pien hammer, judiciously applied, didn't cure. It was 32 years ago and I had help from a local hotrod mechanic, so I can't recall all the details.
Theoretically, long tube headers are good for better torque.
For the record, I have had the manifold plate resurfaced and an offroad accident that crushed into the #5 downtube into the collector was resectioned and patched with a half section of pipe, but the Cliffords have served me well for years. They ran about 24 years on the last engine, then were hot tanked and bead-blasted, finally painted with VHT 1200* cast iron grey spray paint and put back on the 'new' engine [the original, but rebuilt @ .030-over, w/ Crane 260H cam, 307 V8 intake valves [1.84"] and a few other mods]. I'm still running these headers 5 years after the rebuild and they are great.
I run dual exhaust with a crossover [angled since the 1-2-3 collector and the 4-5-6 collector exit about 11" apart]. I have turbo mufflers and the stock, behind-the-rear-tire exhaust piping. I think the tube diameter is 1-7/8" or 2".
But then I live in Southern Arizona, and unless I'm skiing, run into zero salty slush.
Old 04-15-2010, 05:07 PM   #95
Shaky
Six in a row makes it go...
Shaky's Avatar
I went with the Clifford shorties and a home-made Y-pipe:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
