Old 03-17-2010, 10:23 AM   #1
neo297
2004 yukon xl tranny slipping
Hi I'm new to this board. I have an '04 yukon xl 5.3 all time 4 wheel drive no 4 wheel steer. it has 149,000 miles on it and has run great since i bought it about 3 years ago with around 100,000 miles on the odometer. Changed the tranny fluid and filter about 4 months ago. Had no problems then just unsure when it was done last. Suddenly and I mean without any warning or prior slipping 3rd and 4th gear are slipping like crazy. 1,2 and reverse work great but as soon as tranny shifts to third tach races to 4,000 rpm and you can barely keep 55 mph. My question is does a clutch pack go out like that or is the suddenness more indicative of a solenoid or electric sensor issue. I do my own wrenching on my motorcycles and my alfa spider but they are manual trannys not automatics. Also I have had no dash board warning lights I have no obd tester to pull codes myself so was hoping for some info to arm myself with when checking with the dealer or local tranny shops. Any help would be greatly appreciated.
Paul
neo297 is offline   Reply With Quote
Old 03-17-2010, 10:29 AM   #2
lyrikz
PITbut
lyrikz's Avatar
Re: 2004 yukon xl tranny slipping
Paul
Yes they will go out like that and they will go around that mileage. What fluid did you use when you changed your trans. fluid.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 03-17-2010, 11:05 AM   #3
neo297
I cant remember I think it was mobil 1 I know I checked at the time to make sure it was compatable with my year. I use mobil one oils in my other trucks( ford explorer), but have to use high zddp oil and stp red in my alfa due to the flat tappet cams. I have no leaks and i checked several times after to ensure the level was ok. The fluid now seems darker but still red not black. If it were to be clutch packs is it more reasonable to put in a rebuilt tranny and torque converter or just replace the clutch pack. My instinct is all the other parts are old and if the tranny comes out I should replace all I can. In my research I saw where some companies add extra clutch plates to the 3-4 pack is this needed for a stock motor that does moderate towing occaisionaly? This is the first transmission issue I have had with my chevys my 98 5.7 pick up never gave me any tranny probs until it was sold with 135,000 miles on it so I am somewhat cluless in this particular area. Thank you for responding so quickly.
Paul
Old 03-17-2010, 11:20 AM   #4
lyrikz
PITbut
lyrikz's Avatar
Paul
Two words, dextron 6. Dont run anything else. We do ALOT of transmissions and fluid changes. It used to be dex 3 would be ran in everything. Chevy changed over to the dextron 6 and we had issues running anything but Dex6 when it calls for it.. FLuids that are compatible wont act the same.
Example, i can run a compatible trans fluid in hondas but they shift like crap. You put the factory Honda fluid in and it shifts right.... just some thought.
and sold.
Old 03-17-2010, 12:38 PM   #5
neo297
Sounds good Now I just have to determine what it is going to cost to fix. My alfa is very tempermental on the type of gear oil and engine oil needed so I am familiar with the subtlety. I just was not aware for my yukon that I needed to use anythingelse other than making sure the brand I chose said it was for that year model gm. Live and learn. Do the clutch packs, solenoids, bands etc. come as part of a rebuilt tranny as a unit? It seems if there is no specific electronic component or solenoid that affects 3rd and 4th gear I'm looking at putting a rebuilt transmission in. Since it shifts into 3rd and then slips I am assuming it is likely clutch pack unless someone can advise me otherwise.
Old 03-17-2010, 01:20 PM   #6
lyrikz
PITbut
lyrikz's Avatar
I would have it rebuilt completely since its out... Most shops i use, have found known deficiencies in the transmissions so they do things in those areas to make them better. So when you do have yours rebuilt, or get a rebuilt one they are better then the original. Im not sure if your tranny fits that scenario.
Also depends on your budget... If it slips in those gears, slap a clutch pack in it and drive it.. But that just seems shady ya know... Good luck.
and sold.
Old 03-17-2010, 04:27 PM   #7
clinebarger
Every 700R4/4L60/4L60E I build gets 9 3-4 clutches VS 6 the factory uses, I consider it mandatory, Even the V6 transmissions that have 5 from the factory.
If it happened all the sudden its probably a apply curcuit problem(cracked servo piston, busted separator plate, bad lip seals on the apply piston, ETC...)
So i whould get it rebuilt because just putting clutches in it will not solve the apply curcuit problems.
clinebarger is offline   Reply With Quote
Old 03-17-2010, 04:40 PM   #8
lyrikz
PITbut
lyrikz's Avatar
I knew they had some goodies when rebuilding. Absolutely you would want to have it gone over completely.
Hey cline, do you guys have a tranny dyno there??? Whats your average rebuild cost on his transmission??
and sold.
Old 03-17-2010, 04:55 PM   #9
clinebarger
I have worked in some transmission shops that do have dynos, but a 4L60E is hard to dyno without a stand alone controller that shop owners dont want to buy.
$1200 to $1500 with R&R. $800 to $1000 bench job.
Old 03-17-2010, 05:23 PM   #10
neo297
Thanks guys you have confirmed what I was thinking, there is just no sense in not putting a rebuilt in as long as the old one has to come out. I am going to make sure I have an up graded 3-4 pack do i need to ask for a 4l65e
to get the upgrade or are the rebuilt "4l60E's" already there. I know the 65's did not have 8 or 9 plates in 3-4 but had more than the 60's. I also thought the 65 had different planetery set. I am going to present these questions to my mechanic so I can ensure I get the best tranny to put in. I do appreciate the input and will post back when the repairs are done.
Paul
Old 03-17-2010, 10:24 PM   #11
clinebarger
Paul
4L65Es have 7 clutches, and have a 5 pinion planetary gear set VS 4 on 4L60Es. A quality rebuild on your 4L60E will be good.
Old 03-18-2010, 12:00 PM   #12
neo297
Thank you I had takren it in yesterday at lunch and there were no dtc codes it showed it to be shifting into third and then it just slips bad he told me it would nee dto be pulled so I told him to get me prices on a gm rebuild that has 100,000 mile /3yr warranty v. his supplier of rebuilts with a 90 day warranty and based on cost we will proceed accordingly. Thanks to all who responded.
paul
Old 03-18-2010, 07:05 PM   #13
truckdude239
truckdude239's Avatar
just nmake sure they use dexron 6 in the new unit
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-18-2010, 09:16 PM   #14
clinebarger
You can run dexron III fluid in any and all 4L60E/65E transmissions with no problem.
Old 03-18-2010, 09:48 PM   #15
Black 95 TSI
I just got done putting a Jaspers in my 2000. I am running BG syn in my truck
70 C10 SWB stepside forsale
00 Silverado Z71 Sold
95 Eagle Talon TSI turbo (Hellz ya its fast)
70 Chevelle
69 firebird
10 Silverado 4x4
Black 95 TSI is offline   Reply With Quote
Old 03-19-2010, 08:38 PM   #16
truckdude239
yeah but it is getting harder to find and gm now recommends the dexron6
David fuller
2000 Tahoe 5.3l 378
Old 03-20-2010, 08:41 PM   #17
clinebarger
I use alot of dexronIII I havnt had trouble buying it. DexronVI is for the new 6 speed autos & if i had one i whould use it. Im not going to let GM dictate that I need a more expensive ATF in a 4L60E when dexronIII worked good for so long.
Old 03-22-2010, 02:18 PM   #18
neo297
Well I'm being told it will be $3500 parts and labor for a gm from the dealer rebuilt 4l60e installed labor included(about $700) this is with 3 yr 100,000 mile warranty or he can get me a localy rebuilt 90 day warranty tranny for 2400 plus labor or a junkyard pull " low milage non rebuilt" for 2200 both plus labor to install. I do not have that much at this moment so it will wait for a liitle but wanted to pass on the prices I was given. Unfortunately I live out in the country so my options are limited.
Paul
Old 03-22-2010, 04:05 PM   #19
lyrikz
PITbut
lyrikz's Avatar
Paul
Do this.
Order a rebuild online and then install it yourself. Save you quite a bit of money...
Do me a favor, get me the year, make, model and vin if you feel safe. I can tell you exactly what fluid you want.
and sold.
Old 03-22-2010, 05:32 PM   #20
neo297
Do this.
2004 yukon xl 1/2 ton L59 flex fuel 5.3l with stabilitrac all wheel drive top of the line traction control engine mngmt system 3.73 rear gear "heavy duty trailering equiptment pkg"?transfer case #az91d dont have the vin written in this book i have with me if needed i can post later. Who do you reccomend that wont cost arm and a leg to ship to dallas area. I have no lift at home just ramps and air compressor with a few tools normal assortment of hand tools any special tools needed and can a tranny lift be rented? Thanks
Paul
Old 03-22-2010, 06:26 PM   #21
clinebarger
GM recommends Dexron III to 06. PM me if you want to and ill recommend some shops, 90 day warrenty is a joke.
Old 03-23-2010, 12:33 PM   #22
lyrikz
PITbut
lyrikz's Avatar
Paul
I dont care what anyone says here. Use Dextron 6.
and sold.
Old 03-23-2010, 01:00 PM   #23
truckdude239
btw dextron 6 does not cost much more then the 3 does
David fuller
2000 Tahoe 5.3l 378
Old 03-25-2010, 01:20 AM   #24
bighaas79
unless you can find someone who has the special tools to loan you that you need to rebuild it, let someone else rebuild it for you. If you have to buy the special tools to do it yourself it would probably end up costing you more in the long run. trany special tools arent cheap. And as far as tranny fluid you can use dex 6 on nething that used to call for dex 3 EXCEPT transfer cases. (one of the additives in the dex6 will deteriate the nylon parts inside.) However you CANNOT use dex3 in nething that calls for dex6. Besides dex6 is a better trans fluid than the 3 neway. Has better friction modifiers and resists breakdown to higher temperatures. And really whats say $20 more spent on fluid compared to the $3000 spent on replacing a burnt up tranny?
bighaas79 is offline   Reply With Quote
Old 03-25-2010, 01:31 PM   #25
clinebarger
Wow, now this super fluid keeps transmissions from burning up?
His 3-4 clutch failure is not fluid related. Low fluid level maybe but not the type
If the transmission gets hot enough to break down dexron III its toast anyway I dont care what fluids in it.
