Re: How about some pics of '73-'87 Short Beds
my 86 sierra,,just painted and it is HORRIBLE
Balls to the wall!
looks good in the pics any way. I have all ways liked silver on square bodies.
1982 swb 1/2 ton Also have a 2001, 400+ Hp T-top Camaro SS Loving my old Chevy truck and my new square body family on here!Thanks for all the help,tips and ideas I have gotten already guys. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=388836 ............_________{\___ ............l_(0),,,______(0)l |
b4 paint
the dull spots can be from overspray or to little clearcoat or failing to aply the clearcoat at the right moment , waterbased paints have a different way of aplying than thinnerbased ones there allso less good to buff without scratching because the paint is softer after drying
still (sounding like a standing joke here) : "you might be able to buff those out" try a small spot thats not clearly visable standing up and with some water buffing compound a soft rag and a lot of elbow grease see if the dullspots gets a shine or you just go trough the paint in the first case youre lucky and its fixable with little money and some effort the second they didnt aply enough clear and they need to redo the clear , it should cost a lot less than having to do the basecoat and topcoat over again the dents and al the other stuff has allready been taken care off so its only getting the truck sanded down with a scotch pad and respray right this time try buffing or sanding buffing first you might actually be able to get the truck look like its covered in glass with a lot of buffing from a person who knows his job when working with a machine and buffingcompound you have to be carefull on edges to keep the surfase wet enough so you dont force the buffingstuff intoo the topcoat and not to burn the paint those things take time to learn working with youre hands rubbing the truck is better when you dont have as mush experiance but its a LOT of work
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
