Old 05-01-2010, 11:06 PM   #1
longbedrick
longbedrick's Avatar
mech. fuel pump variation
installed a fuel pump on a Big Block '69 El Camino a while back, and noticed there was (1) inlet and (1) oulet on the mechanical fuel pump. On my '73 Big Block 454 it seems there are (2) inlets and (1) outlet. Why the variation? my truck has dual tanks. there are 3 ridgid lines running from the two tanks. (2) lines to the pump, one line to the charcoal canister
Here's mine on the '73
Name:  fuelpump resize.jpg
longbedrick is offline   Reply With Quote
Old 05-02-2010, 01:23 AM   #2
Prong
Re: mech. fuel pump variation
The third line is the fuel return (1/4" dia hose). It'll either run to the switching valve (on a dual tank setup) or to the sender on the fuel tank itself (single tank configuration).
Prong is offline   Reply With Quote
Old 05-02-2010, 03:15 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
All I see is dirt. LOL
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-02-2010, 11:00 AM   #4
longbedrick
in order to test the fuel pump, do i plug off the return line? thinking of purchasing a fuel pressure gauge to check pressure on pump. i put my finger over the line to carb inlet, and could BARELY feel anything. how much pressure should I read on a gauge?
Old 05-02-2010, 11:05 AM   #5
longbedrick
found a Chiltons manual for 80-87 GM trucks. fuel pressure psi for 80-81 454's is 7.5-9 psi. 84-86 454's is 9.0psi. safe to say the same for a 1973 big block?
Old 05-02-2010, 01:06 PM   #6
gchemist
gchemist's Avatar
Yes, if the pump is old replace it.
Old 05-04-2010, 11:21 PM   #7
longbedrick
bought a new vacuum/pressure gauge (all non AC DELCO handtools 50% off while supplies last at Kragen). fuel pump is pushing only 1 psi.
1.)can I use a fuel pump with NO return line and block off the return?
2.)do I absolutely have to have a return line?
Old 05-04-2010, 11:53 PM   #8
gchemist
gchemist's Avatar
No you don't need to have the return. However you should use a return style pump. A new fuel pump is not expensive.
