year of cab???
I have started working on my project truck and am using a rust free cab from a donor that has no tag or anything on it. I know that it is 1981 to 1987 as it has the built in hood hinges but are there any other differences??? I know I might be getting myself into trouble as I ripped out the wiring harnass along with just about everything else so I can clean up the whole cab before paint but would like to know if I can take parts from any 81-87 to put it back together or if I need to find certain years. When I got it there was no dash, drip rails, dash pad, glovebox or much else inside, but the metal is absolutely spotless. Might have had a little work done on the drivers rear pillar as there are a couple of weld spots in the door opening but other then that it needs sanding and painting and then alot of assembly.
Thanks for any info.....
'70 Malibu with 383 stroker/T350 '56 SWB Mercury pickup..under construction '67 Firebird Convertible...all done stock '70 LWB 350 on propane...beater '69 LWB 350/T400 body restored |
Next project: 1970 K10
Re: year of cab???
67-72's had some differences with e-brake and throttle pedal assemblies, which I am guessing are the kinds of differences you are referring to. But I think the 81-87 cabs are all the same, so aside from some cosmetic appearances it shouldn't matter much what you put back in as long as it was from a 81-87 cab originally.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-04-2010 at 01:33 PM. |
Laid back freak
Re: year of cab???
84 n up has no wiper switch hole in the dash as the wiper switch was then put on the column.So if you got a dash that still has the windshield wiper switch hole its 81-83 then.
thanks pat
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). Last edited by 80stepsideguy; 05-05-2010 at 04:45 AM. |
Re: year of cab???
Oh, that's a good one Pat!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-04-2010 at 03:04 PM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: year of cab???
In 1984/5 (have to check my notes) they started using galvanized floors. And around that same time they started putting the plastic stuff on the pans to "stop" rust from leaks which leaves a good place for water from leaks to hide to make rust....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 05-04-2010 at 03:10 PM. |
Laid back freak
Re: year of cab???
Its all good bob
thanks pat
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
