Old 05-25-2010, 06:13 PM   #1
67 c10 guy
67 c10 guy's Avatar
wiper arms
i am having problems getting my wiper arms off. there is a thin tab at the
base of the arm i dont know if thats the release for it on not.
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 05-25-2010, 07:10 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: wiper arms
Lift the arm up as high as it will go. You have to hold it in that position while prying the bottom off its pivot. Seems like you need three hands to do it but it will come off with some coaxing.
Warning: they may be stuck so it may require some serious prying or coaxing. I use a towel under a claw hammer or pry bar and ease it up. Try not to damage the paint.
68gmsee is offline   Reply With Quote
Old 05-25-2010, 08:48 PM   #3
JimKshortstep4x4
Re: wiper arms
There is a removal tool that works pretty well. Most "Help" sections in auto parts stores have them and you will not skin up your cowl using it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-26-2010, 12:02 AM   #4
67 c10 guy
67 c10 guy's Avatar
Re: wiper arms
thanks, paint is not really an issue and i did get off with out any damage to the cowl. and all it took was 2 screw drivers.
thanks very much
Eric
67 lwb build sold
Old 05-26-2010, 12:46 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: wiper arms
This is the tool that makes removal a lot easier.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
67 c10, c10 2wd fleetside, how to, wipers
