Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-18-2010, 10:53 PM   #951
smbrouss70
smbrouss70's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
I like to put a Trans. Temp sender in the line with one of these... http://www.summitracing.com/parts/ATM-2287/
That way you don't have to unhook it everytime you change the filter and fluid.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-18-2010, 11:05 PM   #952
jmedero
jmedero's Avatar
I say red with a white stripe like the truck. Why not.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-19-2010, 09:35 AM   #953
67cheby
67cheby
67cheby's Avatar
i say paint them red and have whoever made you that scrolling badge make a scrolled piece to go all the way down the center of the valve covers....its just money and it would look killer
67cheby is offline   Reply With Quote
Old 07-19-2010, 04:14 PM   #954
eagleuh1
eagleuh1's Avatar
Your engine should look like that after 20k also. Without the exhaust crossover and hot intake baking the oil. Mine looked pretty clean when I had it open at 20K. Does your shifter get into all gears and also is the column adapter made by Lokar or your custom design?
eagleuh1 is offline   Reply With Quote
Old 07-19-2010, 06:11 PM   #955
Hart_Rod
Hart_Rod's Avatar
Originally Posted by VA72C10 View Post
Man, you know how to test a man's willpower from coveting.
, Be strong!
Thanks for the link. I was wanting to use the factory lines but it looks like I may have to do something different.
Don't you think I have enough red and white already???
That would probably break the bank......
Totally agree. Shifter goes into all gears. I will still need to do some fine tuning after I put everything together to stay. Are you talking about the shifter arm bolted to the bottom of the column? If so, that's the Flaming river builds their columns.
Hart_Rod is offline   Reply With Quote
Old 07-19-2010, 06:41 PM   #956
kvn1011
Kvn1011
kvn1011's Avatar
1st opinion would be black Powdercoating/or paint (glossy)
2nd opinion would be chrome plating or chrome Powdercoating
Awesome job your in the home stretch now!
kvn1011 is offline   Reply With Quote
Old 07-19-2010, 06:43 PM   #957
kvn1011
Kvn1011
kvn1011's Avatar
Doublepost
Old 07-20-2010, 08:10 AM   #958
mac72
Rob
Just do them glossy red like glocks http://67-72chevytrucks.com/vboard/s...d.php?t=412159
That relly looks sweet . Mac
mac72 is offline   Reply With Quote
Old 07-23-2010, 11:13 AM   #959
Hart_Rod
Hart_Rod's Avatar
Originally Posted by mac72 View Post
Rob
Thanks guys. I'm still debating. I'll probably shoot one of each color and see which one I like the best, ...
R/
Old 07-25-2010, 12:26 AM   #960
Hart_Rod
Hart_Rod's Avatar
Accomplishments today:
Drilled and tapped oil port to install oil pressure sending unit.
Painted one of the valve covers red (not sure if I like it yet).
Mounted the fuse for the air bag compressor.
And I finally started on the wiring......... what a mess.....
Old 07-25-2010, 12:50 AM   #961
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
idk about that red valve cover maybe it will grow on me but not diggin it as of right now? It just looks outta place?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-25-2010, 12:58 AM   #962
mcbassin
Still Learning
mcbassin's Avatar
Looks like some great progress!
Old 07-25-2010, 01:31 AM   #963
jmedero
jmedero's Avatar
Wow all that and you found time to look at my mess....
I like the red, looks good.
Old 07-25-2010, 10:32 AM   #964
mac72
I'm diggin' the red cover,it just needs the coils laid on it to mute it down a little. Mac
Old 07-25-2010, 10:54 AM   #965
eagleuh1
eagleuh1's Avatar
I like the red. Just be careful of how many of the liquid refreshments you have while working on the wiring, or it will be a fried mess. LOL. Do you have the part number for the oil pressure cover with the the knob like your using. My Chevy dealer keeps ordering me the plain covers. Thanks. Looking good.
Old 07-25-2010, 06:34 PM   #966
VA72C10
VA72C10
VA72C10's Avatar
Nice progress. I think the red will be good once you have the coil packs on it to break it up...
Old 07-25-2010, 07:29 PM   #967
jbclassix
Junk Yartist
jbclassix's Avatar
since your SC is cast finnished, your valve covers should be cast finnished too. More red, or no red. The lone red valve covers just scream corny.
jbclassix is offline   Reply With Quote
Old 07-25-2010, 07:30 PM   #968
Thealien
Thealien's Avatar
Thats what I was thinking also.
Old 07-25-2010, 08:42 PM   #969
Hart_Rod
Hart_Rod's Avatar
I thought the same thing. It looks better with the coil packs back on it.
Thanks! Any progress on those SB center caps?
Anytime Bro!
You're wish is my command! What do ya think?
, I didn't think anybody saw that. I think you need to be drunk or crazy to jump into the middle of this wiring mess, . I don't have a part number, but I know mine came off of a truck pan. I have an extra one if you can't find one local. Let me know.
Take a look and tell me what you think.
OUCH!!! I see what you're saying, though. Since they're pretty easy to take off, I'll probably wait until everything is together to see how it looks before I change them again.
Tough crowd, .
Old 07-25-2010, 08:48 PM   #970
dan468
dan468's Avatar
I like em!!!
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 07-25-2010, 08:54 PM   #971
VA72C10
VA72C10
VA72C10's Avatar
I think it looks good. Plus, the headers are similar color to the blower so it will break it up just enough while tying it together with the burb.
Old 07-25-2010, 09:30 PM   #972
kvn1011
Kvn1011
kvn1011's Avatar
i agree!! the coil does break it up just enough!! lookin good!!
Old 07-25-2010, 10:54 PM   #973
jbclassix
Junk Yartist
jbclassix's Avatar
maybe paint the fuel rails red too, add a red pinstriping design to the SC snout, black wires (red might not match hues). don't worry, my opinion cant be all that important, I have been told by my smarter half that my black door panels dont match my burb!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
Old 07-25-2010, 11:08 PM   #974
mac72
Looks really good man, I'd leave em
Old 07-25-2010, 11:19 PM   #975
63chevyll
gets board easy.......
63chevyll's Avatar
i have the same Lokar shifter kit, but im having trouble on my wagon, the rod is too short.
How do you like it?
63chevyll is offline   Reply With Quote
