12-27-2009, 04:04 AM | #151 | ||
NEWBIE!!
Re: pics of lwb trucks lowered or bagged
Water is for the weak I don't like cocaine.. I just like the smell of it "Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa VolksRods |
12-27-2009, 11:19 PM | #152 |
ok thanks. ill do that. she sits to high right now
01-03-2010, 08:42 PM | #153 |
Here's my 71 gmc.Z'ed the frame 3'' and dropped the cab mounts 1''.
01-03-2010, 08:57 PM | #154 |
WOW looking good grantos... id love to see the final outcome
1972 Chevy suburban sale |
01-03-2010, 09:09 PM | #155 |
Thanks dragitvinn,it was stock when i bought it a month ago but i'm building it as a rocker laying rat rod.
01-05-2010, 01:31 PM | #156 |
01-05-2010, 04:23 PM | #157 |
When i air it up the tires straighten out.
01-05-2010, 04:54 PM | #158 |
bob nice truck man .
is the rear of your truck bouncy |
01-21-2010, 10:08 AM | #159 |
Love the lowered lwbs...keepem coming. I'll post mine once I lower the rear a bit more. Currently 5/5 drop, trying to lower the back another 2 inches.
01-21-2010, 07:01 PM | #160 |
New pic with bed on
01-21-2010, 09:01 PM | #161 |
I love that color combo.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
01-22-2010, 09:19 PM | #162 |
01-22-2010, 09:51 PM | #163 |
Redefining LowBudget
Alright heres some fresh meat for you to chew on....keep in mind its in the build stage and heres the specs so far and whats planned for it
SO FAR: bagged with a 2 1/2" c notch with Pbar mod, 265/70/15..... up front the stock lca are cupped with 5180 monroe shocks bump/steering stops are gone 235/75/15's the parts get here tomorrow for this rear rallies cut and widened from 8 to 12" for the new 18.5x30x15's... new bed thats getting a tub job moving Pbar to trailing arms and flip the shock mounts for better travel and angle..this will be part of the rear axle swap to ditch the 308's for a set of 373's the front is getting a chop job on the spare X member while the mouse motor (327) gets a new set of Vortecs and a 470 lift cam your going to have to forgive the pics the last one was before the LCA got there new short shocks and new rear sneakers check my build for more pics and yes its still a truck
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-22-2010, 10:44 PM | #164 |
heres mine not exactly a truck but a long wheel base lol. specs are in my sig below.
01-23-2010, 12:20 AM | #165 |
resident oilfield trash
Hey my headers used to live on that truck
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-05-2010, 01:33 AM | #166 |
Too many toys,not enough money
I can play here!!
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336 |
04-05-2010, 02:57 PM | #167 |
I want to play! 3/4 with springs; im thinking about going down another inch in the back but im not sure yet. its getting a new clutch and rebuilt three speed right now though.
68 Chevy C10 long box |
05-18-2010, 11:20 PM | #168 |
Here is mine, just got it yesterday!
07-16-2010, 01:05 AM | #169 |
10-26-2010, 02:46 PM | #170 |
72highlander, You got one good lookin gtruck buddy... Would it be too much to ask to post some pics of the engine and interior.
10-26-2010, 03:04 PM | #171 | |
Big Red - Now its a SWB!
Here are some other threads about dropping with a leaf rear: http://67-72chevytrucks.com/vboard/s...d.php?t=419051 http://67-72chevytrucks.com/vboard/s...d.php?t=403279 You could also go with a flip kit if setting pinion angle and welding up spring saddles doesn't scare you. It will get you about 5-7" without affecting ride/payload, but may require a c-notch.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-26-2010, 09:08 PM | #172 |
Heres my work in progress!!
10-27-2010, 11:47 PM | #173 |
So is 3" safe on the rear with blocks on a coil spring 3/4ton?
Could I go further? Or would I need to go less? |
10-28-2010, 12:56 AM | #174 |
It really depends on you're wheel/tire size. If your running 15" wheels with short tires it may be pushing it. You have to consider "scrubline", which is the height that the truck would sit if you got a flat tire. If the block is so thick that it makes the trailing arm sit below the lip of the wheel and you were driving and got a flat that means your trailing arm and ubolts would be dragging the ground. This would make a bad situation (flat tire) even worse as you were sliding down the road. However if you have a taller wheel 18+" with taller tire you can get away with more because your scrubline is greater/lower. I know it is regular practice to use a 2" block and I have seen some use 3". It just depends on what wheels/tires you're running.
10-28-2010, 01:09 AM | #175 |
16.5 wheels with like a 30" tire, around there.
