Re: Extreme Powder Coating '65 C-10 Shop Truck
Damn day light savings time has me up before 4 ! By spring I should have it figured out just in time to start over sleeping again! LMAO!!!
1961 Impala dash looks great more pictures later today
Same "rat time" Same "rat channel" ?! LOL!
Posted via Mobile Device |
Pics from Lakeside Rods and Rides...
Continued...
Continued...
The right side of dash is not finished, the Vintage air unit used up alot of space. Roger will finish right side dash in the next few weeks. Stay Tuned
Your definitely in good hands.....
How about the Mooneyes gas cap filling in the stock gas tank filler?
Which engine should I run?
327 Bored .030 comp cam / roller rockers or a LS-2 carburated with GM front dist. drive. ASA hot cam ???? undecided ???? Also will be running a T-56 from a 97 Trans Am with 3.73 rear gears ? Both engines will look very Old Skool . What you guys like the trick battery boxes ? Last edited by kart34; 11-25-2010 at 01:42 PM. |
Coooool !
Will you be doing away with the stock glove box on the far right? And do you think if you do you will be using the grab bar from the Impala also? I see you filled in the control area for the hvac from the Impala dash. What are you thinking for that? What are the seats from?
Man this beotch is gonna be F-ING KILLER!!! Last edited by Dirty Doug; 11-18-2010 at 09:39 PM. |
Dirty Doug, The stock glove box door will be gone, we are having issues with the AC unit and we need some type on access door for the AC unit. It was a very tight fit. Roger did not expect that with the Vintage Air Gen.II unit.
The grab bar like on the 62 SS would be really cool ! Just a thought , didn't know if you were thinking about using one or not . What colors will the dash and metal be inside ?
#15 |
The interior rendering by Carter Hickman is posted above. But colors may change. We will powdercoat it stay tuned ????
#16 |
327 ! Use the LS in the wagon. Also when I did the math/calculations on my ElCamino with the T56 and a 27.5 ish tire , I will be able to use a 4:56 gear and only run 2100 RPM at around 75mph , if I remember right. I did the calculation off of a web site 3 years ago. They make a S10 rear with a 4:10 gear. That 6th gear is like a double over drive. But the 327 would be a cooler piece in that shop truck!
#17 |
![]() Join Date: Oct 2009
This is a real nice start, kart34. I am along for the ride. I would go with the 327 for this build and send me the LS.
![]() ![]() Last edited by realnice1s; 11-22-2010 at 11:22 PM. |
#18 |
gets board easy.......
nice wagon,
they are hot these days |
#19 |
Yes, Thanks The Buick has done a great job advertising for my powdercoating shop. It has been featured in Car Craft and Hot Rod mag. plus 2 Good- Guys builder choice awards. More photos on my website and my Hub Garage site.
#20 |
![]() Join Date: Jul 2010
327 get's my vote..i was jus read tha old article on that wagon last night...that thing is sweet is sweet i know this will be tha same & props on keepin it a long bed..
#21 |
327
#22 |
yes kinda thinking 327 also with a little twist ? maybe a Fast EZ-EFI set up but have it hidden under a 70 vette duel snorkel air cleaner?
#23 |
#24 |
Heck yeah on that dash!
#25 |
New Shop Truck Designs By Carter Hickman
Tags |
'65, c-10, carter hickman designs, extreme powder coating |
