#351 |
Re: 85 burb meets 6.0 lq4
That is what autozone lists for them. Just making sure i am using the right plugs.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#352 |
Also have ordered my new engine mount plates. YAY. And all my parts i ordered from gm came in. I ordered dipstick tube, the dipstick, starter bolts and an alternater bolt. Also got my o ring for my oil pump therw them.
#353 |
Truck and auto performance nut
wont be long then.
checked the plugs....AC Delco 41-985...also has 12609877 on the side
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#354 |
Thanks for the numbers.
#355 |
Them plugs are 11 bucks each. What do yall think of this plug?
Autolite-Xp-Iridium/Spark Plug XP5245 http://www.autozone.com/autozone/par...er=896892_0_0_
#356 |
Also i got my new dipstick and tube and starter and alt bolts in today from my local gmc dealer. All i need to do is paint the block and put all back together. My do it tomarrow if i feel better. Hole dang family is sick.
#357 |
seems like I hear of guys using NGK plugs? Something like a TR55?
#358 |
I looked at the ls1tech and it seems that that is a old shcool style plug. The plug number on yours you gave me came up a a iridium plug. I realy want to keep it close to orig. But not spend 10 a plug. With the MSD box i dont know if it matters but my dad used 8 different plug sets in his 4.8 and they were almost all old school plugs and they all ran like crap. His truck just has headers and a programer on it then.
#359 |
Just went and painted my block and while i was there i installed my timing chain and took a plug out. Mine are deff the fancy iraidium type and the number is ngk pztr5a 15 ACDelco 12567759.
#360 |
Have you ever seen the new chevy comersils. They say chevy runs deep. I verifyed that today. I painted my block in....lets say not the optimal area and the inside of my nose was bright orange. I sneeezed chevy orange. I blew my nose and the towle was you gessed it chevy orange... I guess i may have needed to use a mask.
#361 |
Got me a set of plugs tonight. Dang little buggers are pricy. Autolight XP Iridium. The XP stands for Xtream Performance. I guess to all other auto makers chevys are all Xtream performacne vehicles. I guess we will see how Xtream performance they are when i fire this sucker up.
#362 |
New Plugs brings me to my next question. I only have 4 spark plug wires so i need to get a new set. I have been looking a wires on line and have found no good answer to what ones i need to get. One site says camaro wires will fit the next one says they will not fit my lq4. And what brand should i get. Do i need any kind of boot protector cause of my headers?
#363 |
My headers can use the OEM wire/boots. I would stick with a set of wires for a '99up LSx truck (same yr as your motor). Like I said before...the truck coils are different then the car coils...cant say why...just are.
#364 |
I have seen the diff in coils. If you look on autozone and look up one from a 01 camaro and one from a 03 truck the diff is clear. Where the spark plug wire connects is in totally diff position. GMPP has a set of wires that says ls style motors but cant find any thing that says they will work on a truck. I guess i will just get the msd set for a truck.
#365 |
Love the Chevy Orange paint!
I painted my Project Willys engine that color too when I rebuilt it.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
#366 |
I also love the orange color.. I am a firm believer that ever engine needs to have orange on it.
#367 |
Got some work done today that acctually accomplished something.
#368 |
more pics. last too are what it used to be and what it is now.
#369 |
Going to paint the alt, water pump, then install them and hope my pushrods get in by that time so i can do fianl assembly. YAY. Also got balancer install.......and dipstick tube removed. Boy i never what to do that again. It almost did not happen. All 8 holes still have good cross hatching and are not too shiny. Only need wires, adapters for sensors, map sensor, hoses, belt, and i am sure i will find something else. About 200 bucks more wich is good cause it is that time of year again.......xmas time=short on money.
#370 |
Already did.....oil change stuff.
#371 |
looking good!
#372 |
Thanks i seemed to have jacked up the block paint job but i dont think any one will look past the shiny headers to see it. And they really better not be under it. Front looks good tho. Guess that is all that matters.
#373 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#374 |
Good to here. They had better work at 7 a plug.
#375 |
No kidding. I thought the parts guy was pulling my leg when he told me I had to run that type of plug and how much they cost.
