#26 |
C35 Crew Dually
Re: My 84 CC Dually mod thread - there will be plenty of pics
Looks good. what ya doing with the old cab ferrings?
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
#27 |
The racerback? No plans, why?
![]() Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
#28 |
It followed me home?
I like the LED fender lights, more info please
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#29 |
C35 Crew Dually
I kinda like the look was wondering if maby you would like to part with it?
Or maby Santa could bring it to me for Christmas? LOL
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 12-18-2010 at 08:31 AM. |
#30 | |
#31 |
You can buy the strips here
http://www.superbrightleds.com/cgi-b...pecs%2FLB3.htm I then just hogged out the back of the housing, laid the strip in and then sealed everything with silicone. I used silicone because these strips are not waterproof. I did this mod on my old set of lights to try it, when I buy my new lights I will angle the strip a little bit so it shines straight out the back when mounted in the fender. Currently they are mounted flat in the housing so they are brighter when standing a little to the side vs. straight on the rear. Posted via Mobile Device
#32 |
C35 Crew Dually
lol b4 i offer will you ship to canada? I would pay of course
#33 |
I have no problem shipping it to Canada but based on the size of the boxes I bet it's $200 in shipping! ![]() Posted via Mobile Device
#34 |
GoatLube Experss
![]() Join Date: Oct 2009
looks better already .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#35 |
nice,I am gonna follow your build!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#36 |
What kind of steering wheel is that ? It looks reall cool, and what diod you mean by bags just created to much maintenance ?
#37 | |
Between airlines, valves, compressors, etc. Airbags can be high maintenance. Where I am going to towing a big boat I really don't want any problems which is why I opted for a static drop instead Posted via Mobile Device
#38 |
Running boards are gone.
Hopefully the bed will be off tomorrow! ![]() Posted via Mobile Device
#39 |
The bed is off! Now the fun starts!!
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device
#40 |
1) What's the mpg?
2) mpg when towing? |
#41 |
12-14mpg empty, 8-10mpg towing a 10,000lb boat!
#42 |
Never seen anyone pull a truck bed like that. I'll keep those pics on file if you don't mind.
Also, that tan / gold two-tone is AWESOME. Please don't paint it. |
#43 |
I know you said bags can be high maintance,But if you run the back of your truck with helper bags then there is really no issue. Or if you did a 4 link then use an air tank and a leveling valve with a small compressor,you never have to maintance anything except to drian the small amount of water that may build up after a year. Every air tank I use in my projects as well as customer projects have a drain valve in the bottom of the tank. I use air tanks from the trucking industry and they have a pull cable on them so you dont have to get under truck to drain moisture. I also work on Semis and they never have issues with lines and air bags. Just a thought. And when you load the trailer..the leveling valve will add air as needed to set truck as the pre set hieght,when you unhook trailer,it deflated the bag until leveling valve is back to the preset lenght.Not to menchen how much better it will ride when empty. I have Air ride and my own designed 4 link in the back of my 97' cre cab truck. It rides like a caddy! Hope this helps. Cool truck and boat!
Greg "GT" Tholen |
#44 | |
#45 |
I built a 2x4 frame that was about the same height as my truck frame and then with the rear wheels and bumper off I just slid it off the back thats how I do mine
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#46 |
this is a good picture to look at. you'll need to remove them over load stops that are on the frame once you get the shackels in and cut the one support on your bed where the shackle hits it having your bed on saw horses will make that task easy
if you look at your front hanger you can see what I was saying about making a braket and move it up it be easy
#47 | |
#48 | |
#49 |
18 Till I Die
Also, that tan / gold two-tone is AWESOME. Please don't paint it.[/QUOTE]
X2 ![]() Or stay with a 2 tone them....
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#50 |
Man, that's a nice clean truck! Good luck with the project. And the boat... referesh my memory (I feel like you've said elsewhere), but I'll guess Scarab Panther?
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
