Old 01-16-2011, 09:26 PM   #1
Tmend
Tmend's Avatar
Bolt in steering rack
I have 67 that I'm doing a build on. My ? Is does anyone know of a steering rack that would work with very lil if any mods must be done. Thanks
Tmend is offline   Reply With Quote
Old 01-16-2011, 10:21 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Bolt in steering rack
Do you mean power steering, or a rack and pinion that bolts in. No one makes a kit that adds a R&P unless its an integral part of an aftermarket IFS.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-16-2011, 10:58 PM   #3
Tmend
Tmend's Avatar
I ment a rack and pinion.
Old 01-16-2011, 11:12 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
None for a stock/oem cossmember.
Keith
Convert to disc brakes.
Old 01-17-2011, 01:07 AM   #5
Tmend
Tmend's Avatar
That sucks I guess I'll just rebuild and replace.
Old 01-17-2011, 02:06 PM   #6
m6z
m6z's Avatar
There is this....buts it's expensive.
http://67-72chevytrucks.com/vboard/s...d.php?t=417074
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 01-17-2011, 03:22 PM   #7
JNJchev77
Registered Cruiser
JNJchev77's Avatar
^ Yep, this kit is about $3000 or close to that. Comes with new column and a couple other goodies.
JNJchev77 is offline   Reply With Quote
Old 01-17-2011, 04:02 PM   #8
lolife99
lolife99's Avatar
I was unaware that Flaming River had that set-up for the C10 trucks.
For that kind of money I would purchase a Dropmember (www.PorterbuiltStreetRods.com) and gain the additional ground clearance.
(especially now that Nate's adding the option of a "coil over" version to his super popular air bag Dropmember)
Keith
Old 01-17-2011, 04:07 PM   #9
jimmydean
jimmydean's Avatar
You could do a power dropmember for less than just the rack and bracket.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-17-2011, 04:14 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
I was unaware that Flaming River had that set-up for the C10 trucks....
Based on the price I can see why we have never heard of them. Then again, it is Flaming River. Really, really nice stuff, but $$$$
Articles-
"Refining Sierra"
Old 01-17-2011, 04:21 PM   #11
Scottshotrods
You can also price out a Scotts bolt in ifs we have this in a coil-over set up
already and a airbag set up as well.Our complete hub to hub starts at $2895.00
and this comes with all the mounting hardware and parts needed from one supplier.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 01-17-2011, 05:58 PM   #12
SCOTI
SCOTI's Avatar
I thought that kit was for 73-87's?? I know the x-members are interchangeable, but that doesn't mean that set-up could be used on earlier models if so (slight variations in the frame rails).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-17-2011, 06:36 PM   #13
tech@scottshotrods
We at Scotts offer a dirrect bolt in for the 63-87 in coil over or air bag complete hub to hub and have been for some time ask lou santiago what he thinks since he is installing one on his 83 burban right now..
tech@scottshotrods is offline   Reply With Quote
Old 01-17-2011, 06:53 PM   #14
SCOTI
SCOTI's Avatar
Yep, I remember reading that somewhere....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2011, 07:11 PM   #15
Tmend
Tmend's Avatar
You would think being that these trucks r so popular thatbthe after market industry would have came outvwith one by now.
Old 01-17-2011, 07:12 PM   #16
tech@scottshotrods
just makin sure since it seems people are askin about a coil over version...
Old 01-17-2011, 07:59 PM   #17
LUCKIN-FOU
I'M NOT SCARED I HAVE A PLASMA
LUCKIN-FOU's Avatar
I really like the bolt in I got from Scotts' here is some info on it.
1.The cross member is made out of 2x4 structure steel and is made out 3/16 wall thickness. That is 100% TIG welded
2.Upper and Lower A-arm mounting points are made out of 1 1/8 solid bar stock, not tubing.
cross tubes that are 8 inches long and slide thru the cross member and sticks out 2 inches per side on the cross member. There haves never been a problem with this set up and is 100% bullet proof
3. Upper and lower a-arms are made out of 1 1/8 round 1/4 wall DOM tubing. For customers who polished S.S we make them out of 1 1/8 solid 304 S.S
4. The rod ends that secure the a-arms are made out of 304 S.S that are CNC machined in house not china. These have been tested to with stand
180,000 pounds of pressure.
5. All of our mounting hardware as in the bolts are grade 8 bolt and have never failed over the years.
6. Spindles are forged steel spindle we use and we have these either in a stock or dropped spindle
7. Brake calipers are off of a 82-89 Chevy s-10
8. The rotors are a Lincoln Granada off a 77-78
9. The power racks are a 88 Ford Thunderbird
10. Bags are from slam bags
11. If you want a coil-over instead of a bag we use a Alden coil-over
12. The complete frontend is 100 tig welded not mig welded.
Starting price is $2895.00 retail and this is a 100% complete from hub to hub. If you price it out with our other companies who make a bolt in ifs for the c-10 truck we are a almost $700.00 cheaper for a complete bolt on package.
13. The outer tie rod end we use a tie rod end not a hime joint.
14. Keep in mind this frontend is 100% bolt in IFS no welding at all and this is also with our airbag set up as well. No need to notch the frame at all.
Lou Santiago
US Navy Retired/World Traveler
Car Builder/Welder/Airport Investigator
garageinsidertv.com [FORUM]
WORK IS FOR PEOPLE WHO CAN'T FISH. I GUESS I'M SCREWED BECAUSED I HATE FISHING.
LUCKIN-FOU is offline   Reply With Quote
Old 01-17-2011, 08:11 PM   #18
tech@scottshotrods
thanks lou for copying justins post from the c-10 forum :-)
Old 01-17-2011, 08:41 PM   #19
LUCKIN-FOU
LUCKIN-FOU's Avatar
Here are a couple of pictures of the front end that I have. I have put alot of front ends under stuff. I have built a bunch of front ends for different stuff. I like the way this piece fits.
Lou Santiago
Old 01-18-2011, 07:04 AM   #20
n2billet
Village Idiot....
n2billet's Avatar
Q: Why are the inner supports cut in half and then pieced back together (in picture #2) and does it it only have one bolt on the cross member that bolts to the side of the frame? (picture #3)
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 01-18-2011, 11:45 AM   #21
Scottshotrods
These Pictures are not complete and this is only mocked up and Lou does not have all bolts in place in the pictures above.The inner brace was cut in half
to fit the correct width of the 73- 87 frame they are around 3/4 wider than
the 63-72 frames.This was done several months ago at Lous shop and after this was installed we made the changes and inner frame brace is made out of one piece of material to fit the differnce in the frame.
Justin
Old 01-18-2011, 11:53 AM   #22
Tony@AirRideTech
Junior Member
I wouldnt bother with a R & P unless you are completely changing crossmember... it is just a really good way to screw up the ackerman and end up with excessive bumpsteer runout. If a crossmember option is out then look at CPP for an upgraded box and rebuild your front steering. When done right they actually do pretty darn good
Tony@AirRideTech is offline   Reply With Quote
Old 01-18-2011, 02:08 PM   #23
Tmend
Tmend's Avatar
i was looking at cpps steering products they look like dam good stuff. but saving a lil money and going with scotts IFS kit would be perrty nice $$$$$$
Old 01-18-2011, 04:11 PM   #24
robnolimit
robnolimit's Avatar
As luck would have it, we are currently testing a C-10 Rack&Pinion set-up. (67-87) I'll let you know when were done. So far it fits very nice. 2.75 turns lock-to-lock. Full steering to 40 deg (same as stock). .136 deg bump-out in 4" of compression travel, and .166 deg bump-out in 4" of droop. This mod will require some cutting and welding on the crossmember. We are working on the install templates, and machined adjusters for the TRE. --- SOON, VERY SOON.
robnolimit is offline   Reply With Quote
Old 01-18-2011, 04:16 PM   #25
Tmend
Tmend's Avatar
nice i would love to see this set up. it would be a great add-on to someones build whos not looking for a complete IFS kit but yet wants the modern rack..please do keep us posted..
