01-19-2011, 08:36 PM | #1 |
Project Pro Touring "Ole Blue"
Well...I guess I should start a build thread. I'm working on my '64 C10 that I'm building as a pro touring style truck. It actually started out as a C20 long bed step side, but when I'm done, it will be a 1/2 ton medium* bed fleet side.
*Instead of the typical 12"/8" chop, I'm going to do a 9"/6" chop Here it is at it sits now: I'll start posting pictures of what I have done already and explain it as I go
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
01-19-2011, 08:39 PM | #2 |
Re: Project Pro Touring "Ole Blue"
Here is where I started after tear down:
01-19-2011, 09:08 PM | #3 |
Hey another kansas guy...Nice rig cant wait to see it come along,but one question? Are you talking choping the top?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-19-2011, 09:09 PM | #4 |
Here's some pictures of the work on the front suspension
One of the lower arms I fabbed up (I need to modify the ball joint plate and angle it up to keep the ball joint from binding ) One of the upper arms jigged up, ready to weld Mounting the steering box Front suspension mocked up I built the arms with the ball joints moved forward to center the front wheels in the wheel wells and I also set it up with increased caster (6* base) with the option to go +/-2* besides the normal adjustment available. I'm running 2.5" drop spindles with the 1.25" thick rotors and Wilwood D52 calipers (thanks Jon ) The way I mounted the steering box it actually raises the center drag link approximately 0.75" from the stock '84 front geometry, so I'm hoping I can juggle thing around to reduce bumpsteer as much as possible.
01-19-2011, 09:12 PM | #5 |
Actually no, I was referring to the 12" removed out of the front and 8" removed out of the rear of a long bed to make it a short bed I've always thought that the short beds were just a little too short, so I'm goint to go 9" in the front and 6" in the rear to make it proportional and hopefully look right to me
01-19-2011, 09:15 PM | #6 |
OK I was wondering... What do you do for a living? Nice arms...
01-19-2011, 09:19 PM | #7 |
Well...I'm just a mechanic (over 10 years already ) but I love doing fab work in the evenings and I love the challenge as well. I'm excited about working on this project because it was actually my first car, so I've got a bit of a sentimental attachment to her too
01-19-2011, 09:24 PM | #8 |
67-72 parts collector,…
Subscribing to this one!!!
01-19-2011, 09:33 PM | #9 |
You must have access to some nice tools...Those arms are pretty nice pieces. I used to be a mechanic also but got tired of leaning over working on things so started welding and never looked back. Ill be watching this one.
01-19-2011, 10:29 PM | #10 |
Truck and auto performance nut
Nice work! I have a question tho...did you weld that steering box to the frame?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-19-2011, 10:38 PM | #11 |
Looks like a pipe notch to me. I thought that too when I first seen it.
01-19-2011, 10:41 PM | #12 |
Thanks for all the comments, and no, I didn't weld the steering box to the frame. I used the lower rear bolt hole on the frame and figured the angle the box needed to be and made new holes for the power box. What you see in the picture is the backside of the notch I made to clear the box so I could mount it straight on the frame. I did that instead of buying an adapter plate because I wanted the idler arm and the pitman arm to be parallel when going straight.
As far as having nice equipment goes, I have the basic welder/grinders/etc, but I do have an awesome buddy that works at a metal fabrication shop building industrial equipment. All I have to do is draw something up (measured drawing) and tell him how thick of plate I want and he cuts it on there cnc plasma cutting table . It sure helps make things look so much more professional I'll post up some pictures of the rear suspension tomorrow, and you can see some more of his work too.
01-19-2011, 10:43 PM | #13 |
Beat me to it I'm a slow typer.
01-19-2011, 10:53 PM | #14 |
A little more information:
The tires are 275/40ZR17 for the front and 315/35ZR17 for the rear. I'm planning on buying Billet Specialties Street Lites in 17x9.5 and 17x11 to go with those. To go with the Wilwood front brake calipers, I also bought a set for the rear too. I also bought a set of brake rotors (Astro van fronts, thanks Captainfab for the idea ) What the heck, here's a picture of the rearend with brakes on it and a teaser of my watts link setup
01-19-2011, 11:05 PM | #15 |
Resistance is Futile
Nice work mech77!! Love the mock-up shot; truck looks good and cant wait to see more.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-19-2011, 11:09 PM | #16 |
Thanks, I can't wait to get the cab off so I can cut the frame down and mock it up at the correct wheelbase
01-20-2011, 11:25 PM | #17 |
Here is some pictures of the rear suspension almost done
And some pictures of the trailiing arm brackets that I'm going to mount up I'm not going to mount those brackets up until I get the cab off because I'm going to flip the crossmember to gain some driveshaft clearance when it's aired out
01-20-2011, 11:28 PM | #18 |
Here's some better pictures of my watts link setup
I'm thinking I might swap the 1/2" rod ends and links out for some 5/8" ones and I haven't machined the center pivot for the bearings yet.
01-21-2011, 12:50 AM | #19 |
I like it!
01-21-2011, 01:18 AM | #20 |
Finally... somebody building a watt's link like they are SUPPOSED to be set-up!!!!!
Looks like a cool project!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-21-2011, 10:07 AM | #21 |
Thanks porterbuilt, that means alot coming from you, I've been admiring your work for a while now Do you think the 1/2" rod ends and links are strong enough? I'm having trouble finding any good technical info on watts links. I've looked at quite a few other companies watts links and none actually list what size rod ends they use, but it looks like some of them use as big as 3/4" rod ends. I'm probably just being paranoid, but if one rod end breaks, I'm most likely going to crash I have enough material on my mounting points that I could upgrade to 5/8" rod ends, and I may do that to ease my mind
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 Last edited by Mechanic77; 01-21-2011 at 10:09 AM. Reason: grammar |
01-21-2011, 04:07 PM | #22 | |
Nate
03-05-2011, 04:08 PM | #23 |
I finally got internet at home, so an update and some more pictures are coming....very soon
03-05-2011, 04:27 PM | #24 |
Ok, here's an update for everyone....frame is now 9" shorter in the middle and 6" shorter on the rear. The suspension is all but done The only significant things left to do on the chassis are gusseting (sp?) the frame where I shortened it, build the support for the motor mounts, and triangualting the chassis to try and reduce torsional flex as much as possible.
As it sits right now engine and transmission in the chassis pic of front suspension (done ) rear suspension done other than swaybar links (too long) If anyone wants to see something better, just ask and I'll see what I can do
03-05-2011, 04:29 PM | #25 |
One thing I forgot...I did upgrade the watts link rod ends to 5/8", it's hard to see in the pics.
