01-31-2011, 07:57 PM | #451 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Frame is painted.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
01-31-2011, 08:08 PM | #452 |
Pics are required! (You know that!)
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-31-2011, 08:14 PM | #453 |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
02-01-2011, 12:33 AM | #454 |
The only pics are of the primer, too foggy in the "booth" to get new pics of the chassis black.
Check back tomorrow.
02-01-2011, 01:10 AM | #455 |
VA72C10
Thanks for the pics....looking good!
02-01-2011, 01:29 AM | #456 |
Still Learning
Hey, that frame looks great! you are kicking some serious tail on this build! Keep the pics coming!
02-01-2011, 01:46 AM | #457 |
Thanks! Gotta get er done.
02-01-2011, 01:49 AM | #458 |
i dont think gm painted there frame this well nice job drew your lucky you can run all the rims that we cant because that frame!
02-01-2011, 02:29 AM | #459 |
Its always great working on a nice clean frame. You are not going to want to put on any old dirty parts, or that could just be me. I always have to put in new bolts, and they seem to always be the gold colored ones.
Looking good, and it looks like you bought your booth at the same place I buy mine from. They work well, but when you use a real booth, its tough to go back. darren
67- 72 Parts collecter |
02-01-2011, 06:52 AM | #460 |
looking good hometown
02-01-2011, 10:41 AM | #461 |
Satin Chassis Black by Eastwood.
Next we will be sandblasting the bottom of the bed, inside of bed, and priming/painting both.
02-01-2011, 11:08 AM | #462 |
You make it look so easy. I find myself reading your build instead of building mine. LOL Great job.
02-01-2011, 11:14 AM | #463 |
I do that myself on occasion, and then I'm mad at myself for wasting time. It's not really wasting time, more like research to get new ideas or see how its done. I will say also, it sure is nice to have roomy place to work and the right tool for the job at hand. Keeping the frustration low keeps you on task and motivated more. I am very blessed.
02-01-2011, 02:11 PM | #464 |
You ought to come by and check it out sometime.
02-01-2011, 04:58 PM | #465 |
6>8 Plugless........
Drew, it looks great, nice job.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-02-2011, 12:49 AM | #466 |
Ride height, Show height? I hope.
May not be possible, but a guy can still hope right?
02-02-2011, 01:00 AM | #467 |
VA72C10
Nice!!!
02-02-2011, 01:20 AM | #468 |
This build totally rocks I had thought about this idea abround 15 years back when I was single and had less bills(ha ha ha). It is a great idea and Completely RULES. Keep it going and Hang tough. God bless.
02-02-2011, 05:59 PM | #469 |
Working on getting my high hump installed. Does anybody know how the factory cut out the low hump? Is there an indentation of where to cut? I'd like it to look factory.
02-02-2011, 06:16 PM | #470 |
Don't quote me but can you place the high hump over the low hump and trace the perimeter? may help to draw a line around the edge then scale inward the width of the flange?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-02-2011, 06:18 PM | #471 |
+1, but just spray paint the outline and the holes......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-02-2011, 06:21 PM | #472 |
02-02-2011, 06:22 PM | #473 | |
02-02-2011, 06:30 PM | #474 |
Same way I think ....
02-02-2011, 06:40 PM | #475 |
Still plays with trucks
My old high hump truck looked like they punched the hole out when the floor was stamped. The cut was very clean and uniform. The square receiver nuts were spot welded in place on the floor pan.
I am considering using nutplates instead of welded in place fasteners on my 69 C20 high hump conversion since the bead of seam sealer will make up for the thickness of the cage and the hole can be oversize a little to allow for some margin of error on installation.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
