Old 02-14-2011, 10:37 AM   #76
steelscout
Words under my name
steelscout's Avatar
Re: Fuel filler options
WOW lots of cool ideas!!!! Wish some one thought of this stuff at the dealer while they were installing my saddle tanks on both sides......pretty ugly IMO
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 02-14-2011, 02:18 PM   #77
smokeater05
smokeater05's Avatar
Fuel tank
Hey Hart Rod what gas tank did use for your truck? I love your idea! I will be going to Home Depot and get me two if them. I think I might go this way and do dual 21 gallon 74 truck tanks.
smokeater05 is offline   Reply With Quote
Old 02-14-2011, 02:24 PM   #78
Hart_Rod
Hart_Rod's Avatar
Re: Fuel tank
They come in pairs, . It's similar to a FuelCellguy tank, but with a deeper sump and a rear feed line.
Hart_Rod is offline   Reply With Quote
Old 02-14-2011, 03:31 PM   #79
FL71C10
Originally Posted by weircc View Post
here's mine hope this helps
I really like that, can you give some more details? Like what kind of cap that is, etc?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-15-2011, 11:55 PM   #80
BP68
BP68's Avatar
http://67-72chevytrucks.com/vboard/s...=269999&page=4
Check out post 92 for some good pics of mine. I gave my bodyman some pics and details, and this is what he came up with.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 02-16-2011, 01:29 AM   #81
AirSpeed
AirSpeed's Avatar
Originally Posted by roughedup72 View Post
heres mine
I've been thinking of using a fuel door like that in the stock location when I repaint my 69 C 10, has anyone done one like that?
AirSpeed is offline   Reply With Quote
Old 02-16-2011, 07:30 PM   #82
RaceAGMC
RaceAGMC's Avatar
How about some finished pictures of that mod? Are you running trim? Did you have to enlarge the hole for clearance?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 02-16-2011, 09:13 PM   #83
chuck3026
chuck3026's Avatar
One more...stepside
2006 Crew cab Z71
1972 Short Wide Step (under construction)
chuck3026 is offline   Reply With Quote
Old 02-16-2011, 11:20 PM   #84
Critter
Future TOTM Winner
Critter's Avatar
^ That's SHARP! Great idea.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-17-2011, 12:09 AM   #85
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Here's one I saw in an ad just today...
The wood panel is motorized, and it can allow access to air pumps etc, too.
Link
Zoomin is offline   Reply With Quote
Old 03-16-2011, 05:46 PM   #86
lakeroadster
My Stepside.. Filler is under the bed rail, in front of rear stake pocket.
lakeroadster is offline   Reply With Quote
Old 03-27-2011, 10:58 AM   #87
lakeroadster
Here is a nice fuel filler install on '66. Saw this one on Ebay Hugger Orange 1966 SWB Fleet
Old 04-09-2011, 08:22 AM   #88
lakeroadster
Here is a step by step DIY for a side marker light filler on a '68 stepside:
http://67-72chevytrucks.com/vboard/s...699#post599699
Old 03-08-2014, 09:13 PM   #89
texman
Hi I am wanting to do this very thing any info you could give me I would appreciate it thanks steve
texman is offline   Reply With Quote
Old 10-10-2014, 11:36 AM   #90
Coursey
Coursey's Avatar
Nice Ideas Here
Coursey is offline   Reply With Quote
Old 04-13-2016, 10:46 AM   #91
JG67
Originally Posted by superchevy View Post
Here's mine.
Nice!
JG67 is offline   Reply With Quote
Old 04-13-2016, 10:48 AM   #92
JG67
Originally Posted by pdr510 View Post
Here's mine.
Clean install and blends in.
Old 04-13-2016, 03:26 PM   #93
n2classics
I used a Hagen flat retractable door. Mounted it in the rear inner fender. This picture does not show the door installed. Very clean look, but slow to fill.
John
n2classics is offline   Reply With Quote
Old 04-13-2016, 04:23 PM   #94
mcbassin
Still Learning
mcbassin's Avatar
I followed HartRod's idea and used the marker light filler:
LINK
Old 01-16-2019, 12:59 PM   #95
howell57
I've considered all options, but yours seems the simplest. Exactly where on the wheel tub did you put your hole. I've seen low back side and directly center on top.
T
KX
howell57 is offline   Reply With Quote
Old 01-16-2019, 03:27 PM   #96
Ironhorse
Ironhorse's Avatar
Not sure if I posted any pics of this set up elsewhere or not so went up to the shop and took a few of what I have. The fuel fill itself came from a 90s Chevy Lumina. Also had to fab a copper elbow I got from a plumber friend of mine to get the correct turn towards the under bed tank. Used fuel hose for both fill and vent lines. The fill cap is centered on the left driver side wheel well hump at about 12'' up from bed floor.
Fills quick with no burping at all. The hose for the tank vent I routed up over the wheel well hump using strap clamps and existing bolt holes. Did this about 10 years ago or more so and have been very pleased with it. Simple but effective.
Hope it helps.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-11-2021, 02:17 AM   #97
HeavyHauler
Originally Posted by Hart_Rod View Post
Here's mine. No cuttin or welding on the bed....
Hey I am trying to figure out how you made that hinge work as I like the idea.
How did you attach your hinge to your side marker light? Did you epoxy the hinge to the side marker?
And what does your U- bracket that you made attach to?
I sure would appreciate any input and thanks. I PMd you also about it.
HeavyHauler is offline   Reply With Quote
Old 10-12-2021, 01:28 PM   #98
Hart_Rod
Hart_Rod's Avatar
http://67-72chevytrucks.com/vboard/s...er+fuel+filler
