chevy runs deep
Truck dont wanna start
![]() Posted via Mobile Device
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
BAD BOW-Silverado XST
Re: Need help ASAP idk what 2 do next
Pour a little fuel down the TB. Does it run for a few seconds? If so you have a fuel pressure problem. TBI's are very sensitive to fuel pressure loss.
If you have spark and fuel then I would say check your firing order again, or maybe somehow your timing got messed with during all the work you did.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
chevy runs deep
Thanks guys gonna check it out 2 morrow could air get into the fuel lines when I changed out the fuel filter And that's what causing not 2 start
Air in the line shouldn't be a problem, the regulator sends excess fuel back through the return line and that should purge the line.
Check your ignition - you probably have something wrong. You swapped a lot of stuff, there's plenty of room for error. |
#6 | |
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
Did you put oil back in it? Fuel pump wont turn on until oil pressure switch has pressure on it.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
chevy runs deep
Yeah that was the first thing I did was change the oil, when I got off work 2 day I messed with it but no luck ![]() Posted via Mobile Device
chevy runs deep
And where is the oil pressure switch located
i would tripple check your plug wires. did you plug your distributor back in?
chevy runs deep
Got it running
what was the solution?
chevy runs deep
at least the fix was free.
