add air conditioning ? 1972 C10
Any suggestions, advice for adding air conditioning to a 72 c10 currenty without...preferable on the least expensive side...
and don't say roll the windows down...lol or chop the top! |
Re: add air conditioning ? 1972 C10
Start piecing it together from junk parts here and there? (ebay)
gather everything you need and then cut the firewall and weld in a ac panle and then cut the holes in the dash
Rottenwood Garage Member
Buy a $500 donor truck with AC...take off what you need and scrap it out. You will get most of your money back. You will probably find though once you piece it all together, weed out the bad stuff and juice it...You will be withing a few hundred dollars of a new systyem that will be right! A generic under dash unit may be your cheapest route!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 02-27-2011 at 05:24 PM. |
Restoration Virgin!
There's a whole setup for sale on the parts board right now
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=449337
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 02-27-2011 at 08:19 PM. |
![]() Join Date: Oct 2009
I put a factory system in my 71 last year, mostly using parts I bought from the forum, but a new compressor and condenser from Vintage Air. It works well, and there's no way to tell the truck wasn't A/C when it was built. But, it was not cheap! About the same cost as an aftermarket kit.
IMO, it comes down to whether you want fresh air (none of the aftermarket kits have fresh air intake; all factory set-ups do) and whether you care about the way it looks.
1971 C10 Longbed, 350/TH350 |
just bite the bullet and buy a vintage air unit
![]() Join Date: Feb 2010
I'm looking at doing this in the future ( since it hits 115 degrees here in the summer), is it worth swapping it all into a non a/c cab or should I watch for a reasonably priced complete cab?
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold 1971 Cheyenne 2wd Lwb 350 4 speed Sold 1972 K5 blazer 4WD auto A/C |
![]() Join Date: Feb 2001
If the factory look isn't important than go with a aftermarket unit. JMHO
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#10 | |
RAT1968 '68 Cab/'71 Parts
I'd be all over the one on the parts board. That looks like a great deal.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 03-02-2011 at 02:20 AM. |
#11 | |
Had the OEM Compressor, Woiring Harness, everything. I had to buy a new Head Unbit, Rebuilt Compressor, (My Cab was already AC). I had a professional do mine. Final bill was about $700.00.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
paying the premium for a new modern system will end up cheaper in the long run
40 year old ACsystems drain ALOT of power and gas mileage compared to the newer modern systems of today
the boat guy
I'm pretty sure it cost about the same to rebuild old stock stuff as a new vintage air setup. Alot less hassle and looks cleaner to just get new stuff.
![]() Join Date: Jan 2001
The BEST thing you could do is go all OEM. Piece it together and just graft the firewall portion from a donor truck. Very little fabrication needed. The only real cutting is for the ball and upper center vents which, you would have to do anyway using the cheesy plastic louvers supplied by the after'mkt folks.
It will work better and you will be much happier....trust me I have been there and done that! If you do go with the original POA system (which I strongly suggest you do, DO NOT remove the POA in favor of the "El Cheapo" **POA Eliminator** kits that you have seen. Re-calibrate the POA to 27PSI for use with 134A (if you go that route) and get a good pump. I am using a Sanden 5-cylinder unit myself but if you want to keep it OEM'ish you can get a good dual-lipped front seal A-6 compressor or the new style The Pro6TEN Compressor which utilizes all of the OEM hoses in the stock location. Get a good parallel flow condenser with the maximum surface area as you can stuff in there. Some of the after'mkt folks have these in the correct size and configurations. Put all of the factory components in right down the the cowl flapper. This will put you way ahead of the rest of the pack (with the exception of this author ![]() Your dollars, your decision. Bud Last edited by 69sixpackbee; 03-02-2011 at 02:59 PM. |
#15 |
Moderator
![]() Join Date: May 2007
This is your solution if you go all OEM. I used this compressor and it works fantastic.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#16 |
Awesome! thanks again guys!
#17 | |
![]() Join Date: Mar 2011
#18 |
Old School
When the switch/lever is on fresh air it is bringing fresh air from outside the car whether it be hot or cold. When it is on recirculate, it is just recirculating air from inside the car with none coming in from outside. This is the nice thing about OEM systems. On most underdash units, there are no provisions for bringing air in from outside. All air is just recirculated. The system I have been looking to use is pieced together using a 1999 compressor, 1975 Cadillac condensor(huge), and an older underdash unit. Don't know how this is gonna work together just yet, as I have not gotten to that phase just yet.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
#19 |
Quit if it's not FUN!!!
http://www.nostalgicairparts.com/air...system-351.php
Bought a '70 with one of these. seems to work well, but no hot weather yet! Last edited by TobyArnot; 03-06-2011 at 09:22 PM. |
#20 |
Old School
[QUOTE=TobyArnot;4534587]http://www.nostalgicairparts.com/air...system-351.php
This is exactly the same one I am installing in my truck. It appears it requires a small modification to the heater box.
#21 |
![]() Join Date: Nov 2010
I'm doing the donor cab thing, I think I'm going serpentine settup. The parts will mostly be over the counter if I'm on a trip and things go south. I'm gonna adapt the new compressor and lines to make it over the counter-non special order parts. The only thing is in old cabs, is the Cond., Evap., and lines need to be cleaned(Rx11 flush) and pressure checked(nitrogen not air)and maybe replace TXV to go with 134-A. Just remember compressed air is almost putting water back in the system. Just a thought.
#22 |
sharp as a marble
![]() Join Date: Jan 2007
I agree, I have done several A/C installs. I like Classic Auto Air. ICEY COLD when done.
#23 | |
Posted by BOZO:
The PO installed the unit and kinda went over board on cutting the ductwork. I was able to repair the over-kill and get everything working O.K. Good Luck! Toby |
#24 |
Oh yeah, run the vacuum pump till it stops the girgling noise. If it still makes the girgle sound, you probably have a leak.
#25 | |
Old School
And to the fellow who started this thread, I apologize. It seems I/we highjacked your thread. I didn't intend to.
