Old 03-07-2011, 09:19 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Redneck Removal
Ever have one of those trucks that you are going to pull a motor and you know nothing is going back in. That's right.......get out your sawzall and your side cutters. Easiest motor I ever picked. Noticed I opened up the birth canal a bit????
The hoise wouldn't move in the gravel so I had to take a 2x8 board and kept prying up on the bumper to inch it back as I hoisted.
It looks like the bottom of the motor and the trans had just been detailed so that will make working on it a snap!!! LOL
prostreetC-10 is offline   Reply With Quote
Old 03-07-2011, 09:23 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Redneck Removal
Yup, I cut the nose off a van 1 time to pull the motr & trans Looks like you have a spare BB crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-07-2011, 10:33 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Redneck Removal
Worst I have ever personally done is use a wrecker to rip the entire front half off a motorhome to get the 454 out. It was actually with another board member on here a few years ago.
Yes, that's the entire dash sticking out the front of the motorhome. We wrapped a chain around the entire front end and yanked with the truck.
Worst I've seen was a guy was giving away a 440 Mopar before he scrapped the car. My buddy used a front end loader and a chain to jerk the engine out. When I say jerk it out, I mean just that. He used the loader repeatedly to jerk the car off the ground until the engine finally ripped completely out of the bay. He unhooked nothing, no wires, exhaust, mounts, nothing. It was a noisy process. All he had to work with was the tractor and a chain. The guy was on the way to the scrap yard with it so it's the best he could do to get it out. Wish I'd have videotaped it though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-07-2011, 10:34 PM   #4
72 tigger
72 tigger's Avatar
Re: Redneck Removal
I had a Ford courier beater with a 2.3 that I parted out. A guy came to drive it & hear it run- he wanted the engine & trans. He gave me $150 & said he'd come back to pick it up when I got it pulled- I said stick around for a 1/2 hour & it'll be in your truck. You can disconnect a lot of things in a hurry with a torch & side cuts! It was fun!
72 tigger is offline   Reply With Quote
Old 03-07-2011, 10:40 PM   #5
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Redneck Removal
Whats the story on the rest of the truck? Looks like some decent sheetmetal on the front clip? What size BBC is that?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-07-2011, 10:42 PM   #6
ratrod67
ratrod67's Avatar
Re: Redneck Removal
[QUOTE=Tx Firefighter;4537401]Worst I have ever personally done is use a wrecker to rip the entire front half off a motorhome to get the 454 out. It was actually with another board member on here a few years ago.
That almost looks like shane(bbs1965).
ratrod67 is offline   Reply With Quote
Old 03-08-2011, 01:42 AM   #7
prostreetC-10
My Carbon Footprint
Re: Redneck Removal
It's kind of like a motor merry-go-round. That motor, which is a 396, is going in the truck below. The overkill 454 is coming out of the 3/4 and going in the camaro even father down. I built the 454 for the truck with the hay about 3 years ago. Everytime I drive it I laugh at how overkill it is for what the truck gets used for. I mean that thing rips. Bought the Camaro for $500 last week. As many of your know I have a little Holley business I have fun with a needed a tester car for my upper end carbs. Not even a dyno can simulate how a carb is going to act like being on an acutal motor on the street. I had a major score happen yesterday. Just happened to jump on craigslist and found a guy selling the axles out of a 70 bronco do to some upgrades he was doing. I snatched the rear one up immediately. Just happens to be a big bearing Ford 9 inch with 4.11 gears and factory locker. Get this.......paid $250 for it!!!!!!
TX Fighter.....bet that block was a 4 bolt main huh? Many to most motorhomes got those.
I think something that would be super cool to do to SOMEONE ELSE'S car would be to chain the living daylights out of the front and get going in reverse as fast as you can until the chains get tight. Rip the motor right out of the front. lol
Old 03-08-2011, 02:27 AM   #8
darush01
Re: Redneck Removal
At my buddies yard we cut the front end off of the big block vehicles all he has left are dodges so the are mostly 440s and we use the backhoe to pull the motors once we cut the truck up
darush01 is offline   Reply With Quote
Old 03-08-2011, 03:11 AM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Redneck Removal
I was pulling the motor out of a junked ranger once and all I did was take the motor mounts loose and the bellhousing bolts out then I hooked a crane truck (for pulling out well pumps, its what I used to do) to the engine and lifted till the front tires were about a foot off the ground. Then I stood on top of the engine and shook it till the tranny popped free, and took a sawzall to all the remaining lines/wires/exhaust. Took about 45 minutes to get it out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-08-2011, 03:14 AM   #10
prostreetC-10
My Carbon Footprint
Re: Redneck Removal
BTW.....the pic of the Camaro is NOT in front of my house. That was the house I got the car from. Looked like a darn wrecking yard in the front yard. lol
Old 03-08-2011, 04:07 AM   #11
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: Redneck Removal
prostreetC-10
thats exactly what the PO did to the 68 gmc i purchased. he wanted the engine and tranny for his jag
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 03-08-2011, 07:51 AM   #12
Tx Firefighter
Re: Redneck Removal
Hey man, we don't judge
Old 03-08-2011, 12:03 PM   #13
clos69
Its Topless Season!!!!
clos69's Avatar
Re: Redneck Removal
Your thread title wouldnt be complete with a pic like that
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 03-08-2011, 01:44 PM   #14
mrein3
mrein3's Avatar
Re: Redneck Removal
Long before cellphone cameras and cheap digital cameras I saw this:
70something Impala at the crusher's yard. The fork lift that lifts the stuff to the crusher used the two spears to peel back the hood. Chain around the now gone hood and around engine. Lift engine/car and shake up and down. Who needs an engine?
Kinda like what Tx Firefighter described in the bottom of his first post.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-08-2011, 08:17 PM   #15
crushermechanic
crushermechanic's Avatar
Re: Redneck Removal
http://web.mac.com/tupat/iWeb/Pember...%20Puller.html
check this out. i have installed 2 of these on loaders. it takes about 30 seconds to pull the engine.
crushermechanic is offline   Reply With Quote
