Old 03-10-2011, 08:44 PM   #1
Glennerd
Glennerd's Avatar
Olds powered 72 GMC
Just recently bought this truck from a friend, and it is registered as a 72 gmc. He threw in some grille and headlight chrome with the purchace and put a fender on the drivers side that had been smucked. The replacement fender isn't the same as what he took off. The fender he put on matches the chrome trim that I have but not the other fender that was un-damaged. Did someone put chevy fenders on this thing at one time? I will post as many photos as I can. pls help and thx.
Glennerd is offline   Reply With Quote
Old 03-10-2011, 08:59 PM   #2
Glennerd
Glennerd's Avatar
Re: Olds powered 72 GMC
A couple more shots and a rad question. My old rad packed it in and I had this brand new 3 row from a 67 beaumont (malibu). Although it isn't as wide, it will go in with a couple tweaks. The original fan shroud is a maybe, most likely not. Any thoughts? The rad drain is located on the bottom of the rad pass. side, so that is why it is tilted. Have to drill a 2" access hole if I can use it. Apparently the 3 row rad I have, cooled the BBC's in those cars?
Old 03-10-2011, 09:07 PM   #3
67chevy1series
67chevy1series's Avatar
67 chevy fenders= 67 gmc fenders
68 chevy fenders = 68 72 gmc fenders
69 72 chevy fenders = nothing in gmc
you have a 68 72 gmc/68 chevy fender on the passenger and a 69 72 chevy fender on the drivers side
67chevy1series is offline   Reply With Quote
Old 03-10-2011, 09:25 PM   #4
Glennerd
Glennerd's Avatar
Thank you 67! Ok, the chrome I have in the truck bed is also chevy?
Old 03-10-2011, 09:47 PM   #5
67chevy1series
your welcome the chrome you have is for gmc so all you need to do is get a new 68 chevy or 68 72 gmc driver fender and your set
Old 03-10-2011, 11:02 PM   #6
Glennerd
Glennerd's Avatar
Thanks again. More swapping and trading I guess.
Old 03-11-2011, 10:14 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Great info there Rick....nice follow-up to help out a new member!!!
Glennerd.... to the boards from NC
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-11-2011, 12:57 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board nice looking truck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-14-2011, 09:05 AM   #9
Glennerd
Glennerd's Avatar
HUGE thanks again, Rick! Found the correct fender, glovebox and a free vintage roadside spotlight, all for $40. It's great to have questions answered by people who know thier stuff!
Old 03-14-2011, 10:18 PM   #10
truckster
truckster's Avatar
I'm glad you scored the parts, but your title was "Olds powered 72 GMC" and you didn't tell us anything about your power plant. This Rocket lover wants to hear details.
truckster is offline   Reply With Quote
Old 03-14-2011, 11:48 PM   #11
Glennerd
Glennerd's Avatar
Pardon me folks. Sadly I don't have much great news about the engine. From my understanding, the motor only has about 15,000 miles on it after a complete rebuild "BUT" it's a 1977 350 block. First year of the less desired, low nickle content, lightened main support blah blah. The engine is cammed a fair bit, but I have no specs on it. Just purchased a billet HEI dist. last week (truck now has points) and a week before I bought it the previous owner put in a streetfire multi spark w/rev limiter, msd wires, flamethrower coil (that I don't need now), new exhaust from collectors back w/magnaflow mufflers and new rotors/drums and brakes. It sounds great and it will fry the tires right off from a stand still all day long. I bought the truck last year and drove it for an hour before the tranny emptied out on me. It has been parked since. Now it has to be finished properly. I have a couple photos and one is of the driver's motor mount. If you look close, you can see that the install expert collapsed the front header tube to make room around the mount. I have a new 350 tranny so I'm gonna pull the headers to make some room for the swap, pull the dent and cut the mount a bit where it needs it.
Old 03-14-2011, 11:56 PM   #12
Glennerd
Glennerd's Avatar
Kinda screwed up on the photos. When I washed the motor, most of the "fresh paint" came off. Any suggestions on prep and paint to clean it up a bit? Not very familiar with the newwer products.
Old 03-15-2011, 03:28 PM   #13
jasons
not enough hours in the day
jasons's Avatar
The trim you have is mis-matched. The upper grille trim is for 69-72 to match the hood you have. The fender trim in the photo is driver side for 67-68. The 69-72 GMC's had wider trim on the fenders to match the upper grille piece.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 03-17-2011, 11:30 PM   #14
Glennerd
Glennerd's Avatar
I need to change out the tranny so the headers came out of the way and got media blasted and repaired ( kind of a hack job on the driver's header. Decided to clean and paint. GM blue is the correct engine colour, but I bought it thinking it was a rocket. So it's gold now! Ha ha! It's kinda over the top I think, but it's done.
Old 03-18-2011, 06:21 AM   #15
crazy longhorn
Fabricate till you "puke"
My Oldsy loved me.....mid 90's I ran a 461 in my longhorn. .030 over,TRW pistons, polished & peened rods,arp bolts....a hard sot after forged crank, nice balance job, nice street/strip Engle cam,Torker intake/800 DP holley,big valve C casting heads(all the blend work done by a fat man with a beard) the old truck ran a set of hedmans(a body, & the rails still wear the scars from the fit on the tubes.She ran a hy volume pump, main restrictors,& all the chit that Mondello reccomended......Man did that lill bioch run! 400 turbo/24-2500 stall, 3.40 gears......at 125mph, the ? was always, will it ever quit pulling! Dont ever underestimate an Olds, but if you start building,be ready to lay some coin downcrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-18-2011, 07:14 AM   #16
71C10SWB
71C10SWB's Avatar
Don't worry about the color man. It's still a Rocket.
Ought to do this to mine. I have a few Olds motors laying around.
Nothing much better for good cheap torque.
71C10SWB is offline   Reply With Quote
Old 03-18-2011, 07:53 AM   #17
cam.man67
cam.man67's Avatar
Sweet truck, gotta love them olds motors
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 03-18-2011, 10:08 AM   #18
Glennerd
Glennerd's Avatar
Thank you very much for the compliments, guys! To be quite honest, I have had some regrets about the purchase. Not when I initially bought it, but more after I started going through it and realizing how much was not up to par. The interest people have shown in my truck (I want to call it a project) has changed the way I am looking at this now. I bought a pair of chrome valve covers that say rocket on them for a dozen beer (actually drank 6 of them myself before I loaded them in my truck). Looking for a better idea on the cheap. Sand and paint the covers I have now and find decals? Not sure. Ideas with cheap in mind would be cool.
Old 08-25-2011, 10:28 AM   #19
Glennerd
Glennerd's Avatar
Some more recent pics of my?
Old 08-25-2011, 10:30 AM   #20
Glennerd
Glennerd's Avatar
And a couple more.
Old 08-25-2011, 10:36 AM   #21
Glennerd
Glennerd's Avatar
More pics to come. Keep finding everything needs to be re-done as it was never done correctly to begin with.
Old 08-25-2011, 11:48 AM   #22
406 Q-ship
406 Q-ship's Avatar
Do yourself a favor and trashcan that downflow radiator, put a stock crossflow back in the truck. The downflow radiators are nowhere near as efficent as the crossflows that these truck came with, there is a reason that just about every manufacture went to crossflows. Besides the way that downflow is in there (big gaps at the sides) the air will just go around and not through the core. Use a heavy duty cooling with A/C Radiator for a SBC including the fan shroud (the fan are always pretty close even though it is a Olds). Put a good clutch fan on it too.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-25-2011, 11:51 AM   #23
chevypoint
chevypoint's Avatar
Do you have any good shots of the motor mounts? I have a 403 Olds out of a Trans Am that I have been thinking of using. I have been wondering how to make the mounts.
71 c20, 350/automatic
71 K5 Blazer, 350 3 speed (really my 16 yr old sons)http://67-72chevytrucks.com/vboard/s...d.php?t=686111
71 GMC build thread; http://67-72chevytrucks.com/vboard/s...d.php?t=468765
47 Chevy Aerosedan, 403 Olds/350 turbo
69 Camaro, 307/powerglide
06 Silverado Z71
chevypoint is offline   Reply With Quote
Old 08-25-2011, 12:40 PM   #24
Glennerd
Glennerd's Avatar
Lost the rad and had the old one re-cored. Went with a TCI tranny cooler to lighten the load on the rad. I haven't got my camera right now, but tonight I will post some photos of the motor mounts. I bought the truck with the motor in it, but as you can see I had to modify the drivers mount to allow clearance for the #1 primary tube. The pass. header was not modified but the driver's side was and I'm not sure what the were off of to begin with.
Old 08-25-2011, 02:58 PM   #25
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
I have an Olds 455ci in my '67 Burb and if I wasn't at work I'd shot to pictures of it. The one thing I don't like about mine is the exhaust manifolds (no headers) on one side of the frame rails almost touch them.
My engine has an Elebrock Torker II intake and Holley 800DP, other than that I have no clue. Even though it sounds like it might have a cam at low idle.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
