Dads old '72
Ok. First things first. I’m new here and I’m looking forward to learning a lot and giving info and ideas back when I feel qualified enough to do so. I’m excited about becoming a part of the hot rod/old school group… So this is what I have. 1972 Chevy Truck. It was Dads truck and I’m getting it and I want to fix it up, drive it around, and show it off. My Dad loved driving that truck around and I want to have it for a long time to pass to my kids one day. What I need is basically a checklist of where to start on this project. I feel like I’m going to be doing things 2,3, or 4 times because I’m not doing it in the right order. Bodywork is fine other than the cab. Dad said it had gotten hit before he had it and the doors never shut just right. He said I should get a whole new cab. Other than that, no body problems. It’s already primed and ready for paint… now the bad news. The old 307 is weak. Doesn’t run cause it needs a new carb. I want to put in a 383 or 427 anyway. So that means tranny needs to go, drive shaft, and a new rear end needs to be put in. I want airbags on the back too. I’m sure the body needs to come off, cleaning and painting and coating done, new stainless bolts put in… So. That’s it in a nutshell. Can you guys pass along some of your hard won wisdom to get me going on this? I will post pics and start a new thread with updates on everything I do. I’d like to help someone else with his or her project by seeing the work on here… Thanks!
Re: Dads old '72
I would say it sounds like you got the order right.
If it where me I would take the body, engine, and transmission out/off and start on the air ride. Then do the body modification to make it fit on the chassis. Do the engine and all that last. |
Re: Dads old '72
Welcome, so where to start. I tore mine down completely and stared there. Cleaned up the frame, looked it over for any repairs. With it stripped you can do any suspension or brake modification with ease, and it is not hard removing the body. You can then build you engine and tranny how you like and install it with no body on, get the whole driveline in, do the exhaust etc. Clean up the cab do any body work / paint / mods etc. Reinstall the cab and box and the rest is fairly simple. You can really do this any way you want, as long as you know what you want to do. Look over what you have, figure out what you want, figure out how much you can spend and then check on the price of the new stuff, it is really easy to go over budget on these trucks, so knowing your timeline also helps. Post some pictures so we can see what you have.
Re: Dads old '72
Okay. Thanks for the initial feedback... Im going to put picture up soon and get going on this build. All info with respect to the best parts to go with, or not go with is appreciated...
This is what I want in the end: 427 IFS mustang front end Bags in the rear One piece side windows Ford 9 inch rear end Gas tank moved under the bed, not behind the seat.... Fuel Cell... Any ideas here? Big nasty cam that makes the truck shake the ground Last edited by quickstrikez06; 02-15-2011 at 01:17 PM. |
Re: Dads old '72
Go big block for sure. The stock rear end is strong enough unless you plan on big HP and big slicks. just my .02
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
Re: Dads old '72
Curious, why the mustang front end? The front suspensions are easily modifiable without doing that. Check out the suspension forum for some other ideas before you make your mind up.
-Scott- |
Re: Dads old '72
The IFS was an idea that Dad gave me. He said it was a really popular front end set up to use... Im open for ideas. I'll look on the suspension forum.
Re: Dads old '72
#9 | |
Re: Dads old '72
Re: Dads old '72
Re: Dads old '72
So it looks like I might not be going with the Bagged option... What do you guys think about doing a single side window? It looks pretty good. What all goes into it?
Re: Dads old '72
Im thinking about switching the cab out due to a old wreck that bent the cab a touch... Does the truck Title follow the Cab or the frame? Just trying to decide if I should get some sheet metal work done on the truck, or just get a better (non-wrecked) one./
![]() Join Date: Feb 2010
Re: Dads old '72
The title in GA follows the cab, since that's where the VIN is. But since you don't need a title in GA for a truck of this age, you just need to get the police to do a VIN search and affidavit to verify that it is not stolen so that you can register it. I've had several vehicles done this way.
Shawn |
Re: Dads old '72
Okay Zeke... Im going to keep the cab then. My buddy owns a body shop in Monroe. I'll just have him fix the corner then. I want to keep the vin and frame all together... Not sure if that makes sense or not... but oh well! haha. I think I've decided on the '72 paint style. The colors are going to be 2011 Corvette ZR1 Cyber Grey and white. Im going to get corvette front and rear calipers and have them painted the same light blue that's on the ZR1 too... The blue caliper and the blue flake in the paint look really nice together. Thats the plan for now.
#15 |
Re: Dads old '72
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#16 |
Re: Dads old '72
