03-22-2011, 10:53 AM | #1 |
C10 Club Tennessee
Project Patina Burb
I picked up this 1972 burb down in Olive Branch, MS, about 4 hours away from me. It is a really solid burb. A couple of rust spots, but overall it's real solid.
Not a fan of the rear of it too much, but it's growing on me. I plan on drilling out the door handles so I'm not leaving them shaved. The guy has the parts for a 67 front end already and that was a selling point for me. It has 2 inch drop coils in the front, 4 inch in the rear w/1in block, Drop Shocks all the way around and it's already been C-Notched. Also already has the Adjustable Track Bar installed. He gave me a set of bags to go with it because I've toyed with the idea of just bagging the rear to get it lower. I'll probably try my luck with schrader valves if I do. Came with all new weatherstripping except for the rear side windows. My plans(as of now) 5.3/6.0 LS Engine 67 Front end Lower it more!!! Going to go Blue and White Patina Newer Chevy Tahoe Seats
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 03-22-2011 at 10:54 AM. |
03-22-2011, 10:55 AM | #2 |
C10 Club Tennessee
Re: Project Patina Burb
I'll also cut out that dash and put the factory one back in there.
Going to part ways with the seats, don't know what they are worth, but it did come with the hold downs.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-22-2011, 12:21 PM | #3 |
Restoration Virgin!
Look forward to following along Bryan!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
03-22-2011, 02:57 PM | #4 |
On the fast track to nowhere..
I'm in for the long haul B!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
03-22-2011, 11:51 PM | #5 |
C10 Club Tennessee
Mike, will those bags work? Nobody has answered me on the suspension section.
03-23-2011, 10:04 AM | #6 |
Well, here's the deal. I can't find any weight rating for this series of air springs. The 100psi max rating on the bag scares me a little. It has a 9"nominal outside working diameter but that isn't the max diameter. I can't even find anything that says what it's intended use is. If it were mine I'd try it if the diameter isn't too big.
03-23-2011, 02:24 PM | #7 |
C10 Club Tennessee
the plate is 6.5 inches
03-23-2011, 02:27 PM | #8 |
I saw that. I found every spec. for them except for the weight rating, which is what I thought would be the most important one
03-23-2011, 04:46 PM | #9 | |
"Oh well, it's a driver."
Subscribed, should be an awesome cruiser. I once went to Olive Branch to pick up a truck. Mine didn't come home on a trailer, but it probably should have
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
03-23-2011, 07:03 PM | #10 |
Got these off the Good Year website hope it helps
max Dia. @ 100 psig - 10.3" stroke - 7.2" min compresed hight - 3.5" max extended hight - 10.7" force @ actuator hight limit PSIG 100 80 60 40 2924 2285 1674 1081 Force @ compressed hight PSIG 100 80 60 40 6000 4700 3600 2400
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff Last edited by 71gmcburb; 03-23-2011 at 07:04 PM. |
03-29-2011, 04:09 PM | #11 |
dave
Have 2 agree with u on that dash.....uuuuuuuhhhh yeah
QUOTE=5150;4569479]I'll also cut out that dash and put the factory one back in there. Going to part ways with the seats, don't know what they are worth, but it did come with the hold downs.[/QUOTE]
check out my build "DIRTY BURB" |
03-29-2011, 06:16 PM | #12 |
*Subscribing*
Build Thread: Frankenburb .._________ /____|__|__\___ l__(o)______(O)_l Cruizin' Thru... Low N Slow |
03-31-2011, 06:53 PM | #13 |
C10 Club Tennessee
Got a little done today.
I started on my fauxtina paint job I also yanked out the automatic steering column with no tilt and unbolted the dash. I guess I'm going to have to take a sawsaw to it and cut it out. It looks like the just covered it with another piece because I can see the old dash behind it.
04-02-2011, 07:42 PM | #14 |
C10 Club Tennessee
Finished the other side today with a little help.
04-08-2011, 07:28 AM | #15 |
04-14-2011, 02:06 PM | #16 |
C10 Club Tennessee
I got the bags bolted in on the rear
05-18-2011, 05:39 PM | #17 |
Restoration Virgin!
got anything done on this lately
05-18-2011, 05:51 PM | #18 |
C10 Club Tennessee
Not much, started the patina paint job, but that's about it. I'm having to find the door handles on the third door and the driver's door. It's made me lose a little interest.
05-18-2011, 06:08 PM | #19 |
its all about the +6 inches
the front is more than 2 inches... it has stepped lower control arms too. You have a 3 or even 4 inch drop up front once the motor goes in.
05-18-2011, 06:19 PM | #20 |
C10 Club Tennessee
I'll definitely be getting rid of those lower control arms.
05-19-2011, 09:25 AM | #21 |
Restoration Virgin!
Is that something made we can find dimensions for in the factory assembly manual for ya?
05-19-2011, 10:03 AM | #22 |
C10 Club Tennessee
Nah, I've got the angle grinder out and I'm just going to have to find it.
06-15-2011, 11:42 PM | #23 |
BlahBlahBlah
So its been a month since and update ... how is your new ride coming along?
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
06-16-2011, 09:25 AM | #24 |
C10 Club Tennessee
Very slow, been working three jobs and I am the promoter of the Southeastern Truck Nationals which is coming up in a month. Also, my wife is 7 1/2 months pregnant. I'm a little busy
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 06-16-2011 at 09:26 AM. |
06-16-2011, 09:35 AM | #25 |
BlahBlahBlah
You are busy =) Congrats on the new kiddo! She's due in July/August? Thats gonna be tough for her in the full heat of the summer.
