Steering wheel resizing
has anyone ever seen a smaller version of orginial steering wheel possibly aftermarket
![]() Join Date: Jul 2000
Re: original steering wheel
I cut one down to 15 inches and took pics of process . Will post pics when I figure out why not posting corrrectly.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
Steering wheel cut and bent to new dia
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:37 PM. |
Rim welded together with new spoke locations cut out
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:38 PM. |
Had to add extensions to spokes because I cut spokes too short. They should be cut flush with rim.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:39 PM. |
Welding process
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo Last edited by augie; 04-04-2011 at 10:40 PM. |
Using filler and shaping
Finished product. Sorry about individual pic post, could not get them to post all at one time.
I like it. You got me thinking. Did you use regular body filler?
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
I used epoxy on cracks and then covered and feathered with Bondo. I used Bondo on the big gaps. PC-7 Epoxy would also be a good choice instead of Bondo. (this is and old spare wheel). This is first one I've tried.
Note: the steel ring is made from hardened steel and I used two Bosh metal cutting jig saw blades to cut. The outer material is similar to hardened rubber but will not crack when bent to size. I cut the spokes initially with a stub on the rim, but side spokes move up in rim when it is resized and should be cut flush . If I had done this I would not have had to weld extensions on spokes. Will be glad to answer any questions.
Registered Chevy Owner
Ok I just saw this thread and I have a question. Do you think that a smaller diameter late model steering wheel would work instead of cutting up the original? I'm thinking a weekend project in in the near future.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
nickp51chevy: I have used an 80's model Camero wheel that is a direct fit and is 14and 1/4 inches in diameter. I have also used a 90's Chevy truck wheel and it is 15 and 1/2 inches in dia. and does not require modification to fit.
![]() Join Date: Aug 2010
That looks awesome. I really really wanna do this to my steering wheel. Have you tried it on a truck? Is it centered?
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
I put this on my truck after I completed it. I really like the smaller diameter. I tried several other wheels (Camero, 90's truck, Grant) but I like this style. If I do another one I will make the cut in the wheel at the bottom where the spoke attaches after I have cut spokes out of course. I will also cut the spokes as close as possible to the rim so I wont have to weld pieces back to spokes. I can then trim the spokes if necessary. Plan on using several metal cutting blades, the core is hardened steel.
