Old 08-28-2010, 04:33 PM   #26
JWPOORE
Re: Blazer interior rear panels
I too am in favor of the cleaner look and tucked behind the pillar.
JWPOORE is offline   Reply With Quote
Old 08-28-2010, 05:47 PM   #27
1972CST
1972CST's Avatar
Doesnt the chrome strip at the top of the rear panel help to form the needed contour? I dont see the strip I am thinking about in any of the pics.
1972CST is offline   Reply With Quote
Old 08-28-2010, 08:01 PM   #28
VA72C10
VA72C10
VA72C10's Avatar
You can go all the way past the piece in the front if you put a formed spacer across the top edge as seen here:
Old 08-28-2010, 09:21 PM   #29
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
I don't have a chrome strip on mine. Does anyone have a pic of it? Let me think about the spacer idea, that may work.
FuelCellGuy is offline   Reply With Quote
Old 08-29-2010, 07:26 PM   #30
1972CST
1972CST's Avatar
I like the spacer idea... especially for those who dont have the chrome strips at the top.
Old 08-30-2010, 09:29 AM   #31
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I think maybe these strips were only on the CST models (or those with the rear panels). Heres the best shot I have from pre disassymbly.
Tom Vogel is offline   Reply With Quote
Old 08-30-2010, 11:28 AM   #32
FuelCellGuy
FUEL CELL GURU
Ok, so the metal strip creates a straight line for the panel.... thinking........
Old 09-03-2010, 02:25 PM   #33
Liron72Blazer
The metal trim does not make it a straight line it simply went over the origional panel in-between the front and rear posts. The trim slides over the panel.
The spacer plan is a good one but you would not be able to use the stock chrome trim, if you had it. It was a CST trim piece. The spacer and panel would be to thick for the trim to slide over.
Here are picts I put a trim on a 72 that is awaiting interior. I mocked up the trim so you could see it.
On my other 72 I had my upolstry guy use a thin piece of plywood and then covered it with vinyl to match. The plywood was thin enough that we could bend it around the posts and use screws to hold in place.
If you could use a thin piece of allum that could be held with screws around the post that would be cleanier and like stock.
Liron72Blazer is offline   Reply With Quote
Old 09-03-2010, 03:15 PM   #34
FuelCellGuy
FUEL CELL GURU
I have decided to do a mockup in aluminum. That will be the best way to go.
Old 09-03-2010, 03:27 PM   #35
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Cant wait to see these..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-29-2010, 01:03 AM   #36
mcmlxix
Collector of Projects
mcmlxix's Avatar
Update? Pics?
Rich
1972 K5 Blazer CST Click HERE
Old 09-29-2010, 09:42 AM   #37
hgs_notes
GEARHEAD
hgs_notes's Avatar
Why not just make them the same dimension as original panels, so they fit using the buyers existing hardware? No need for spacers, etc.
hgs_notes is offline   Reply With Quote
Old 09-29-2010, 10:33 AM   #38
VA72C10
VA72C10
VA72C10's Avatar
I'm assuming (bad idea, right ) that it's because there's not much of the CST hardware out there. anyone w/out the panels originally doesn't have the hardware so this is an option for them. Like my blazer that didn't have it. Plus, I like the way my panels look covering the end panels vs having those painted panels showing between the panel. It's a sleeker look IMHO (FWIW)
Old 09-29-2010, 11:26 AM   #39
hgs_notes
GEARHEAD
hgs_notes's Avatar
I hear ya, I didn't know the CST package was that rare, seems half or more of the blazers I've come across were. How about a short and long version? One for those that have the mounts, and a kit for those that don't or would like a more custom look covering the end panels.
Old 09-29-2010, 03:56 PM   #40
Rochlow
What does the alumabond look like.
Rochlow is offline   Reply With Quote
Old 09-29-2010, 08:03 PM   #41
FuelCellGuy
FUEL CELL GURU
Alumabond is slick just like regular aluminum. Alumabond is out now because I will have to put two breaks in order to fill the gap. I am going to mock up the panels out of aluminum. I have been swamped and will be getting back on this soon. The one thing that does concern me is how to ship them without them getting damaged.
Old 09-30-2010, 11:20 AM   #42
Effeckt
Effeckt's Avatar
Another option would be to make your own trim piece so the panels will work for owners whether they have they trim or not.
My 1972 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=399719
Effeckt is offline   Reply With Quote
Old 11-02-2010, 02:19 PM   #43
drunkbus
New Member
drunkbus's Avatar
Any progress on these? Making my Christmas list.
drunkbus is offline   Reply With Quote
Old 11-02-2010, 03:38 PM   #44
FuelCellGuy
FUEL CELL GURU
I have been SWAMPED. The online fuel cell orders have been thru the roof! Thanks to all! I will get back on this soon. Sorry for the delays. Thanks!
Old 11-04-2010, 02:18 PM   #45
Muleman100
Muleman100's Avatar
I could drive from Houston to pick up a pair.
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
Old 11-04-2010, 07:38 PM   #46
dnandez
dnandez's Avatar
I am interested also!!
72' K5 Blazer
71' K5 2wd conversion project 454 ls7
71' C10 Cheyenne long box 66k original miles
dnandez is offline   Reply With Quote
Old 02-19-2011, 05:32 AM   #47
SlowYourRoll
SlowYourRoll's Avatar
Subscribed.
SlowYourRoll is offline   Reply With Quote
Old 05-12-2011, 08:27 PM   #48
205harleyman
205harleyman's Avatar
I am interested, do you have them available yet?
205harleyman is offline   Reply With Quote
Old 05-12-2011, 11:07 PM   #49
Jtrux
I'm a poor spectator
Jtrux's Avatar
What's the price on these?
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-20-2011, 04:03 PM   #50
FuelCellGuy
FUEL CELL GURU
Ok, I have really dropped the ball on this one. We have been extremely busy and short handed (had a guy quit, I know in this economy, that's unheard of). What I CAN offer right now is full size paper patterns so that anyone can produce them from the material they want. I can do $25 + shipping in the continental US. Eventually, I will produce the panels, I just don't have the time for R&D right now. Thanks everyone.
