i need some help selecting shocks
hey guys.i tried the search but had no luck.im finishing my airbag setup on my build and im at the point where i need shocks.since im building my own mounting brackets i could use just about anything you suggest.im using a DeNominator-II 2500 and 2600 setup.what i would really like to use is a common stock shock that will work and i could easily order from a local parts store.reason being since i live in the great white north Canada, they think its a great idea to charge an arm and a leg to get it across the border from the U.S.thanks for any help fellas
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#2 | |
Re: i need some help selecting shocks
Formerly LSC71
ok thanks guys.so where im using the 01 sierra frame just go with a decent set of shocks for that year sierra?i was just worried they didnt have enough travel for using bags
#5 | |
I did use a different rear shock but only because @ the time I built everything, they did not offer a direct C10 replacement.
