#276 |
Re: 2" Drop Trailing arms
i know i wanted to change it to the truckarm setup i know there some differences to the frame between the older 67 model truck and the square , the part that kicks up is at another spot and the frame is less tall so using a porterbuild old '67 style truckarm crossmember on a squarebody doesnt work out of the box , i have seen a square that had truckarms installed but that was a different manufacturer and wasnt as good looking as the porterbuildstuff
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#277 | |
![]() Posted via Mobile Device
Long live SLIM ------------------ At least try to buy American ![]() |
#278 |
woohooo
#279 | |
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#280 |
Here's a few pics...
This is part of a rear kit we are buttoning up for the 73-87 chassis. It will let you convert the leaf springs to trailing arms. We have a 71 rear end mocked up in it right now, but it will have the factory 12 bolt back in it shortly. This crossmember is for a 2-piece shaft (for laying frame)... the one-piece shaft crossmember is just a little different. More to come on this in the future. ![]() Nate
#281 |
Awesome Mr. Porter! I wonder if it would work on a dually......
#282 |
Registered Cruiser
That is killer, Nate!!!! Nice work as usual!
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#283 |
from wat i can see on the pics it should work on a dually it end at the same spot the leafsprings would , i dont know if you need spacers for the crossmember in the higher c30 chassis or if it will fit a straight beam chassis cab version and you prolly need larger U-bolds and saddles for the 14 bolt rearend ...... not realy hard stuff to change youreself if needed .
one thing im happy about , i was afraid it wouldnt fit a th400 with a gearvendor but theres plenty of room between the tail of the automatic and the crossmember ...... did you done the mockup on a longbed or a schortbed nathan ?
#284 | ||
Now that the 74 is doing new things w/it's new owner, I have the dually & always thought the T/A's could work on one of these as well w/the right design set-up. I was only kidding though when I asked the question..... Quote:
#285 |
im going to change a 1977 C25 intoo a dually (i have a set of spindles/1 ton hubs and the hubs for the rearaxle and a set of adapterplates for a set of 22 inch truckrims )
nathan adapted a set of strongarms for 1 ton spindles back in the days he wasnt making his own arms and i still got one of his old style dropmember im planning to mount on the truck ........ the stuff is gathering dust and some flyrust right now but trust me it will be done
#286 |
Moderator
![]() ![]() Join Date: Aug 2011
Whatever happened to the 2" drop Trailing Arms, Are they for sale?
#287 | |
Nate
