Old 08-28-2011, 01:37 PM   #1
taank
Boom
My truck started missing and clattering. Got it trailers home. Pop off the valve cover. Found #7 intake rocker had fallen off. The stud broke off inside the poly lock. The pushrod and lifter where
Pushed up. Pushrod is not bent lifter has no visible damage rocker body has no visible damage.
So now I'm contemplating should I replace all the rocker studs? And should I replace the lifter? Should replace the rocker arm?
What could be the root cause of the failure? The valves where'nt floated and it wasn't over reved. It has been running pig rich lately. (soot on fenders) I attributed that to not having the proper torque converter. Base idle screw is set higher. Occasionally I will get an audible fart noise out of the air cleaner. Also thinking lack of converter.
taank is offline   Reply With Quote
Old 08-28-2011, 01:41 PM   #2
taank
Re: Boom
It's a 10:1 383 stoker. Dyno'd at 518 hp with a vac sec 750 Holley 4160
Old 08-28-2011, 02:13 PM   #3
project 67 sub
project 67 sub's Avatar
Re: Boom
are you running roller rockers?? screw in rocker studs or stock studs??
project 67 sub is offline   Reply With Quote
Old 08-28-2011, 05:50 PM   #4
taank
Re: Boom
Harland sharp 1:5 3/8 screw in. Atop afr 195 eliminators. Comp xe284 hyd. Flat tap. Springs are correct for cam.
Old 08-28-2011, 06:44 PM   #5
eldogg
eldogg's Avatar
Re: Boom
I would replace all the studs and polylocks, then check your pushrod length.
eldogg is offline   Reply With Quote
Old 08-28-2011, 07:51 PM   #6
taank
Re: Boom
This was assembled and checked by a reputable shop. I'm positive length was correct.
Old 08-28-2011, 08:46 PM   #7
hjewell2
hjewell2's Avatar
Re: Boom
Screw in studs or pressed...also guide plates or not single spring or double. The reason you were getting the fart noise is because the rocker was backing off and poping back back through the carb.
hjewell2 is offline   Reply With Quote
Old 08-28-2011, 10:00 PM   #8
taank
Re: Boom
Screw in 3/8. Guide plates. Double spring
Old 08-28-2011, 10:22 PM   #9
project 67 sub
Re: Boom
was the work they did warrantied??? if so i would try and take it back to them and see whats up
Old 08-28-2011, 10:27 PM   #10
70cst
70cst's Avatar
Re: Boom
X2
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is online now   Reply With Quote
Old 08-28-2011, 11:17 PM   #11
webfoot
Re: Boom
How long are the rocker arm studs you are running? Need to run the taller ones with roller rockers or you will not have enough threads making contact which will weaken it.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
