10-21-2011, 06:19 PM | #1 |
Add A Leafs and ride quality
I just noticed today that there is a set of add a leafs in the front spring packs of the '63. I've been wanting to do the 52" front / 62"rear spring conversion to get better ride quality out of my DD. My question is this; do the add a leafs affect ride quality that much or is it actually possible to remove them and get a better ride. I know I may lose a little height but at this point, I'm not too worried about that (unless the spring pack is totaly shot). What are your experiences with add a leafs good or bad? Just looking for some input so I can make some good decisions here. Thanks, Chris
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-21-2011, 06:38 PM | #2 |
20' Daredevil (Ret)
Re: Add A Leafs and ride quality
Limited experience here but I guess every lil bit of info helps....
For me, AALs were a fairly satisfactory inexpensive, temporary fix. My front springs were sagging so I installed AALs. Did the trick for several years and ride quality wasn't too bad -- stiffer than stock, which is probably to be expected. Eventually had too much sag even with AALs so I got 2.5" Softrides. Huge improvement and well worth it IMO.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-21-2011, 06:53 PM | #3 |
Newbee
I have had several big block 4x4's over the years, and all of them ate front springs. I replaced several sets, then went to add a leafs. I had much better life out of the AAL's. I kind of like the stiffer ride though.
10-21-2011, 07:37 PM | #4 |
honestly it it was me I would call the spring shop and get a price for new springs. if they were in the buget i would pull the AALs and see what it does if you dont like it put new springs in. we have a great spring shop close to here so i may be bias. good luck.
10-21-2011, 08:17 PM | #5 | |
10-21-2011, 10:56 PM | #6 | |
10-22-2011, 10:49 AM | #7 | |
20' Daredevil (Ret)
Sounds like you might just have too much spring.... it'll be interesting to see how it rides without the AALs.
