Old 10-23-2011, 11:14 PM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
Cab differences?
What if any is the difference between a 69 C10 cab and a 72C10 cab? I have a 69 that could use a bit of work, rockers, driver floor ect. but its all original with great fitting doors. Just trying to decide which direction to go?
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 10-24-2011, 07:27 AM   #2
FL71C10
Re: Cab differences?
The only 2 things I can think of would be that the 69 had a throttle rod and the 72 had a throttle cable. The 72 mirror mounts to the windshield, where the 69 mirror mounts to the windshield header.
The 72 doors are different, but I guess you would be using your 69 doors anyway.
That's all I know that's different for sure, but others who are more knowledgeable might chime in with other differences.
Oh, maybe the fuel tank ventilation lines might be different also.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-24-2011, 07:43 AM   #3
72k5zl1
72k5zl1's Avatar
vin tags are different style. 1 piece 72, and 2 piece 70? and earlier. 72 only has a vent on the drivers door post. some 72s also have part of the vin stamped on pass side floor below heater box by toe kick panel. stamped from the bottom. 68 and back had a different firewall due to the e brake change. hope this helps, glen
my build threads, 68 pro touring, auto cross c10 (mid life crisis)
http://67-72chevytrucks.com/vboard/s...d.php?t=464109
website http://www.sauersgarage.com/
72k5zl1 is offline   Reply With Quote
Old 10-24-2011, 08:16 AM   #4
Two piece Vin Tag on Jamb through '69.
Old 10-27-2011, 01:16 AM   #5
scotts72heavyhalf
So I could swap the vin tags over and it would then match the title ?
Scotts72C10
