Old 09-10-2011, 10:16 PM   #26
Indian113
Indian113's Avatar
Re: 1949 Chevy Truck Subframe Install - Any Pictures
Looks can be decieving!!! It has some issues,a lot of rust on cowl and floor. Too bad your so far away I'd make you a deal on it!! I have way too many projects and not enough $. I am working on a model a and my wife's 64 at the same time
Indian113 is offline   Reply With Quote
Old 09-11-2011, 08:59 PM   #27
flatbed51
flatbed51's Avatar
Originally Posted by Indian113 View Post
You can use the rearend too,just watch your backspacing on your wheels. I would use EVERYTHING I could from that bird,you'll save some money. I moved my frontend out to make my wheelbase longer so the front wheel set in opening centered.
Indian what length wheelbase did you wind up with after moving it forward ?
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 09-11-2011, 10:20 PM   #28
Indian113
Indian113's Avatar
I'll measure it in the morning and post it, did it so long ago I can't remember exactly
Old 09-12-2011, 07:03 PM   #29
Indian113
Indian113's Avatar
After measuring it I found out I didn't add any lenght it measures 116 inches.
Old 09-13-2011, 07:16 AM   #30
72Mountaineer
72Mountaineer's Avatar
I've seen lots of these subframe grafts. One question...how do you do the brakes? Do you have to use the firewall mounted brake units? Or will everything still work under the floor?
72Mountaineer is online now   Reply With Quote
Old 09-16-2011, 08:49 PM   #31
tmoble
I have a 2nd gen Camaro clip with an C4 Vette rear, still using the stock master. I'm about to go to a dual though.
tmoble is offline   Reply With Quote
Old 09-16-2011, 10:10 PM   #32
mknittle
mknittle's Avatar
I am going with a firewall mounted hydro boost mostly because my engine is pretty wide.
I am using a 400 Pontiac and a 4speed. I would like to use the same set up under the floor but It wont all fit with the exhaust and clutch linkage.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-22-2011, 05:48 PM   #33
Bonechip67
Can anyone tell me if a 76-78 nova frame is wider than the 74? I bought a sub frame and think the guy thought it was a 76. Being the novice, I didn't think there would be a diff but got it all the way home and it measures out to be the same width as the Camaro which I didn't want. Any help would be GREATLY appreciated! Also, has anyone here used a later Nova sub? Thanks
Bonechip67 is offline   Reply With Quote
Old 10-22-2011, 06:27 PM   #34
Indian113
Indian113's Avatar
Bonechip,if the sub is a front steer it's the same as a camaro. A 74 nova is rear steer,68-74 nova,67-69 camaro-firebird are all the same.
Old 11-08-2011, 05:50 PM   #35
Bonechip67
Smile Re: 1949 Chevy Truck Subframe Install - Any Pictures
So is it common to extend the wheel base 3 inches to make it look better? Need to know before I weld it all up!
Old 11-09-2011, 11:25 AM   #36
nacho55
Eu
I am no expert but I think its a preference on how you want the wheels centered in the wheel wells. But what I did was tacked mine good enough to hold weight and set it down and put the sheet metal on a couple times to make sure I liked the way it looked before I did my final welding and measuring
nacho55 is offline   Reply With Quote
Old 11-09-2011, 11:32 AM   #37
Bonechip67
So what did you end up with for a final length? 119, or 116?
Old 11-09-2011, 12:16 PM   #38
nacho55
I would have to measures tonight when i get home but mine is a long bed so my measurements may not work for you.
Old 11-09-2011, 02:32 PM   #39
Kabwe
Certified Car Nut
Kabwe's Avatar
Man the center of the wheels is fine at 116. Plus you should always just tack it end (its very easy to remove a tack weld) and hang a some sheetmetal and have a look before any final welding. Once you are satisfied weld it in.
This is 116 wheelbase with the rear end also centered in the fenders (some of these trucks are off in the rear also).
Kabwe is offline   Reply With Quote
Old 11-09-2011, 07:34 PM   #40
Root2812
Root2812's Avatar
Off topic but what size wheels and tires are those? I really like the way that size set up looks in the wheel opening. I've been trying to decide if 15 or 16 inch rims are the way to go and then what size tires.
Greg
Root2812 is offline   Reply With Quote
Old 11-09-2011, 08:42 PM   #41
Kabwe
Certified Car Nut
Kabwe's Avatar
Greg
Its not my truck I just installed the clip for a buddy of mine. I had to give him a call and he told me the front is 14x7 with a 235/60/14 tire the rear is a 15x8 with a 255/60/15 tire.
I hope this helps, because I got in a argument with him on the phone because I did not believe the fronts were 14's and he cuss me out and went to go check.lol Once he verified it, he cuss me out some more for not believing he knew what was on his truck. I told him that I will be by to verify it myself this weekend. You don't want to know what he said to that.lol
Old 11-09-2011, 09:56 PM   #42
mknittle
mknittle's Avatar
all 3 1/2tons we have are off center in the rear. they all seen to be different.
Mark
My GMC build.
Old 11-09-2011, 10:38 PM   #43
mknittle
mknittle's Avatar
oops that's 4 mine
Mark
My GMC build.
Old 12-09-2011, 03:36 PM   #44
Bonechip67
Well, we got it all measured and measured.. I think it was 2 evenings worth, but we got it tacked in. Had to haul the cab and fenders from storage to check to make sure it looked right. It did so back apart it all came. Now just welding the sub on for good and boxing it. Them a good cleaning and some paint! I have a few pics, but im sure you guys are tired of all the build pics so I wont bore ya. Thanks for all the info guys!
Old 12-09-2011, 04:40 PM   #45
solidaxel
solidaxel's Avatar
Don't forget to measure the angles for castor on the upper "A" arms!
Check out Rob's post on safety from No Limit, some good points to follow
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-11-2011, 08:51 PM   #46
rollinrooster
rollinrooster's Avatar
If he keeps cussn you tell him you will just put his truck back like it was. Nah just kiddin, youre work is killer and he is the lucky one to have you fix it.
rollinrooster is offline   Reply With Quote
Old 12-11-2011, 09:27 PM   #47
Kabwe
Certified Car Nut
Kabwe's Avatar
LOL. Thanks man, he is just a grouchy old man but he's cool.LOL
Old 03-30-2012, 03:12 PM   #48
Bonechip67
Well I got my 53 back on the road with a little help from all of you, Thanks!!! Now Im picking up a 57 in the next day or two. Think I can do the same sub swap out but with a later Nova or Camaro/firebird correct??
