11-22-2011, 10:05 PM | #1 |
Equal opportunity joke ofender
97 GMC 1500 parts
I have up for sale a complete cab and front clip left over from a truck i scrapped out. I will post pics. tomorrow. would like to sell all one pc. but will entertain offers to break it down smaller pcs. Local pickup only asking $1200 but will consider offers
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-23-2011, 05:57 AM | #2 |
Re: 97 GMC 1500 parts
If you decide to part the cab interior my son is needing the heat and air control for his '96 Chevy Z71 pickup. Should be the same I would think? Need the control unit and the wire harness both. Also if parting, what are the sunvisors like? Need a tan or camel cloth set with working vanity mirrors and shade extentions for my '99 Tahoe. Pics would help to clarify if you decide to part the cab.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
11-23-2011, 09:22 AM | #3 |
It was basically a work truck series with blue vinyl interior and bench seat. I pulled the steering column out of it a few months ago because I had someone interested in it but the deal fell through, so it is just laying in the cab. I will post pictures this afternoon when I get home.
Richard
11-24-2011, 03:38 PM | #4 |
here are some pictures
11-24-2011, 08:11 PM | #5 |
Do you know if the heat and air controls were working in the truck? My son could use them to include the wire harness that attaches to the back. Any broken mount tabs or clips? Price and shipping to 67152 zip.
11-24-2011, 08:57 PM | #6 |
everything was working when taken out of service. transmission went out of truck and ended up buying new truck. this one had 200k on it. I will try to pull it out romorrow and check condition and see what shipping would be
Richard
11-26-2011, 12:29 PM | #7 |
Any luck on the air/heat control and harness? Not in a hurry, just wondering. If your like me, I never get everything done during the day I plan on.
11-26-2011, 12:45 PM | #8 |
Sorry forr the slowness of reply on this.. I thought I had the cab sold locally but it does not appear it is going to work out. If it does not work out i will part it out and you will be fiirst in line for the heat controls and harness. I should know a little later today.
Richard Posted via Mobile Device
11-26-2011, 01:32 PM | #9 | |
Richard
11-26-2011, 09:41 PM | #10 |
My son stopped by and when I talked to him he said what he is needing is the short "jumper" harness that goes from the back of the control unit and connects to the main under dash harness. He said it is only about 10'' or 12'' inches in length with several black plastic connectors.
11-26-2011, 11:43 PM | #11 |
I will try to get it pulled out tomorrow & get a picture of it for you to show your son
11-29-2011, 12:11 AM | #12 | |
11-29-2011, 09:24 AM | #13 |
Not looking for the radio harness, he is wanting the short pigtail harness from the back of the heat/air control. Approx. 10-12 inches long and uses plastic connectors to clip to the back of the control. Then it plugs into the main underdash harness using plastic connectors.
11-29-2011, 09:39 AM | #14 | |
It has the plugs to clip it to the back of the control but that is it. I will get a picture of it at lunch time when I go home. Richard
11-30-2011, 06:47 PM | #15 |
Any luck on the pic of the wire harness on the back of the air/heat control unit? If the connections to the control are the same on the back maybe could splice them his harness?
11-30-2011, 08:23 PM | #16 |
Sorry, I got jammed up with my 08 gmc today I guess she wiped out the transmission. I will get one in the morning and will snap a picture of the back of the control as well
12-01-2011, 05:31 PM | #17 | |
RIchard
12-03-2011, 10:33 AM | #18 |
Richard, I see what you mean about the wire harness going into the main wire trunk. Since I have not actually seen my son's truck wiring set-up can't really say if it is compatible. Will most likely see him sometime this weekend and have him look at your pics. Hopefully he will be able to tell if the harness you have can be spliced to his trunk. Thanks again for the pics.
12-03-2011, 08:32 PM | #19 |
Richard, my son stopped by this afternoon and looked at the pics you posted of your truck harness. Said it did seem a bit differant in that his has connetor ends at both the control and the point where it enters the main wire
harness. Thinks he may be able to splice into his harness with the connector section from yours. Not really needing the control, his problem is a couple bad plastic connector ends on his harness that won't stay tight to the terminal block on the back of the control. I take it the plastic end connectors are in good condition on your harness? My son wants to know how much for the harness from the control back as far as possible into the main harness, say at least 10 or 12 inches with the good connectors to make a good splice? Shipping to 67152 zip code and newspaper wrapped in a bubble envelope would be good. Thanks.
12-05-2011, 07:41 PM | #20 |
Still interested in the 10'' or 12'' section of the heat/air control harness to 67152 zip code. Son stopped by and asked me about it this morning, told him I had not heard from you as of yet.
12-05-2011, 09:43 PM | #21 |
Even being careful trying to remove the plugs the retaining clips broke on two of the plugs. They fit very tight even without them but I would recommend keeping them with the control unit. if you still want them I would do the unit and pigtails all the way back to main harness for $40 shipped.
Richard
12-08-2011, 11:21 AM | #22 |
Thanks for the pics but my son has decided to pass on the control and harness. He already has a harness with mounting issues so another one with mounting issues won't cure his problem. Thanks again.
12-10-2011, 01:26 AM | #23 |
does it have a under the hood light
12-14-2011, 05:59 PM | #24 |
Sorry Liddy,
your post got overlooked somehow. I am not sure on the light but will check when I get home later this evening and will let you know tomorrow. Thanks Richard
12-16-2011, 11:03 PM | #25 |
How are the doors rust and dent wise? assuming you will sell the doors seperately of course. My son needs doors for his 98 2500.
